The Cap Sprayer arrived yesterday and basically consists of this:
The kit comes with 5 bottles of acrylics which I will store since I'm using enamels on this project.
I filled the provided sprayer bottle with Lt. Ghost Gray enamel and put the unit together. Initially, the spraying was even and steady. But, very quickly, the tiny hole in the spray cap became clogged and needed to be cleaned (using the cleaning wire provided). This cycle repeated itself until I had finished spraying all the parts I had ready for painting.
Tonight I will thin the bottle of paint down a bit using Testors thinner and see how that works. I have several other pieces ready to paint so there is no lack of subject matter.
One other aspect I noticed was that it won't take long to go thru a can of propellant. Luckily, I have the can that came with my air brush kit and I can use that when the kit supplied can runs out.
I'll reserve judgement on the kit as a whole until after I've thinned the paint a bit and see how it does after that.
