At 'Em Arizona Fans!
ESzczesniak
Re: At 'Em Arizona Fans!
Post by ESzczesniak »
Tracy White wrote:Not likely. From http://www.history.navy.mil/branches/avchr5.htm
Kind of what I expected. Thanks for the reply.
Leftie too
Post by Leftie too »
Tracy(or others), is there any evidence that the first batch of Kingfishers on the Arizona(early '41) were painted overall grey like the USS Texas photo?
Dana Bell
Post by Dana Bell »
Hi Leftie,
Arizona's OS2U-3s were certainly delivered in overall Light Gray, then later modified with the addition of Blue Gray uppersurfaces. The ship's name on the aft fuselage was applied in white (as seen in the photos) in the overall Light Gray scheme, but would have been applied in black for a newly applied Light Gray/Blue Gray scheme.
Also, the -3s were delivered before the Light Gray/Blue Gray was introduced for aircraft other than patrol planes.
Dana
Leftie too
Thanks Dana. I actually misread Tracy's post. I wrongly thought of Kingfishers as patrol planes rather than ship-based aircraft. So I guess the first batch of Kingfishers were delivered to the Arizona as yellow wings and painted some time after Feb 26,'41.
I guess only a few questions remain: Are those photos I posted earlier the same original Kingfishers(BuNo 1695-1697) repainted again (Blue over Grey) or factory fresh replacements? The photos dated Sept 6,'41 precede the order listed by Tracy as Oct 13,'41.
Are the Bureau Numbers listed above OS2C-1,2 or 3s? The Squadron Publication "Golden Wings" on pg.7 state that Sept 6 aircraft is BuNo 1683 and was lost in the attack Dec 7th. Misprint/error? Is the aircraft #1-0-3 an OS2U-1 as stated on pg.7?
Thanks for joining this discussion.
Russ2146
Post by Russ2146 »
Leftie Too,
The designation you are using, at times, OS2C, indicates Observation-Scout, second aircraft design of that designation and C, the manufacturer, Curtis. The only trouble is that there was no aircraft so designated.
There was the OS2U, which was manufactured by Vought and called the Kingfisher. The same design, manufactured by the Naval Aircraft Factory, was designated OS2N.
However, there was the SO2C, Scout-Observation, second design, Curtis, which an improved SOC, Seagull, but only a prototype was built. SOC and SO2C were bi-wing aircraft.
Now, the BuNos for
OS2U-1s were 1681-1734, Six of these had been sent to Pearl by the end of 1940
OS2U-2s were 2189-2288 and 3073-3130, Delivered to Navy in 1940-41, 53 of which went to inshore patrol squadrons at NAS Jax. Others went to Pensacola
OS2U-3s were 5284-5989 and 01216-01515. Delivery began in 1941
Dana Bell
Post by Dana Bell »
Leftie too wrote:Thanks Dana. I actually misread Tracy's post. I wrongly thought of Kingfishers as patrol planes rather than ship-based aircraft. So I guess the first batch of Kingfishers were delivered to the Arizona as yellow wings and painted some time after Feb 26,'41.
Hi Leftie,
I'm going to have to give you a partial answer right now, since I can't find the documents I scanned last week on OS2U assignments for 1941.
Most USN Kingfishers were assigned to short-range patrol units called Inshore Patrol Squadrons. But the aircraft assigned to battleships were part of Observation Squadrons (VO-1, VO-2, etc). Nearly all of the -1s were delivered to Battle Force in the colorful aluminum/yellow scheme. These all would have been replaced or repainted by December/
First, those Arizona photos are usually described as showing OS2U-3s, and that's how I've usually identified them. However, two small clips on either side of the windscreen mean that these aircraft must be OS2U-1s or -2s and cannot be OS2U-3s. They could be the original -1s, replacement -1s, or replacement -2s. The -1s and -2s were delivered with Vought floats, which proved too fragile for heavy seas and were soon replaced by EDO floats. All the -3s came with EDOs. (The photos show EDOS.) Most sources show OS2U-3s assigned to Battle Force on 7 December, but there's a big question about just when the change might have been made.
Tracy is right about the Blue Gray order being cut in October 1941, however CinCUS preceded that order with a letter in August. There's no problem dating the pix in September.
The OS2U-1s were assigned BuNos 1681 thru 1734, with aircraft 1695 thru 1697 assigned to Arizona (and so-painted at the factory). I'm not sure if the Golden Wings caption is correct, but that book's research has always seemed pretty sound. BuNo 1683 was originally delivered to West Virginia as 4-O-2, but could have been transferred to Arizona.
Right now I'm pulling together my materials for a talk at the IPMS Nationals; when I return next month I'll get back to work on processing my recent finds and I'll see if anything helps answer your questions.
Dana
Amplifying Dana's post somewhat; aircraft weren't assigned to the ships themselves; they were assigned to squadrons, that were assigned to ship divisions. Note here that it shows each Battleship Division with a squadron of 9 planes assigned. So, for the pre-war markings, since Arizona was flag, that meant that her 1-O-1 had the command stripe, but that none of the other planes in BatDiv One did.
Dana Bell
Post by Dana Bell »
Hi Tracy,
Not to clarify your clarification, but I know you meant that 1-O-1 had the only RED command stripe. Of course, the two other section commanders also had command stripes on their aircraft - a white one (with black borders) on 1-O-4 and a blue one on 1-O-7.
Dana
The red command stripe bears a remarkable similarity to the color of my cheeks right now. :doh_1: :oops:
I KNEW that dammit. Talk about brain fart.
So, thanks to the correction to my clarification.
Hippy Ed
Re: Good Trader Alert.
Post by Hippy Ed »
I have finally started my Banner 1/350 Arizona :big_eyes: Now I wanna know, what is the concensus on her paint scheme 7 Dec 1941 in laymen's terms. I've been thru this thread & many other on other boards and don't quite understand all the "orders" on the different paints.
TIA
Eddie
You've lost everything...
On the Bench:
Hippy, I moved your post from the Good Traders thread in Trading Post (whatever were you thinking!)
There is no consensus for Dec. 7. That's the take away. You have two main choices, both of which are equally likely in the absence of firm evidence either way: 5-S Sea Blue and 5-D Dark Grey. If you don't mind the colours themselves, then flip a coin and call it a done deal. In both cases, she had 5-L Light Grey for the tripod masts above a certain height and had bare un-stained decks, with red turret tops.
Alternatively, she might've been in the middle of being repainted, according to some of the other responses. In that case she could've been wearing both 5-S and 5-D for a patchwork mix of things.
Hippy Ed
Post by Hippy Ed »
Timmy C wrote:Hippy, I moved your post from the Good Traders thread in Trading Post (whatever were you thinking!)
Thanks Timmy! :thumbs_up_1: That's what I wanted to know.
Have no idea how my post got put in "Good Traders" I posted it here :scratch: Aint been there in a year...
On the Bench:
Hey Hippy, here's my thoughts as of last fall:
http://researcheratlarge.blogspot.com/2 ... -blue.html
I don't really have any new information yet to push it one direction or another.
Hippy Ed
Post by Hippy Ed »
Tracy White wrote:Hey Hippy, here's my thoughts as of last fall:
Ok Tracy, Thanks. So, it's safe to say that 5-D hull & 5-L masts above the stacks is acceptible? And Red turret tops & natural wood decks :thumbs_up_1:
On the Bench:
Acceptable? Certainly! It's your model, for one, and she was in 5-D from June until October at least. If you want to do her as she was on December 7th then there's no certainty is all I'm saying.
Hippy Ed
Post by Hippy Ed »
Tracy White wrote:Acceptable? Certainly! It's your model, for one, and she was in 5-D from June until October at least. If you want to do her as she was on December 7th then there's no certainty is all I'm saying.
That's what I wanted to hear Tracy :thumbs_up_1: I know there's been alot of discussion as to the color the past few years & I've tried to follow it. Especially with the great builds of Arizona by some great builders...
On the Bench:
Well, it's not like there should be some minimally acceptable standard for a memorial or tribute; not everyone is Leonardo or Michaelangelo.
Hippy Ed
Post by Hippy Ed »
Thanks Tracy. I know my skills aint near as good as Alot of people on here but, I'm gonna do my best on her :thumbs_up_1:
If I recall right, whwen Arizona & the Oklahoma collided 22 OCT 1941, "Zona was damaged on her port side? Wasn't the Vestal on her port side on 7 DEC?
On the Bench:
I don't recall off the top of my head, but her damage was fully repaired by the Pearl Harbor Navy Yard and the work Vestal was doing wasn't related to the collision -they were building up the radar shack on her aft superstructure in preparation for a radar install scheduled on Arizona's next overhaul.
Hippy Ed
Post by Hippy Ed »
Tracy White wrote:I don't recall off the top of my head, but her damage was fully repaired by the Pearl Harbor Navy Yard and the work Vestal was doing wasn't related to the collision -they were building up the radar shack on her aft superstructure in preparation for a radar install scheduled on Arizona's next overhaul.
Thanks! Was not sure if they were related or not.
On the Bench:
