Model Monkey News
Re: Model Monkey Catalog
Post by ModelMonkey »
We are happy to announce accurately shaped and highly detailed 5"/38 cal. Single Mounts for John C. Butler and Rudderow class destroyer escorts have been added to the catalog.
These mounts are available in several popular scales.
Features:
- accurately asymmetrical gunhouse (turret)
- accurately offset gun opening
- forward face stiffeners
- access hatches with latch and bolt detail
- detailed turret bottom supporting structure with accurately placed bolt-head detail
- rear vent and shell ejection chute
- barrels and trunnions included
Happy modeling!
Steve
bioshock73
Post by bioshock73 »
ModelMonkey wrote:[Sounds like a good idea. I can make a pair of turrets with the tubs and associated ammo lockers. I'll do it when I design the Pennsy '44 products.
A set of Oerlikon tubs is available separately in several scales, now, for those who need some right away.
1/350 flat bottom: http://shpws.me/MCur
1/350 stepped bottom: http://shpws.me/MCuq
I feel like a pest. I was searching through Shapeways. I couldn't find any 40mm gun tubs.
bioshock73 wrote:I feel like a pest. I was searching through Shapeways. I couldn't find any 40mm gun tubs.
I haven't designed a generic set of Bofors tubs because there are too many variations of those tubs, even on a single ship, so many that a generic set wouldn't meet scratchbuilding customer's needs.
PM coming your way.
bioshock73
ModelMonkey wrote:I haven't designed a generic set of Bofors tubs because there are too many variations of those tubs, even on a single ship, so many that a generic set wouldn't meet scratchbuilding customer's needs.
PM coming your way.
PM did explain things better.
opspec
Post by opspec »
Hello Steve,
Regarding your corrected 1/700 North Carolina class funnels, the attachment points for the funnels, parts A3 and C1 on the Trumpeter North Carolina kit, are teardrop shape. Can anything be done about that?
Thank you.
Louis
opspec wrote:Hello Steve,
Thank you.
Louis
Hi Louis,
According to drawings by Thomas F. Walkowiak (The Floating Drydock), Trumpeter's teardrop-shape attachment points (base of the funnels) is accurate. No change there is needed. It's just the funnels themselves that Trumpeter got wrong.
Cheers!
We are pleased to announce that a design for a set of three 16"/45 cal. South Dakota BB-57 class Turrets with barrels is complete in 1/350 scale and has been added to the catalog. These turrets are intended to replace the inaccurately shaped and poorly detailed turrets found in Trumpeter's 1/350 scale USS Massachusetts and USS Alabama kits.
The set is available in most popular scales.
This set of three-gun turrets (more properly called "gunhouses") represents the enormous main battery of battleships USS South Dakota BB-57, USS Indiana BB-58, USS Massachusetts BB-59 and USS Alabama BB-60. They are nearly identical to, but very slightly larger than, the gunhouses of the preceding North Carolina class battleships and differ in minor detail.
Features:
- scaled from scans of original builder's blueprints
- open armored rangefinder viewport shutters
- rangefinders with telescopic sights visible through the open shutters of the armored covers
- rooftop screwheads acurately sized, numbered and located
- armored rangefinder hexhead bolt and screw details
- detailed rooftop periscopes
- left periscope for Turret #2 is accurately offset slightly to the right, just like the left periscope of the real Turret #2
- turrets are marked inside (1, 2 or 3) to identify which turret is which
- accurately sized and shaped ventilation trunks
- detailed turret-bottom crew access hatch, accurately offset slightly to the left
- barrels grouped on a trunnion to allow the modeler to set the position of the barrels to any realistic elevation from +45 degrees to -1 degree (-2 degrees for Turret #3), just like the real turrets
Happy Modeling!
Steve
We are happy to announce the design for highly detailed "angle-back" Mk.37 Directors has been added to the catalog.
The models are available in most popular scales.
1/570 scale "angle-backs" are done.
A 1/700 scale set of North Carolina class 16"/45 cal. Turrets with Barrels is ready.
Sets are available in most popular scales.
We are happy to announce sets of accurately shaped turrets and directors for Revell's classic 1/570 scale USS North Carolina BB-55 and USS Washington BB-56 kits have been added to the catalog.
Happy modeling!
Steve Larsen
Boxart: Scalemates.com.
Large scale USN fast battleship fans! An entirely new design for 5"/38 cal. Mk.28 Twin Mounts has resulted in a 50% price drop in 1/200 scale, 1/192 scale, 1/100 scale and 1/96 scale. Each mount is loaded with detail.
Correct Mk.28s may now be within budget for those with Trumpeter 1/200 scale Iowa and Missouri kits. Both kits 5"/38 mounts are the wrong type, Mk.32s, a lighter-weight version designed for cruisers and aircraft carriers.
Fans of battleships and cruisers at Pearl Harbor on December 7th, 1941! We are happy to announce that sets of accurately shaped and sized, and highly detailed Mk.19 directors have been added to the catalog.
Very happy to announce a set of accurately shaped and sized and highly detailed 16"/45 cal. Triple Turrets for South Dakota class battleships has been added to the catalog in 1/700 scale!
These are a tad bit different from the earlier North Carolina class turrets being very slightly larger and having different details.
mister me
Post by mister me »
dear sirs,
I am truly interested in your 1/350 Saratoga '36-'40 Island, but would like to know if you plan to design it in a simplier concept with windows/portholes closed. I personnaly prefer closed bridge windows (and also hope this item could be less expensive).
thank you.
sincerely,
A. BRANDT
Aop Aur
Post by Aop Aur »
The price is based on the amount of material being used, so making closed windows would be more expensive, although only by a tiny amount if the windows are small.
Aop
mister me
Post by mister me »
even with less complex interior bulkheads/decks ? in doing a fully empty structure ?
mister me wrote:dear sirs,
thank you.
sincerely,
A. BRANDT
Thanks so much for your interest and your patronage!
Message sent via Shapeways.
Aop Aur
Post by Aop Aur »
Well if details are removed leaving just the basic structures, then that will surely decrease the price.
Aop
Sumner and Gearing class destroyer fans! We are very happy to announce a set of three, accurately shaped and highly detailed 5"/38 cal. Mk.38 Twin Mounts has been added to the catalog. The design reflects the World War Two appearance of the mounts, before the addition of external stiffeners.
Here's a rendering of three of the most common types of twin 5" mounts. Shape, details, and type of construction differ.
