Rigging sequence for HMS Victory
JohnReid
Re: Rigging sequence for HMS Victory
Post by JohnReid »
Step 41
Main Royal Stay
2" from truck of main royal mast to tie off around the fore royal mast above the foretopgallant shrouds.
Long P224
Hack P67
"Once upon a time......."Storyboard dioramas by JohnReid.
My photobucket
http://s6.photobucket.com/albums/y250/JohnReid/
JohnReid
Post by JohnReid »
Step 42
Mizzen Royal Stay
2" rope from truck of mizzen royal mast to tie off around the head of main topmast just above the crosstrees.
Long P224
Hack P 67
My photobucket
JohnReid
Post by JohnReid »
My photobucket
JohnReid
Post by JohnReid »
Step 43
Inner Martingale
Long P227
Hack P67
4" rope tied to the jib traveler under the jib boom ,leads through the uppermost sheave in the dolphin striker.through the port side of the bowsprit collar and ends in a 9" single becket block.A 9" single block is tied to the port knighthead,and the two blocks are connected in a gin tackle by a 2" rope with its fall tied off around the knighthead.
My photobucket
JohnReid
Post by JohnReid »
Step 44
Outer Martingale
Long P227
Hack P67
4" rope from outer end of the jib boom,through the second highest sheave in the dolphin striker,through the starboard side of the bowsprit collar,ending in a 9" single becket block.A 9" single block is tied to the starboard knighthead and the blocks are connected as in step 43 above.
My photobucket
JohnReid
Post by JohnReid »
Step 45
Flying Martingale
Long P227
Hack P67
4" rope tied to flying jib boom at the same point as the flying jib stay,through the third highest sheave of dolphin striker,through the starboard side of bowsprit collar,ending in a 9" single becket block.A 9" single block is tied to the starboard knighthead,and the blocks connected as in step 44 above.
My photobucket
JohnReid
Post by JohnReid »
__________________________________________________ ____
Formula To Find The Circumference Of Any Rope At Any Scale.
1/TPI X 22/7 X scale =rope circumference.
Using a dowel mark off 1" in length.Take the rope that you want to find the circumference of and wrap the dowel with the string,thread or whatever you are using.Then count the number of turns it takes to cover the 1" length already marked on the dowel and that is the TPI(Turns per inch).Multiply that number by 22 over 7 and then multiply that by the scale that you are working with and that will give you the circumference of the rope as it exists in real life.
Example: 1 over 24(TPI) multiplied by 22 over 7 multiplied by the scale of your ship 78=10.2"(approx) circumference .
My photobucket
JohnReid
Post by JohnReid »
Step 46
Fore Royal Stay
Long P224
Hack P67
3" rope from truck of the fore royal mast,through the notched tip of the flying jib boom,through the lowest hole of the dolphin striker,through the port side of the bowsprit collar,ending in a 9" single becket block.A 9" single block is tied to the port knighthead ,and the blocks are connected as in stage above.
My photobucket
JohnReid
Post by JohnReid »
My photobucket
JohnReid
Post by JohnReid »
Step 47
Jib Traveler Outhauler
Note: this is actually part of the running rigging and a biege colored rope should be used. Installing it now is a good idea because it will be too hard to work on later.
Tie a 12" single becket block to the eyebolt on the front face of the bowsprit cap.Tie a 3 1/2" biege rope to the jib traveler above the boom,lead it forward and down through the sheave in the neck of the jib boom,and back towards the bowsprit cap,tying a 12" double block in its end.Connect the blocks with 3" beige rope in a luff tackle,and tie off the fall .
Long P234
Hack P68.
My photobucket
JohnReid
Post by JohnReid »
My photobucket
JohnReid
Post by JohnReid »
The last pic shows a typical yard with its horses (footropes),its stirrups supporting them and its flemish horses of single loops of rope under the yardarms.These are better installed before the yards are fitted to the mast,but care must be taken to make them fit so that they hang below the yard when they are in place.The horses sag below all yards,their inner ends crossing each other and tied off around the yardarm beyond the yards center point.Stirrups are evenly spaced along the yard.Flemish horses are tied around eyebolts screwed into the tips of the yards.
My photobucket
JohnReid
Post by JohnReid »
Bowsprit Horses Step 36
My photobucket
JohnReid
Post by JohnReid »
I am a 3D guy and not much of an illustrator and this is my first attempt at an illustration. I worked it up in photoshop as a test for future illustrations.There are areas on my Victory that I just cannot reach properly with my camera so I think that a few drawings are in order.
The one above is of the starboard side of the bowsprit looking down.
My photobucket
JIM BAUMANN
Post by JIM BAUMANN »
>>> ......not much of an illustrator....<<<
Looks pretty clear to me! :thumbs_up_1: :thumbs_up_1:
Jim Baumann
JohnReid
Post by JohnReid »
The white caulk on the blackboard look is quite effective in that no one really expects to see a work of art using this medium.It gives it more of a instructional look as you would find in a school type setting.I think that I will stick with the idea.
My photobucket
JohnReid
Post by JohnReid »
My photobucket
JohnReid
Post by JohnReid »
Yard-- Horses-- Stirrups-- Flemish Horses--
__________________________________________________ __________________
Sprit topsail 3" - -
Spritsail 4" 3/3" 4"
Fore 5 1/2" 4/4" -
Foretopsail 4" 3/3" 3"
Foretopgallant 3" - -
Main 5 1/2" 4/4" -
Maintopsail 4 1/2" 3/3" 3"
Maintopgallant 3" - -
Crossjack 4 1/2" 3/3" -
Mizzentopsail 3" 2/2 1/2" 3"
Mizzentopgallant 2" - -
Driver boom 3" - -
My photobucket
JohnReid
Post by JohnReid »
Well that is not quite the chart that I expected,mine was all in neat rows!
Anyway, to read the chart from port to starboard it goes like this:
Name of yard-Horses ,rope size-Stirrups,each side-Stirrups, rope size-Flemish H
A dash on the chart means"not required."
My photobucket
JohnReid
Post by JohnReid »
My photobucket
