1/72 USS Conyngham DDG-17
desron48
Re: 1/72 USS Conyngham DDG-17
Post by desron48 »
on facebook you told me you are a NOVICE.....sence when???...i'm not buying that....this build :thumbs_up_1: is incredable.....
Post by Dave Wooley »
Your problem solving methodology and craftmanship have made the SPG 51s little gems. Great Job , and you are a Novice , :whistle:
ccain
Post by ccain »
desron48 wrote:on facebook you told me you are a NOVICE.....sence when???...i'm not buying that....this build :thumbs_up_1: is incredable.....
Dave Wooley wrote:Your problem solving methodology and craftmanship have made the SPG 51s little gems. Great Job , and you are a Novice , :whistle:
Fellas... I can't begin to express my gratitude. Anything and everything you see me do is a direct result of studying the fine craftsmanship I've witnessed and examined on this forum. Well, that and the fact that I have a lot of time on my hands. :big_grin: My Grandfather used to tell me "Boy... If another human has done it, you can too. Never limit yourself nor convince yourself that you can't do something. You can do ANYTHING you set your mind to" Aside from his work ethic, this is one of the greatest gifts he ever gave me. He also instilled in me that you can do great things with very little. I've never been afraid to try anything. Of course I DO limit myself... I'm not saying I couldn't do it, but I think brain surgery and landing large aircraft are best left to someone else. :heh:
Well, on to today's progress. I worked on the MK68 GFCS. There wasn't much to go on on the internet so I just took a stab at it. The front looks off to me so I will be going over it again.
I also blew a little paint their way.
On a related side note:
I got these glue dots from Wal-Mart.
This stuff is great for holding down light weight parts while painting. Have you ever pried off those magnets from a new phone book? You know the glue on them that stretches and looks kinda like a booger? Same stuff.
Since the surface area of wood and styrene are very different. If you apply the glue dot to the styrene then affix it to birch plywood, the glue dot will release from the plywood easily when you're ready to move it. It will still hold the part firmly enough to turn it all around in order to get paint where you need it. When the paint is dry, you just lift gently then peel the glue dot off the part. It comes off in one complete stretchy, sticky ball.
She's starting to come together...
Neptune
Post by Neptune »
Looking great! And very fast construction too! I can see you have a lot of time at your hands. Still, I have a lot of time on my hands too, but somehow I'm always in a hurry! :big_grin:
Keep it going, those radars are a nice combination of wood and styrene!
The merchant shipyard
ccain
Post by ccain »
Neptune wrote:Looking great! And very fast construction too! I can see you have a lot of time at your hands. Still, I have a lot of time on my hands too, but somehow I'm always in a hurry! :big_grin:
Thank you!
Here's today's progress:
Sometimes you find inspiration in the weirdest places. My ear ring clasp ships bell. :heh:
It became painfully apparent today as I was looking at pics of the real Conyngham I still have lots of stuff to do. I would estimate that, at this point, I'm not even half way there.
desron48
Post by desron48 »
yea just when you .....think.....your done....look again....doh.... :heh: ...build looks better every day.... :thumbs_up_1:
ccain
Post by ccain »
OK... So I'm openly admitting to taking a shortcut on the railings. Sorry gang.
I found this screening at the hardware store and it measures 1/2" square. I thought about it and figured that 1/2" = 3 scale feet. Pretty close for railings. I bought it ($6), came home, made a jig to solder in a middle rail.
It's all straight and is easy to bend. I purposely left a bottom rail on it to make it easier to glue down and to give me a nice edge to cut when painting the decks. I know it's probably not most peoples cup-o-tea but it works for me.
In it's unpainted form it looks rather flashy. I tested it on the refueling at sea king post and once painted it looks pretty dang good if I do say so myself.
Cliffy B
Post by Cliffy B »
I believe that's called "chicken wire" and you can get it in various sizes. It definitely looks the part! Don't feel bad about taking a shortcut so to speak. If it saves you time and/or money and looks good then its A OK! :thumbs_up_1: She's shaping up nicely, keep up the good work.
desron48
Post by desron48 »
Cliffy B wrote:I believe that's called "chicken wire" and you can get it in various sizes. It definitely looks the part! Don't feel bad about taking a shortcut so to speak. If it saves you time and/or money and looks good then its A OK! :thumbs_up_1: She's shaping up nicely, keep up the good work.
in the construction industry it's also known as HARDWARE CLOTH.... :wave_1:
RAILING DOES LOOK GOOD CHRIS.... :thumbs_up_1:
navydavesof
Post by navydavesof »
I really, really like your SPG-51s and your torpedo tubes. The pictures are just great. We can really see the extra detail you put into them! I cannot wait to see more!
ccain
Post by ccain »
Thanks guys!
I don't know why but today I took a break from the railings to build a couple of searchlights.
ccain
Post by ccain »
They don't look too terribly bad with primer on them. I had to tack down the loose wire you see in light number 1.
Hi ccain Those search lights are little gems. How did you make them .
ccain
Post by ccain »
Dave Wooley wrote:Hi ccain Those search lights are little gems. How did you make them .
Thanks Dave!
Well, I started with the lenses. By accident some time ago, I happened on a way of putting a nice raised edge on a round part by heating a piece of brass tube with a torch then pressing it through the sheet styrene. The heat from the tube gives you a really nice and consistent raised edge on not only the part but the blank you cut it from. So, I used that technique to make the lenses.
Using a detail pic of the lights I found on line, I went from there using styrene tube, sheet styrene and brass wire.
ccain
Post by ccain »
I built the smaller search / signal lights today and painted the railings.
desron48
Post by desron48 »
have you started the INNER WORKING yet???....or will it be a static model??...all in all...looking great..... :thumbs_up_1:
ccain
Post by ccain »
desron48 wrote:have you started the INNER WORKING yet???....or will it be a static model??...all in all...looking great..... :thumbs_up_1:
Hey Joe...
I've got the prop shafts in and spinning free and my props should be here in a week or two. I've got the rudder linkages all finished and working well. I'm saving up for motors and electrics and stuff. But that's gonna be down the road just a little bit. I know I'm kinda going backwards from most on this build but what the heck. We'll get there.
ccain
Post by ccain »
A little more detail today. Painted the mast and tops of the funnels.
Hi ccain Looking good thanks for keeping us updated.
Garry71
Post by Garry71 »
Ccain, very good and very interesting!
I want skratchbuild model of Adams-class destroyer too (but 1:200 scale) (after finished USS Heermann).
Nice lessons in your topic for Me!
Thanks!
