To HMS Victory and beyond
dafi
Re: To HMS Victory and beyond
Post by dafi »
And as a small X-Mess story I still prepared a three curse menu, if you still have the time ...
Once upon a time, when young dafi still was young and in the youth of his years, he sat enchantetly in front of his beloved thick book, showing drawings of McKay of the lovingly crafted anchor gear of his big love, the sweet little Vic. As much as dafi treasures the work of this author, this far day he realised some small strange things in the drawings: Why can those heavy cables, the anchor and the messenger be braced hip-high all along the way without sag? How can those rollers in the bows bear the pull, their construction is clearly not for pulling? How can this thin manger board stand the strain of the heavy cables rubbing over it as usually shown?
Thrown out of his dream, little dafi opended his eyes and started looking more closely ...
... and this is where the odyssey began ...
These points can be seen on this beautifully build model of this system, exactely as the book says .
http://nautarch.tamu.edu/model/report2/
Small Interlude
I think some 4 years or more passed ever since and perhaps that is the reason, why the lower gun deck took some more time than planned :-)
The odyssey took me through lots of literature and original sources like drawings and plans. I fastily realised, that the side of the cable running back to the bows is very loose, plenty of sources show this. The French even use an similar system without the 2 rollers. Also the way a viol worked helped to understand.
Next step was to understand the different functions. The trials with the anchor cable laid out to be thrown was shown already. This lead to the conclusion, that the manger boards were most possibly removed for that.
Also riding the anchor was easily understood, the system with the different stoppers was clear, also if the details were sometimes a bit tricky.
So the messenger itself was left. I already realised earlier, that the cable laid messenger on the Vic in P. was replaced by one of identical twist (one counter twist omitted in production) of the same diameter.
http://modelshipworld.com/phpBB2/viewto ... 754#310754
Amicalement, Chef de la Cousine, dafi
To Victory and beyond ...
dafi
Post by dafi »
Aperitif
... so first a new messenger was done and there came the next question: which way was the messenger worked? Always from the bottom to the top or always clockwise because of the lay of the cable?
So Jack, Ben und Phil were pushed away from the old capstan, this one was made turnable, the messenger was wound 4 times round, some weight put onto the cables to simulate load and the capstan was worked.
The frictional connection worked extremely well on the model, I did not manage to make it loose grip, neither with little or with heavy load. The pile of turns nicely slid upwards, giving space on the bottom. The other way round - cable coming in on the top and leaving on the bottom - did not work as expected. (picture still with an old cable-laid cable)
As the messenger is endless, it is linked by 2 eye splices with a lashing. Curious as I am, I wanted to see what happens if this big fat end comes to the capstan - it looks less dramatically than expected :-)
And here comes the big topic, the side that runs back too the bows. On the Vic in P. it is shown on the floor, most models show the same. This for sure is the basic idea. But early in the research i found the drawing of 1815, showing hanging rollers.
Many contemporary drawings show cables lashed up to the ceiling, the AOTS of Bellona 1760 and Diana 1794 show the same system of rollers as seen on the drawing.
So great happiness as I found a uncommon feature to put to discussion.
First tests proved successful
*jumpingofjoy*
*runningbacktokitchen*
dafi
Post by dafi »
First Course
... and if you think things are now sorted, you could be wrong ...
... first a threat was streched to get an idea of the way the messenger takes. Bows rather easy, the capstan too, but the pump ensemble appeared intresting ...
... if the messenger is on the floor, it is underneath the dales and could get stuck in the sharp corner of the stanchion, if it is put on the roller of the stanchion, it hangs in the front of the chain pumps�cisterns, if it is lead from the stanchion�s roller to a hanging roller it interferes with the elmtree pump. Only if it is guided by a roller abreast and aback the pumps it can move freely ...
... what was to be proved easily by a test messenger.
So distributed the hanging messengers by means of a tape on the stand and doing the count of the deckbeams ...
... and drilling the holes ...
... which resulted in another of my funny operations deep inside the intestines of my Vic.
Then taking out the thread, putting in the real messenger ...
... adjusted the length, and taking out the whole thing again to build up the second eye spice ...
... and putting everything in again, sometimes using the heavy duty special devices ...
... just to end up with the fun and honnor to have to do the lashing all down in there :-)
But sometimes two hair clamps work wonders :-)!
Afterwards Dr dafi still had to remove the stitches ...
*andrunnighastilybacktothekitchen*
dafi
Post by dafi »
Second Course
Next curse is about the nippers ...
... here shown the newer version, a long rope, that links the anchor cable with the messenger. The older version is shorter with a small plate on the end, but apparently more difficult to unlock.
The system is simple: 3 turns around the messenger, three around both cables, there around the anchor cable. There were more complicated versions, but I hope, this one will do. The ends are not knotted, so I believe the end was to be stretched by a hand. This is why my little shipyard worker was helping out - What a smart nipper he is :-)
And here are the details: The messenger is pulled on the starbord side and running back on larboard.
At the bows the messenger is running loosely around the rollers ...
... and will be nipped straight after the manger.
Both cables run over the horizontal parts of the riding bits.
On larboard the eye splices are to be seen, then it goes just straight ...
... before the nipping is taken off for the anchor cable to disappear in the orlop deck. The starboard cable is stored on the port side and vica versa for handling reasons.
Of course the grating should still be taken down, but unfortunately it was glued in to professionally in my dim and distant past ...
The messenger still has to finish its turn round the pumps, on starboard over the stanchion�s roller ...
... and finally running round the capstan to proceed bowwards.
And if you have a close look, you will discover our mysterious Mr. Thor swinging his mighty hammer :-)
His duty was to make shure, that the incoming cable does not jump over the turn lying above it. And we see Jack, Ben und Phil pulling free the outgoing cable.
Here a overview from the back, one can see the space above the elmtree pumps ...
... also interesting the turns the cables take on the pulled side, both horizontally and vertically ...
... and from the front.
...hihihihihihi...
dafi
Post by dafi »
Third Course
To end something less heavy to digest, just some details ...
What a nice back ...
...hihihihihihi...
dafi
Post by dafi »
Dessert
And as icing on the cherry :-)
I wish you a good night and a good digestion, also we hope you liked Mr Thor and his mighty hammer :-)
Daniel
JIM BAUMANN
Post by JIM BAUMANN »
brilliant..... :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
INSANE- but brilliant!!
>>>>>>>>>>> His duty was to make shure, that the incoming cable does not jump over the turn lying above it. <<<<
well observed.... a riding turn even on a small sailboat winch is quite a disaster-- leave alone a heavy cable....
all in all ..... you are probabaly barking mad.... :big_grin: :cool_2:
-- but truly excellent!!
Hochachtunsvoll ( admiringly )
JB
angeleyes
Post by angeleyes »
That is funny.I was on Ebay the other day trying to make my mind up if i wanted to get myself into building one of these monsters (Either L.SRoyal or HMS Victory in 1/100) but sanity prevail in the end and i bought a smaller 1/185 HMS Victory by Airfix.That will be my first go at a sailing ship, and although am fascinated by all the rigging that goes on, i must confess i have no clue whatsoever of what goes were and for what purpose.I want to build one in heavy seas , smashing its way through and perhaps even firing a few cannons , so i want a lot of action, but also as much detail i can add .I know these kits are rather old, and specially in the smaller scales a lot can be replaced , so your built and this thread will be invaluable help to me .Eventually i will get one of these monsters as i reckon despite the amount of work they require , they are still excellent value for money , and with some extra work they can be a great addition in in any collection.
LE BOSCO
Post by LE BOSCO »
Hello Daniel
I repeats, this is always so wonderful precision :thumbs_up_1: this model of victory ( except for the real :smallsmile: ) is the most complete that I know
congrats daniel
Nicolas
dafi
Post by dafi »
Question:
How can one manage to make the best of all wives get cold sweat, panic and feel big discomfort in just a second?
Very easy, just leave "by mistake" all three hulls lying on the table ;-)
But one has to admit: it�s looking great !!!
Greetings, Daniel
dafi
Post by dafi »
Wormsigns ...
... here we go again. Where too? Next picture makes it clear :-)
Then dressing them nicely for sacrifice on an old Inca pyramid with several high steps and silicon over it.
Because of the steps, I do not need an extra fence for the casting, in goes a batten in the middle for the anchor shaft and the resin goes over it ...
... and then cursing over ones own stupidity, too much resin and who wants to rework that abundance of material overflow?!?
So back to start, this time less resin and immediately one sheet into each half to press the excess material to the side ...
... and parts were perfect to be taken out by the help of a cutter blade only :-)
Then took an evergreen batten, painted red and did the chamfer with sight control flight ...
... which worked very easily. Then still the arms and throat glued in and positioned the points ...
... as they were guide for thinning the arms. Still glued in the blades ...
... and a nice anchor comes out :-)
In brown the original Heller one, too round, a much later shape ...
Then fenced a small playground, positioned the anchor on three needle tops in the right height ...
... and filled with silicon.
Then used the spay silicon and soaked the first half of the form and even put Vaseline into the corners for that the second half of the form does not form one solid block with the first half - guess how I found out ...
Then filled with resin ...
... and out came ...
... lot of bubbles. Ok, mixed some drops of resin, put back the parts in the form, the resin onto the right places and closed the form - and magically the parts were repaired :-)
By now I learnsd the waffle-cooker method, by first putting the resin in both halves and wait until it starts getting thik and just then to close the form. Works wonders and much better results :-)
Then cleaning up a little, painting, dry brushing and here we have a sweet little set of anchors. Looks like tailor made ;-)
On the last picture one can nicely see the gap in between the two halves of the stocks. By the conical form the stock rings can easily be pushed towards the middle, thus closing the gap and refastening the shaft :-)
Kenavo, Daniel
JIM BAUMANN
very very brilliant indeed!!!
sooooo much thought and pain doe the anchors....
>>>> How can one manage to make the best of all wives get cold sweat, panic and feel big discomfort in just a second? <<<
that is very very funny!!!!!
Your ( our !!!!! ) poor wives.....
JIM BAUMANN
JIM BAUMANN
Ahoi Dafi
have you seen this...?
viewtopic.php?f=16&t=146162
Do contact Robin--he is a really good guy!
maybe you can assist each other?
Rgds
JB
Channell
Post by Channell »
Daniel, I was looking at all the Caldercraft/Jotika Victory model builds on the "other site" and your once humble Heller plastic kit blows them all away. Don't tell 'em I said that! :big_grin:
-Jason Channell
Bill Code
Post by Bill Code »
This is the most impressive build of this model Ive ever seen! I really love the figures that you have made. Are they made from milliput ?? like to see how you make them. I will have to use a few of your techniques on my far humbler build.. Carry on good sir!
dafi
Post by dafi »
Thank you Sirs!
As the stream, the kedge and one for my little Mistery were still on the way and I took the chance to make a better documentation ...
First printing the plan in the right size, taking double sided Scotch tape to fix some Evergreen in the right position, and flood the joints with CA ...
... took it out and glued the reverse too. As the arms grow thinner, I glued a thinner material on the tip as guide:
Then files carefully the whole area in between the shaft and the tip ...
... until the small step to the thinner tip disappeared. Then turned the anchor to do the other side, and as it was not lying flat any more I supported the hanging arm by some sheet.
Here from a different perspective:
before ...
... and after.
Then for the bent of the arms I colored the surface with Edding ...
... and one can nicely see what is done and what still has to be done.
It helps to work on a thin Plexi, as one can use the sides as guide for the file.
Then comes the throat, the area in beween the shaft and the arms. At those days it was rather small, later versions of anchors accumulated much more material on this spot.
The filing itself is easy...
... just getting both sides equal is needs a careful approach.
Colored the shaft and the arms for the chamfers ...
... drilled the hole for the ring and most was done.
Used my small template to cut the palms ...
...glued in place, cut ...
... cleaned up and done :-)
And here the family shot with all the needed tools that were needed for conception.
All the best, Daniel
KevinW
Post by KevinW »
Hello
An amazing piece of work and I'm sure I'll be referring back to these photos again and again as I undertake my own journey of building the victory. Though not to this level, I doubt I'd have the patience. I'm right at the very beginning, still trying to make sense of the terrible Heller instructions while still amazed at the quality of the mouldings.
Anyway - within these pages there's a link to Pete Coleman's victory site, which also looks like a mine of information, but the registration function doesn't seem to work properly. Does anyone know how I can successfully register, or get a message to Pete?
dafi
Post by dafi »
Hello Kevin,
thank you for your kind works and good luck with your own build. The Heller instructions are a good help to identify the parts, the rest is better to be researched ...
The rest see my PM.
Greetings, Daniel
dafi
Post by dafi »
Of course, it had to come ...
... of course, I admit, I made it easier by using just one single strand to serve the anchor�s ring and not the multitude as in the original ...
... of course, this was already tricky enough to me ...
... of course, I had no idea how to do other wise ...
... and of course someone was moaning ...
... and of course, the challenge was accepted!
Once I used my thinking equipment ...
... and of course I used first 4 strands to serve ...
... but the difference was not to visible, so I tried 8 of them ...
... and of course looks much more authentic :-)
Then bent the served wire around a core ...
... and here we are, on the left side the new one :-)
...hihihihihihi...
Challenge won!!!
Of course the seizings are badly done as I did take the wrong rope and it was already late, but the next ones, just wait!!!
Mission accomplished :-)
And now to the other rings ...
... underneath the eyes as these things cost sleep ...
... of course ...
XXXDAn
LE BOSCO
Post by LE BOSCO »
Hello Dan
as always, a work of more accurate,and research to implement techniques and materials, none obstacles you resists :-)
superb!
Nicolas
