1/144 Kiev by Dave Wooley
doog_k
Re: 1/144 Kiev by Dave Wooley
Post by doog_k »
Are all the paints from WEM Dave?
On the Slips:
1/144th Stand-off scale:
IJN Nisshin
HMAS Albatross
Keels laid: IJN Tone
Frames laid 1/25: DDR KleineSchnellBoot
http://www.edinburghmodelboatclub.org.uk
https://www.facebook.com/pages/Edinburg ... 2565540179
Post by Dave Wooley »
doog_k wrote:Are all the paints from WEM Dave?
Hi Doog All except the yellow stripe,
Dave Wooley :wave_1:
russclark wrote:i know how you feel,masking tape make me sweat to .the deck looks very crisp and clean,nice job :thumbs_up_1:
Thanks Russ Forming the roundels will be the tricky bit. :thinking:
Dave Wiikey
GTDEATH13
Post by GTDEATH13 »
This is ... I cant describe... So many praises have been posted so I will just say I agree with what has been previously posted. :thumbs_up_1: :thumbs_up_1:
Questions:
What are the criteria for deciding to make a surface or part detachable from the main model?
Will the detachable surfaces be qlued or firmly attached to the model in any way?
Do you make preliminary sketches of your model so as to figure out the difficult-tricky parts or analyse a model of smaller scale in order to clarify the difficulties of the build-paintjob?
Early in the build you were discussing about the tiled surface of the flight deck. Do you intend to incorporate such an effect in any way?
What kind of masking tape are you using?
Thanks a lot, Nikos
:wave_1: :wave_1:
NIKOS (NICK)
Hi Nikos
Thanks Nikos To answer your questions .
The Criteria that determines how much of the deck is going to be removable is two fold 1/access for batteries . 2/ The other criteria ,is one of disguising the CUT in the deck . This was done by working out where the white stripe falls on the flight deck { this will be explained in the detail relating to the preparation for painting this stripe. }
The detachable surface is just that and will not be fix other than slotted onto bearers below deck .
I do make sketches of every part I build to see if the construction sequence will work{ Oh to be proficient in CAD}
The paint scheme and how to sequence that is decided on about half way through the build .
As for the tiled deck { my thanks to Ingura for all his help and assistance on this} I decided that it might not work the way I envisaged it { the sample deck surface was superb but there was other considerations } and I tend to apply the old adage when in doubt don�t . Perhaps in hindsight this might have been the wrong decision but I�ll live with it.
The masking tape is Tamiya low tack , It is an excellent product .
Thanks Nikos for your questions and your kind comments
:thumbs_up_1: :wave_1:
SweeperSkipper
Post by SweeperSkipper »
WOW Very clean looking Model Dave. Well Done. Looks Fantastic on the Water. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Jesus Christ and General Jackson, this is the hottest potato they've handed me yet!
(Bull Halsey)
1/48 Benhan Class DD
1/48 ATF
1/48 DE
1/48 Gearing class DD
1/48 AM Minesweeper (Dry Docked)
1/24 AM Minesweeper (In for Refit)
SweeperSkipper wrote:WOW Very clean looking Model Dave. Well Done. Looks Fantastic on the Water. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Thanks Sweeper Skipper for your interest. and kind comments :thumbs_up_1: :smallsmile:
To continue the spacer is used through out the entire length of the white strip.
This photos should give some idea of what the strip looks like on the full size vessel.
The next step is to BLANK OUT the sections that are NOT painted . But they
need to be measured accurately. For this a simple jig that can be moved along
the length of the white strip.
The spacing between the blanks is also critical .
The end result
This side of the preparation is complete ..
Next the outer port deck stripe has to be masked off. Once again simple spacers
to ensure the gap remains constant.
More than one spacer is used .
Dave Wooley more to follow :wave_1:
ARH
Post by ARH »
Dave , Thats not good.
Its very, very, very GOOD, love the work your putting in to the model. :woo_hoo: :woo_hoo: :wave_1: :wave_1:
Simple but effective.
Hi Ron Thanks for your kind comments always appriciated from the master . It seems to take for ever . Question Do you know if the likes of this low tack tape comes in sheets . The idea being I can form the Helo roundels if I had large enough sheet. Does any one know if such a material exists???? I can of course buy them in but I would like the challenge of DIY before I go down that road .
Dave Wooley :scratch:
johnny canuck
Post by johnny canuck »
Dave,
There is a product called Frisket which is a low tack vinyl film that can be cut for stencils. I have used it to mask my USS Enterprise (starship) model to create the Aztec pattern. It is reusable so the masks can be moved from spot to spot. I have a roll but I know that my local art store does sell sheets. I have searched UK suppliers and found this one:
http://www.londongraphics.co.uk/acatalo ... _Film.html This in rolls but if you search other UK art shops they may have just single sheets.
Hope this helps.
James W.
Dry docked:
1/72 HMCS Assiniboine DDE 234-1960
1/72 HMCS Ottawa DDE 229-1960
1/72 HMCS St. Catharines-River Class Frigate-1944
On the slipway:
1/72 HMCS Camrose-Flower Class Corvette-1943
1/72 HMCS Trillium-Flower Class Corvette-1942
Thank you James this is just what is needed. Much appriciated ,superb :woo_hoo: :woo_hoo: :woo_hoo:
Capit�o Norbert
Post by Capit�o Norbert »
Nice technics to paint.
i use a bit of baby powder to contain the strong glue in some masks.
the powder broke the strong glue in some masks marks and you can control better too.
but need use little powder and spread it in the part of mask you using.. :thumbs_up_1:
nice work on model
J. Soca
Post by J. Soca »
Tha is simply superb !! :thumbs_up_1: :thumbs_up_1:
Jose
On completion of masking off the inner edge of the flight deck the forward end
is also masked off.
Along the outer edge of the flight deck masking follows a different pattern. Here
there will be a series of white squares which connect to the white inner stripe.
Once again a simple spacer was used .
As there is a gap between the deck edge and an inner rail masking tape had
to fit tight over the rail to avoid paint creep. The process by
which this is done is shown in this shot.
The edge overlapping the rail is scored at deck level .
The excess is very carefully removed
Masking complete
Once again the hull was prepared for spraying .
Spraying takes minutes masking takes a lot longer but the job gets done.
Is the effort worth it find out next time
ARH
Post by ARH »
Dave, Lovely job, I will have to wait, going away for a long week end to our friends in Cambridge, keep up the good work. :thumbs_up_1: :thumbs_up_1: :wave_1: :wave_1:
Thanks Ron have a good break weather looks favorable for you .
It worked ! One of the aims was to try to ensure that the joint that will provide
access into the hull along part of the length of the flight deck remained hidden
and it worked :woo_hoo: :woo_hoo:
Back into the work shop for the next phase.
First you make a jig!?
Dave Wooley see what this is for next time , more to come :wave_1: :wave_1:
Bill Waldorf
Waldorf Productions
Waldorf Productions
Post by Bill Waldorf »
Well, you have done it again ....... Another great build coming together. You gotta feel good about that. The attention to detail and clean work is what I most admire. Can't wait to see those a/c and figures!! Update on BB58 coming soon. Outstanding job as usual, Mr. Wooley. We can all look up to your craftsmanship. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
Hi Bill Aways good to hear from you and thanks for your kind comments much appriciated. Also I was waiting for those few words "up date of BB 58 coming soon" I for one truly look forward to your up dates and get withdrawal symptoms if they are not there. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
