1/144 Kiev by Dave Wooley
- Bill Waldorf
- Waldorf Productions
Re: 1/144 Kiev by Dave Wooley
Thanks for the reply Dave. I too will give the Indiana that "commisioned look". Nothing wrong with that. Weathering can be very time consuming and is easily overdone. I like the "clean look' as far as a full hull model is concerned. When one gets into waterline thats a different story................
Leviathan
Hello Dave,
In the case of your Kiev and in my opinion, a weathering would conceal the precision of your wonderful work. There are so many details which shouldn't be covered. Anyway, I also prefer the "commissioning look", especially on modern warships.
Kind regards
Kind regards
- roy allen
Dave, although i'm a self professed weathering nut, to weather such a huge model is a project in it's own right.
So i think you are wise to give it a wide berth.
As always a pleasure to see your work
Roy
Roy
- Dave Wooley
Hi Roy good to hear from you. I must admit when I see the likes of yourself, comfortable and relishing the prospect of weathering your models , I'm clearly amazed at the results achieved which bowls me over { Jim Baumann I�m always watching } . Perhaps it is more difficult weathering large model either static or working, as Bill has quite rightly pointed out it's easy to over do it and perhaps spoil the model. It has been said to me on a number of occasions that there is no such thing as a "pristine" warship. Perhaps to cover up my own limitation or just to prove the opposite is true I always aim to build the model as commissioned. To be fair I have only ever seen one really authentic, large scale and effectively weathered carrier model and that is Ted Parr's fabulous 1:144 Nimitz . I think for what it's worth, to weather is to go above and beyond just an acquired skill, it is an art form and this site proves it. It would be interesting to get more feed back on this subject?roy allen wrote:Dave, although i'm a self professed weathering nut, to weather such a huge model is a project in it's own right.
As always a pleasure to see your work![]()
Roy
- Dave Wooley
Just to refresh the memory this is Ted Parr's Nimitz
- roy allen
I weather using pastels, which are ok for static models.
I intend to do a photo shoot sometime in the future for the SIG website.
But as your models are working, the use of pastels is a no no.
this means your going to have to use oils.
I use oils mainly for figure painting these days, but used as a wash on larger subjects the results can be awesome.
If you want to have a go, the best way is to use a test subject.
Get hold of an old plastic kit in 1/72, charity shops are good places to look.
Build and paint it up, then you can practice over and over. if after a while the boat gets to messy just cover with more paint and start from fresh.
One tip, use the best turpentine you can get, not the cheap stuff from the local DIY
Windsor & Newton paints are very good quality. As for colours, sienna, umber, burnt umber, lamp black and white will be all you'll need.
Then we have the option of dry brushing.
When i do this, i take a cocktail stick and lift out the thick pigments that settle at the base of the tin over time
and use that, not the runny stuff.
I also have an artist's lint free cloth that i use to remove the paint from the brush before applying.
My brushes have badger hair and are old, but the new types of brush are superb, for your scales use a chisel type.
Any good art shop will help out.
Roy
Roy
- Dave Wooley
Hi Roy thanks for the information and advice. Looking at all the photos I picked
out one that is the ultimate in weathering for poor old Kiev before the vessel
was spruced up for sale to China as an amusement park . I know this is certainly
not typical even rather extreme but it does give some idea on how and were
the weathering forms on a vessel such as this. Other photos taken during the
life of the vessel show little of this sort of rather cruel "left to rot� situation. How
you personally would approach this in model form is part of the mystery,
{ for me anyway} especially in achieving realistic weathering that is not over done.
A definite first time for me is adding figures. These Preiser 1:144 are ideal being
German Air force. The only problem is I have no idea were to start. What to
paint first, clothing, face and what type of paint would be best suited to the job.
I�m not going to get away spray painting these!!!! I have about 35, enough for
deck crew? Also I have looked closely at the figures used by Bill Waldorf on his
Santee, they are good and that�s what I would like to achieve. Although I am a
little way off before I need to start adding figures , I would like to be prepared if not
skilled up for the job!!!
Dave Wooley:
Dave Wooley:
boatman
HI DAVE your model just keeps on getting better an better i am really enjoying whatching this build an now with figures it will really bring it to life an its makin me want to get back to my nimitz build more than ever yours is a brilliant model
chris
chris
- Dave Wooley
Thank you Chris for your kind comments .Your own ability in the effective use of figures on warship models certainly inspires me to press on but I have much to learn.
- roy allen
Hi Dave,
it's a shame the figures are attached by the heads and not the feet.
So first thing is to remove and clean up each one, then mount onto a work bar with a tiny drop of CA.
The bar can be made from scrap plasti strip, with say two figures per bar.
This is then attached to a round handle grip. you can make one using an old wooden broom handle
or use the handle from a razor saw.
Use your normal under coat to cover the figures.
then paint the flesh tones in, the eyes can be done using a cocktail stick.
As the figures are 1/144 dont bother with dark tones when doing the uniforms.
Just stick with the main colour plus the high light tone
So lets say one figure has a dark grey tunic , then the high light tone which will need to be dry brushed
on is light grey.
What ever you do, don't use white as a high light instead use a tiny , tiny amount of yellow.
Standard enamels are fine for this or you could use the Valejo range of acrylics
If you are attending Telford this year. i'll be at the finewaterline sig table where we can go over this
in more detail if you wish.
Roy
on is light grey.
Roy
- Dave Wooley
Roy you are a gent that's a magic suggestion . This is the first time I have attempted to put figures into a model so any help from the "experts" will be greatly appreciated . There are so many question and having a chat will really help, perhaps helping me avoid the most obvious of mistakes. thanks
- tintin
Hi Dave ,this thread is a real eyefest.This is also my chosen scale and its great to see what can be acheived.The step by step posts are a great idea to teach us lesser mortals the fine arts,and I thank you for that.
One question I would like to ask is if you can recall where you got your photo etched rails?
Thanks again
John
Thanks again
John
tweety777
Hi Dave,
What a beautiful model is this!!!!!!
I'm going to follow this threat!
Greetings Josse
Greetings Josse
Making a complete new Well Enhancer, again scale 1:75.
- roy allen
See you at Telford then Dave
Is it Saturday your coming
Roy
Roy
- Dave Wooley
Hi John My rails are sourced from Gordon Brooks on gordon@tinworthrestoration.ndo.co.uk and thanks for your kind comments .tintin wrote:Hi Dave ,this thread is a real eyefest.This is also my chosen scale and its great to see what can be acheived.The step by step posts are a great idea to teach us lesser mortals the fine arts,and I thank you for that.
Thanks again
John
- Dave Wooley
Josse thank you for your kind comments . It's been a long but enjoyable project.tweety777 wrote:Hi Dave,
Greetings Josse
- Dave Wooley
Hi Roy It will be early Sunday morning . Usually we would attend on the Saturday but this time I'm going over to the International Model Boat show at Warwick , which I haven't been to for some time , then over to Telford . Two FULL days of models .I'll be the equivalent of punch drunk or would that be model drunk by Sunday evening . I'll of course be looking forward to seeing familiar faces and I'll be looking forward to some expert and valuable advice from your good self.roy allen wrote:See you at Telford then Dave![]()
Roy
- doog_k
The weathering discussion is interesting, I've found some useful materials recently, both for static and working RC ships. As Dave knows I tend to work in stand-off 1/144th and have been thinking about how best to weather for many years, I still haven't learned the art yet but I've found that a combination of Games Workshop acrylic washes and good old fashioned semi-dried out enamels help to lift details. My late war version of USS Wolverine should be an interesting challenge! BUT, not overdoing it is key, I always err on the side of caution.
That Nimitz is breathtaking, but I think Kiev will give her a run for money, will she come up to Glasgow for the Warship weekend next year?
On the subject of figures I concur with Roy, take them off the sprue and put them on some sort of temporary base - I use scrap balsa as it's easy to break them back off the material when complete, I tend to spray them with a mist of halford's primer and then paint the flesh white and then humbrol's flesh colour. That way, at least in largest scales you paint around the eyes, you don't have to paint 'em in afterwards. At 1/1444th eyes may be a moot point
On the Slips:
1/144th Stand-off scale:
IJN Nisshin
HMAS Albatross
Keels laid: IJN Tone
Frames laid 1/25: DDR KleineSchnellBoot
http://www.edinburghmodelboatclub.org.uk
https://www.facebook.com/pages/Edinburg ... 2565540179
IJN Nisshin
HMAS Albatross
- Dave Wooley
Hi Doog Good to hear from you . I was very impressed with your USS Wolverine especially sailing and I look forward to seeing more of your model next year. I hope to be at the National Navy day next year with Kiev but we shall see. I have a completely open mind on the subject of crew and how they are presented , as my knowledge on this subject in "nil" So I have it all to learn. When I see the likes of Bill Waldorf and Ted Parr incorporating figures , effectively and gaining such impressive results I see that it can be done and done well. Thanks for the tips much appriciated.doog_k wrote:The weathering discussion is interesting, I've found some useful materials recently, both for static and working RC ships. As Dave knows I tend to work in stand-off 1/144th and have been thinking about how best to weather for many years, I still haven't learned the art yet but I've found that a combination of Games Workshop acrylic washes and good old fashioned semi-dried out enamels help to lift details. My late war version of USS Wolverine should be an interesting challenge! BUT, not overdoing it is key, I always err on the side of caution.
- ARH
If anyone can do it its DW
putting me to shame these days Mr W.
Simple but effective.
