1/144 Kiev by Dave Wooley
Re: 1/144 Kiev by Dave Wooley
Post by Dave Wooley »
ARH wrote:If anyone can do it its DW :woo_hoo: :woo_hoo: putting me to shame these days Mr W. :heh: :heh: :heh:
Ron You have done more on "scratch build" to promote scratch building than any one . Once the master always the master. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
roy allen wrote:See you at Telford then Dave :thumbs_up_1:
Is it Saturday your coming
Roy
Hi Roy This is what I would like to achieve on the model with deck crew .
Dave Wooley :wave_1:
ARH
Post by ARH »
Dave, Dont look at the big picture, brake it down into chapters, pick the crew for your first aircraft and start there, chapter one, when you have done that you will find the next aircraft easy.
First I would look for crew in white , then blue and spray them, thats a large section done, then start adding the small colours, like face and hands, boots, hair or hats and helmets, best of luck, you know its the small parts that take the time. :heh: :heh: :heh: :thumbs_up_1: :thumbs_up_1:
Simple but effective.
The next job is to fit the peel off vinyl numbers into the HELO/ VTOL circles.
It�s certainly not a difficult job but non the less requires care.
The number is carefully removed from the backing . These numbers and letter
are in self adhesive vinyl matt white.
Once fitted the number is gently worked to ensure that it is firmly in place.
The larger circle aft has a letter M in the centre . The application is the same.
All the circles except the forward "off set" spot will have numbers fitted.
Why there is no number in that circle I really don't know If any one can shed
any light as to why it would be much appriciated. There is no information on
this that I can find .
Now for the second set of numbers to the side of the deck edge.
This part of the job is again reasonably straight forward . These are the results so far.
More work on the flight deck yet to do .
Dave Wooley more to come :wave_1:
tweety777
Post by tweety777 »
Did they want to give it the number 0 and then thought like, well, a circle is close to a 0, so why not leave that number, saves paint and metal.
Why metal, most marks are metal numbers, letters or symbols with mostly white paint on it.
The metal won't easily be removed, so all the important information is allways visible as a higher spot on the deck or hull.
Looking great by the way.
Greetings Josse
Making a complete new Well Enhancer, again scale 1:75.
tweety777 wrote:Did they want to give it the number 0 and then thought like, well, a circle is close to a 0, so why not leave that number, saves paint and metal.
Greetings Josse
Hi Josse You may well be right best explaination I have. Thanks for your kind comments .
ARH
Post by ARH »
From what I have seen, its a letter C. :thumbs_up_1: :thumbs_up_1: :wave_1:
The Cyrillic "C" corresponds to the English "S" - not sure what significance that has though.
Dave, you know the Navsource.narod.ru page on Kiev, right?
GTDEATH13
Post by GTDEATH13 »
The markings are superb.... Another lesson for us novices... :thumbs_up_1: :thumbs_up_1:
Concerning the unmarked circle fore, I think that they only used it for emergency landings and assorted incidents (I have read it somewhere but cannot recollect where). If you check your references you might discover that they did not use that place vey often. And it is the landing spot from where it is easiest to jettison a burning wreck off the ship simply by turning and thus listing.
As far as weathering is concerned, I would not weather a full hull model. Let's assume that Kiev is going to be insected by the fleet Admiral, or worse, the eyes of many people... :heh: :heh:
The additon of the figures is a tedious task. The easiest way for painting (at least that is what suits me in 1/32 scale) is firmly attaching the whole figure somewhere where you can hold it from (mainly at the foot , since it is easier to paint black the spot afterwards), paint the main colours of the suit, than the secondary colours and finally the bare skin spots and the facial characteristics (I guess that in 1/144 scale this is not very easy or worth trying)...
Those where my two cents of worth...
Keep the photos coming... :wave_1: :wave_1:
NIKOS (NICK)
ARH wrote:From what I have seen, its a letter C. :thumbs_up_1: :thumbs_up_1: :wave_1:
Thanks Ron I see it now silly me , should have noticed. :doh_1:
Dave Wooley :thumbs_up_1:
GTDEATH13 wrote:The markings are superb.... Another lesson for us novices... :thumbs_up_1: :thumbs_up_1:
Hi Nick I like the bit about the Admiral of the Fleet coming to inspect , You are right I shall not be weathering .
Dave Wooley :cool_1:
ARH
Post by ARH »
That will be in November Dave :woo_hoo: :woo_hoo: :thumbs_up_1:
ARH wrote:That will be in November Dave :woo_hoo: :woo_hoo: :thumbs_up_1:
Possibly January "Admiral" :nod_2:
mitchell300
Post by mitchell300 »
Err what?
Who is an admiral? :P
Am i missing something? XD
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
Hi Mitch The admiral in question is ARH. Ron is known as Admiral Ron H. All this came about before I was on the board and goes back years. No doubt Ron will be able to shed more light on this .
Athwartships of the flight deck aft is a broken white line this is how the line was
formed .The lining tool comes back into its own for this simple task.
On the sheet of figures and letters there is various other items which can
{like Bill Waldorf and ARH have said many times even the innocuous can be useful }
that can be utilized .
Each broken length is carefully set against the marker .
All in place.
The completed line.
The next phase is to insert the fore and aft line running through the centre of
each circle
The line will be solid within the circle and once again to ensure that all is true
a cord was placed for and aft at a position just off the centre line and corresponding
to the thickness of the stripe.
One side completed now the next.
J. Soca
Post by J. Soca »
That is one utterly neat job Dave !!!! :thumbs_up_1: :thumbs_up_1:
Jose
Thank you Jose much appriciated. It's not the fine detail work of fittings or superstructure but I think in many respects this type of work is as important in the overall scheme of things.
ARH
Post by ARH »
Looking very good Dave, when you said jan, did you mean you will not bring it till then, or did you mean you will not be at the next meeting.
As for the Admiral, it goes back many years when the site was in its infancy, Bill and I did a lot of builds, I was asked to set up Scratch and R/C, because of all the work I had put in Tim the owner of the site bestowed the tittle of Admiral on me , :heh: :heh: and it has stuck, especially with the older members, also the Pirates from the good old days, when it was fun, fun , fun. :woo_hoo: :woo_hoo: :wave_1: :wave_1:
Hi Ron Kiev could be at the January meeting and I shall certainly be attending for November.
