To HMS Victory and beyond
Re: To HMS Victory and beyond
Continued incredible work.
dafi
Post by dafi »
Thank you Dan!
It has now been 4.5 months since the big show in Evian. Since then, my ing Beauty has been lying in her box in the camper van, as I haven't had the time to kiss her nor the space on the work table to lay her down gently.
This weekend I finally pricked up my lips and gave her a really nice wake-up kiss
And I took the opportunity to take a few beauty shots and compare 1803 and 1910
Is this now considered unto be out of box?
I also took the opportunity to take a closer look at the new bow. It was based on the three-deckers built between 1800 and 1805. The bowsprit is now also anchored one deck higher.
One side is still a bit rough ;-)
Hope you like it!
XXXDAn
To Victory and beyond ...
dafi
Post by dafi »
Oh God, now the building report has actually slipped so far down that archaeological excavations were almost necessary to find it again ...
A lot of business in the business, vacation, home garden, garden plot and life itself - lots of things that can get in the way and prevent you from tinkering.
But a little something did happen. On request, I did a bit of research into the deck accessories. First the riding bitts. Another small kit in itself of 10 parts.
XXXDAn
I somehow missed your prior post. I certainly prefer the more classic look of 1803.
dafi
Post by dafi »
Thank you Dan. I certainly prefer the more unknown look of 1765.
XXXDAn
dafi
Post by dafi »
And the pumps were also due.
First the elm tree pump. There is a protective bracket to protect the handle and the two through-pipes for the two lower decks are also included. In order not to have a pinch-off point, the handle was printed free-flying, diameter 0.5 mm x 0.5 mm. It came out straight, but when washed in acetone it bent uniformly on all prints. It's better to make a connection at the top for the next print in the hope of minimizing warping during washing.
Therefore, a glass of hot water, briefly dipped in ...
... kept in shape while cooling down and - tata ! - everything is straight again :-)
Here is the comparison picture. So never cold bend resin, it works wonderfully with heat!
Then I discovered that I had made a 0.15 mm hole in the 0.5 mm x 0.5 mm handle.
Checked the passage with a wire ...
... and pulled in a rope. It actually really worked :-)
The wooden clamp is not a standard one but a mini clamp ;-)
And the chain pumps have also arrived.
XXXDAn
SG1
Post by SG1 »
So good of you Dafi! :cool_2:
dafi
Post by dafi »
Thank you SG!
And I was also finally able to finish the capstans.
All the parts had been in the making since well into last year, but I never really had the chance to finish them. Basic programming strictly according to plan is always done quickly, but until the look of the printout refreshes my eyes and heart in terms of model making, it takes a few more rounds of printing, tinkering and improving, version #15 is the normal case here.
Here is an intermediate version, the brass tubes have now been replaced. Still mising are the bevels on the wedges below the ribs, which allow the rope to slide smoothly from round to pentagonal or hexagonal. I take such pre-prints for color samples, and lo and behold, it looked stupid in this color scheme.
Here is the penultimate version. [Note to self: HOPEFULLY!] Good enough for a prototype. [Note to self: HOPEFULLY!]
And what do I always say? Before applying the aging, a clean base coat must be applied. Here you go.
And then life gets in: The wood starts to show at all the rubbing points of the rope on the drums. After several tests, I decided on a non-covering drybrush, which gets across most of what I would have liked to show.
And someone else has bombed into the picture: The capstan bars ...
... to match the capstan.
I made a template for alignment, using corrugated cardboard as a base to sink the upper part of the drum into and bring the spars to paper height ...
... bars inserted into the capstan and the capstan inserted upside down ...
... bars aligned and glued.
Then the swifter is pulled in and that's it.
And here are the individual parts, the middle piece is available in two heights, depending on how the battery deck is fitted with gratings.
XXXDAn
dafi
Post by dafi »
Some time ago, I made the mistake of getting involved with the boats because of the oars. Of course, this was not without consequences ...
... Here is the white �big� launch from the kit and behind it a new �decent� 34 foot launch according to McKay's drawings.
Unfortunately, the planks of the inner floor gave way during printing, there was only a small usable remnant at the front and rear.
And if you man the boat, you can see straight away that the large boats were rowed �double banked�, i.e. 2 men per thwart and if the capstan is used, one thwart cannot be used.
Oar lengths inside and outside and the position to the rower and his arms seem to be correct.
But the inside floor still gives me pause for thought. As McKay draws it, it is 30-40 cm too low for the rower's legs and too high so that 50% of the load volume is lost. So it's a strange intermediate height
Somehow this still didn't fit. I then rummaged through my documents again and found what I was looking for, as these details are seldom shown.
Here is the small kit that has evolved as a result.
The inner floor to protect the hull now rests on the frames at the very bottom. The rowers' feet have been given a bar for this purpose.
Trial fitting ...
... and it fits reasonably well. With slightly straighter legs it even fits quite well.
So the other foot bars are also installed.
After that came the thwarts and the other interior ...
... ... and it already looked quite passable.
And again we had a rehearsal sitting ...
... even multiple ones.
This also seems to fit. The capstan is removable, so two more rowers could fit in.
But the next question is, what was the rigging like?
In terms of the mast positions, I would have guessed lugger rigging, which I was able to see live a few times in France, or perhaps sprit rigging, but I'll see what Steel has to say about that later. Above all, all the fittings on the hull are still missing, which are vera often omitted.
Greetings, DAniel
wefalck
Post by wefalck »
It's really fantastic what can be done with 3D-printing.
And I know from my forays into laser-cutting that it may need half a dozen iterations from the original draughting to get the parts to the right dimensions.
Eberhard
Image Image Image Image
Amazing work! Those boats look fantastic, as does the capstan.
SG1
Post by SG1 »
Beautiful little masterpiece. An incredible improvement if compared to the white launch. Well done! :thumbs_up_1:
Exquisite work, all of it, the planking, oarsmen, capstan, etc.
Of course, all I could think of is that you should now seque to a Roman galley with galley slaves. You have the details down perfectly. :heh:
marijn van gils
Post by marijn van gils »
That launch looks amazing Daniel! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Haha, I have been working on a very similar thing over the last week: the crew of my small version of that same launch. :smallsmile:
I have been selecting and converting them, so I can soon take them with me on my holiday and paint them.
In the launch, I have opted to leave out the capstan, since their mission in the diorama is not lifting an anchor or similar, so I have every thwart manned with rowers.
TF17Greg
Post by TF17Greg »
Superb work
CUT...FILE...GLUE...PAINT...WEATHER...AND...REPEAT :wave_1:
Follow me on YouTube https://www.youtube.com/@Fullmetalpainter
dafi
Post by dafi »
Waiting for Godot ...
Since the geometry of the boats is highly complex, the printer has to run at the highest resolution, and that takes time ...
That's why I used the time in between to finish a few other things, or rather to give them a final polish.
All the bitts on the upper deck have now been joined by the bitts on the upper battery deck, which hold all the halyards of the main mast. Big strong things with nice rollers in the base.
Here with the swifel pump in between.
You can already admire them in the open heart of my Vic.
The matching deck beam supports. Cheaper by the dozen. A bit of drybrushing here too to modulate the shape.
Plus the small kit of the riding bitts and what you can be done with it.
And I would like to take this opportunity to out myself again: As much as I like and need high-quality tools, but often nothing beats the basics!
- A sheet of sandpaper on the table and you can make smooth and even strokes when sanding
- Sandpaper stuck to wooden sticks using double-sided tape allows sanding tools to be cut to the exact width of the workpiece using the width of the sticks. Some of the sticks shown here are exactly the width of the gunports of my Constitution.
- Right-angled blocks facilitate sanding at a 90� angle.
And when the paper is blunt, a new one is put on.
And here is the guessing game of what else I have prepared :-)
Best regards, Daniel
dafi
Post by dafi »
I had finally found the time to finish off a few little things around the stove. It was slowly becoming what I wanted :-)
Here are two colour versions, one with a classic red brick floor and one with the typical southern English yellow-beige floor covering.
And here in the detail shots you can also see the warming trays that could be hung on the handrail of the cooker.
Of course, the stove also includes the kitchen area. I have chosen the wickerwork that can be seen on the contemporary model of the Princess Royal and others.
The whole thing is a cute little kit of 22 parts. The drive chain is twisted copper wire and the rail is bent wire, for which there is a template.
Here are a few more details:
The base plate with catch tray and tube for the fresh air supply from the deck below ...
... the stove body ...
... the holders for the skewers ...
... the distiller with all its attachments ...
... ... and the cowl, all that's missing is the round cover plate against rain and storm.
As usual, the ensemble was finished with a little diluted ink and a white drybrush, and the metal parts with a little graphite.
XXXDAn
PS: And it took me a while before I had the courage to print the warming trays directly and completely. But all the attempts to glue the holders on with holders were just horrible in the result ...
pascalemod
Post by pascalemod »
Perhaps this was answered earlier in the thread, but why the white painted hull bottom?
dafi
Post by dafi »
@pascalmod
If you mean the 1920 version, thathas the bottom white simply because it was too early to put the coppering on :-)
If you mean the boats, then this was the color of these days.
All the best, Daniel
pascalemod
dafi wrote:@pascalmod
Daniel, I meant the 1920 version yes. I was wondering if they just painted it in white for some reason below water (leaving the copper bit above as you have). But of course, all copper makes sense, I was just confused a little, as 1920 version looks all kinds of different in many other areas too. Thanks for clarifying!
