1/144 Kiev by Dave Wooley
JIM BAUMANN
Re: 1/144 Kiev by Dave Wooley
Post by JIM BAUMANN »
Deck looks razor sharp!
JIM B :wave_1:
Post by Dave Wooley »
JIM BAUMANN wrote:Deck looks razor sharp!
JIM B :wave_1:
Hi Jim Thank you much appriciated. I'll leave the weathering bit to the experts. :thumbs_up_1: :wave_1:
Continuing with the broken white stripe .
Again the cord comes in handy for maintaining a true line.
With the broken centre stripe completed the next part of the deck marking is the
narrow width stripe emanating forward from the side of each of the inner circles
Once again the lining tool proved very useful, ensuring that both sides were the same
The tool was progressively moved along .
A circle completed
All are completed using the same method in a very short time.
The one single problem with the markings on the flight deck of Kiev is that they were
constantly being changed. . At one point on Kiev circle 3 was like a compass
rose . I have no idea as to the purpose of this but the photos confirm that it was in place.
The deck makings on the Kiev�s are not complex just involved. The long narrow yellow V
will be the last of the deck markings to be fitted.
Dave Wooley more to come :wave_1:
boatman
Post by boatman »
HI DAVE well again youre the master builder i think really brilliant modeling an she certainly colourfull an how youve fitted your deck markings brilliant i if i ever get that far hope to use the same teckneics on my nimitz :thumbs_up_1:
Hi Chris Thanks for your kind comments. I think one of the reasons this build is a little protracted is I try where possible to plan the construction so it can be shown , as ARH would say in a step by step way. And when you say that you may well make use of some of the techniques illustrated, then that's makes my day, and it's more satisfying to know that what is shown can help others . Press on with your Nimitz it's a great subject and a great build .
mitchell300
Post by mitchell300 »
Sorry that i didnt said anything, but got a new pc and forgot my pass :P
But damm kiev, i love your decal workings.
Really nice made!
im looking forward to the next progress
Mitch ;)
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
russclark
Post by russclark »
very nice lines,numbers,and circles.every thing is lined up neat and straight,i can,t see a blemish or boo boo anywhere,excelent job. :thumbs_up_1:
ARH
Post by ARH »
Dave I did notice your photo needed flipping. :heh: :heh:
Simple but effective.
Hi Ron I didn't notice that . You are right .
Dave Wooley :thumbs_up_1:
JIM BAUMANN
... its not just your deckmarkings that are razorsharp.....
so is our Ron ARH....!!!! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
JIM B-- bowing to the observational skills of his elders! :heh:
ARH
Post by ARH »
Thanks guys, I could not understand why I could not read the numbers clearly. :wave_1: :wave_1:
The signage continues with the markings on the offset circle to the forward
end of the flight deck.
Starboard aft is an dispersal area for the Yak 38s . This consists of a series of
angled white strips . These as you would at first assume are not all parallel .
Using low tack tape ensures that each white strip is set straight .
All the strips are set in place
The low tack tape is removed . Once again there is no reference as to why
these white strips are spaced as they are? I can only assume it must help
in parking up the aircraft, a feeble reason I know but in the absence of any
other that's what I�ll go with.
Set into the deck surface are tie down points . These are linked to the top of
the nose wheel undercarriage .
The tie down points are formed from PE
Next job is a white stripe through the large M circle .
All that remains now is the yellow chevron ,to complete the deck markings
and the white stripe above the black boot topping to complete the hull but
that�s for next time.
Dave Wooley more to come . :wave_1:
ARH
Post by ARH »
Dave,Is there a white line up to where the nosewheel stops between the tie downs, looking good, did you enjoy the show. :heh: :heh: :thumbs_up_1: :thumbs_up_1:
ARH wrote:Dave,Is there a white line up to where the nosewheel stops between the tie downs, looking good, did you enjoy the show. :heh: :heh: :thumbs_up_1: :thumbs_up_1:
Hi Ron like the rest of the deck markings the parking stripes was changed frequently . The centre line as in the photo was not in place but the tie downs remain the same regardless of time line. In fact on some photos the same stripe was blue then deck red then white . Also added at one time was a set of small numerals at the head of each stripe .There is one photo I have which shows a different set of stripes in the opposite direction as if no longer in use. All very confusing. Once again there purpose is unknown . The show was busy with a good number of models, plenty of traders Got me a set of name plates for Kiev in classic Cyrillic for the side of the hull and aft ,from Barry's Lettering , he even did the Soviet emblem at 1:144 which also goes right aft. I'll post these up in due course superb job .
GTDEATH13
Post by GTDEATH13 »
Your effort for correctly detailing the flightdeck is exceptional, adequate of the construction work...
I thought that you would like the following pics. I just took them at Pylos port, in Greece. This is a Russian vessel that came here for the anniversary of the Navarinon naval battle in 1827. As you will clearly notice the ship is fresh painted. No spot of rust whatsoever... I guess that Kiev will look like that when complete...
NIKOS (NICK)
Thank you Nick Ships can indeed look free from being weathered as your photos show. :thumbs_up_1:
mitchell300
GTDEATH13 your wrong.
That ship whas also whit dutch navy days 2009 in my harbour port.
When you take a close look you see everywhere paint and no rust.
but how its painted is very ugly.
You got a nice sheet of paint, whit thikker peaces on it and more.
From a distance it looks nice, but close it looks like S**t
Ill find those pics for you to show you.
Greetz
Mitch ;)
Ships in dock:
Ships in repair:
GTDEATH13
Post by GTDEATH13 »
Than I guess that Dave will have to paint and repaint his Kiev at various spots so as to achieve the many different layers of paint... :heh: :heh:
The point I am trying to make derives from the earlier discussion whether Dave should weather his Kiev or not... I believe that he should not.
I used those photos to make my point. Believe me, I know first hand how to tackle with hiding the rust on ships. Old Bloys Van Treslong which I am currently on service got the same treatment before we got to the anniversary celebretions. Sometimes it is difficult to correctly retouch and protect the ships metal from its eternal and leathal enemy: rust. For our Russian friends aboard would be more difficult sunce they had to travel up to Greece and then have their ship look up to shape.
Moreover,even in 1/144 scale, depicting the various colour layers and mispaintings will not really show, will it? And actually, we already assumed that Kiev is going to pass an inspection from himself the Admiral of th Fleet when complete. And we know Admirals do not like seeing something unpainted...
What moves you salute, what does not you paint, and old navy saying goes... :big_grin: :big_grin:
I will get a closer look on the paintwork of the fellow Russians tonight when I will visit them for the reception they are holding... :wave_1: :wave_1:
NIKOS (NICK)
ARH
Post by ARH »
If its not right I will set Scousegit on to him, and I dont think he will like that, :heh: :heh: :heh: :thumbs_up_1: :thumbs_up_1: looking good :woo_hoo: :woo_hoo:
mitchell300
Cool your on the EX Hr Ms bloys van treslong(f284) currently:HS nikiforos fokas (f466)
Dutch made, very good ships :P
Mitch ;)
Ships in dock:
Ships in repair:
