Shows a great deal of detail! Tiedown points, cutouts around the bitts, drain grating between deck and ramp, looks as if non skid goop has been recently removed from wooden deck and tiedowns on woodern deck area are still visible.
Thanks! T
Thanks! T
Great resource here! Anyone have photos of the area inboard of the harpoon launchers? Looks from fragmentary photos that there is a blast shield and some sort of passageway or shelter between there and the stack.
Regards: Tom
Regards: Tom
- Luky
Space between skegs?
Can anyone tell me the space between skegs on the USS Missouri?
1:192 scale or 1/16 scale
They are parallel right?
Went to get coffee.
- rtwpsom2
Yes they are parallel, and the distance between centerlines appears to be 24 feet even.
If you have access, p 408 of Stillwell's Battleship Missouri has body plans from fore and aft. HSNA has, i believe, general plans for New Jersey which thou different in detail are quite useful. The inboard shafts are parallel, the outboards are not.
T
T
- Luky
Thank you so much for that info and the time you took to give it to me rtwpsom2.rtwpsom2 wrote:Yes they are parallel, and the distance between centerlines appears to be 24 feet even.
Now I can continue building the hull.
Went to get coffee.
- Luky
Thanks for that info Fliger 747!Fliger747 wrote:If you have access, p 408 of Stillwell's Battleship Missouri has body plans from fore and aft. HSNA has, i believe, general plans for New Jersey which thou different in detail are quite useful. The inboard shafts are parallel, the outboards are not.
T
Went to get coffee.
- Luky
Full hull. people like to see shiny propellers. Know what I mean?Fliger747 wrote:Possibly, though such lips are usual shipboard to direct water toward the scuppers and drains. Here is a really bad photo captured from an online video of the ship being moved from drydock to Ford Island and her current location. Shows line handlers and the ramps.
Luky, is yours going to be a full hull or waterline?
All of the photos of current work on page #56. This thread.
Went to get coffee.
Luky:
The length OAL of the ship is 887ft 3 inches. At your 191 scale that should be 55.743". At 1:192 that comes out to 55.453 inches.
Cheers. Tom
Cheers. Tom
- Luky
Wouldn't the 192 scale be 55.625? OR (55-5/8)Fliger747 wrote:Luky:
Cheers. Tom
887ft. devided by 192 X 12 =55.4375
Then add .1875 for the 3 inches=55.625 right?
AND...
887 feet devided by 191=55.725 THEN add .1875 +(3 inches)=55.9145 inches
Went to get coffee.
I took the 887 and multiplied by 12 and added three, then devided by 192. I do have a very large vernier caliper i use for woodworking projects but's not that long. Best thing i ever found (in Taipei) was a tape measure calibrated in 1/100 foot increments, which could be easily read to a couple of thousands. Great for laying out stairs and probably ship hulls! Never sen one since.
Having built two of these before i am sure you have learned a lot!
Regards. Tom
Regards. Tom
- Luky
Each one I build I still keep learning things.Fliger747 wrote:I took the 887 and multiplied by 12 and added three, then devided by 192. I do have a very large vernier caliper i use for woodworking projects but's not that long. Best thing i ever found (in Taipei) was a tape measure calibrated in 1/100 foot increments, which could be easily read to a couple of thousands. Great for laying out stairs and probably ship hulls! Never sen one since.
Regards. Tom
I hope I can get this one to be a little closer than the last two.
But the last one I built I used a pair of calipers that were 6 inch with .001 increments.
Those direct from Hawaii photos are really the best help overall.
Went to get coffee.
I'll see if I can post a few more photos. In retrospect i would take even more photos. Some parts of the ship were not acessable at the time.
T
T
- Luky
Thanks for the photos!Fliger747 wrote:Ship from dockside, fwd.
The up close photos of the superstructure are really helpful.
Went to get coffee.
It appears the ship is covered completely with small fittings, drain pipes and equipment fastened to every bulkhead. I photgraphed with the vague idea of sometime working on the model again. If I get back there again I'll methodically take full coverage of everything.
Will look through them and see what elese might be useful.
Tom
Tom
- Luky
Today I worked on the decks fore and aft of my 1:187 scale Missouri. Getting the skegs faired in.
I am thinking about how I will carve out that bow area where it is concave.
Can anyone tell me the length of the small skeg between the two large skegs?
Went to get coffee.
I am taking a little break while some glue dries.
It is 2:30 PM-PST and it is only 36� outside!
That is cold for this part of California.
I am having some hot tea and blackberry pie. Warmed up.
I m working on the bow section of the model. Tough going
but it is the last part of the hull carving.
Still waiting to see if anyone can tell me the length
of that small 3rd skeg on the bottom of the hull.
Looks to be about 52 ft on the bottom and 64 ft on top next to the hull.
Cheers T
Cheers T
- Luky
Thanks Fliger 747!
Now I can make that while other things are going on. Like sanding.
Breaks up the routine.
Photos tomorrow of the bow.
Went to get coffee.
