Revell 1/350 USS Wasp LHD-1
Bigdaddy Mark
Re: Revell 1/350 USS Wasp LHD-1
Post by Bigdaddy Mark »
I just showed the wife, she said "Oh my god, No"
I guess I'm out on this idea.
~ Chester W. Nimitz ~
boomstick68
Post by boomstick68 »
I like the camera idea. I may implement this on my Enterprise build but my Nimitz is close to her hangar bays being sealed up. Keep us posted on the progress and IPB on the system. My plans for CVN 65 are a full total detailed hangar bay and a not so full airwing so I would love this setup for the hangar bays. Good idea sir. :thumbs_up_1:
Nansen
Post by Nansen »
Thank you for the feedback, much appreciated.
After a rather successfull camera test, it is back to hangar overhead building. I used 1x1mm styrene strips to replicate the beams in the overhead, not going for a 100% replica, but more of a generic overhead, since I don't think it is possible to make a true copy in this scale. However, I'm rather happy of how this turned out. When peeking in the hangar doors this is what you see
It took a lot of time, measuring and dryfitting to make it work. I'm not that much of a scratch builder so I need to do some adjustments and clean ups later. I will also do some work in the crane area and some minor detailing.
An overview of the overhead
More to follow
Erik
Nansen
Post by Nansen »
Small update to night. I more or less finished the "crane area". Only some minor detailing here, loosely based on some ref pictures. I added walkways made from some scrap pe and the crane beam.
This is how it looks through one of the hangar bay doors. The railing looks bent, but this is an effect from my crap camera. I will call the overhead more or less finished now. A big thank you to Tracy White who pointed out the raised area for me. I'm pretty happy about how it turned out.
Erik
That hangar shot is absolutely convincing!
boomstick68
Spectacular.
Bigdaddy Mark
Great Job!!
This is WAY OVER THE TOP!!
Nansen
Post by Nansen »
After a couple of quiet days I have a small update. After finishing the CH-53 in a maintenance stance I promised my self not to do that again. Yeah right... When I started glueing Harriers I kept comeing back to a ref picture showing maintenance on the jet engine... So to make a long story short I brought out the Dremel and cut open the engine bay. I made an engine from styrene rod, led from a wine bottle and styrene discs made with a punch and die set.
The start of the jet engine
Engine installed. I covered it with thinned putty to "blend" the parts and detailing will continue when the putty is dried.
I also installed rotor cradles on the SH-60 with the folded tail. This went much easier than I thought it would, and adds a nice detail to the helicopter when painted red.
Finally I painted some vehicles for the well deck. This will be the last ones.
Erik
Christian Bruer
Post by Christian Bruer »
Hello Eric,
I missed this before. What a wonderful project with so many fine details - really nice and good modelmaking :thumbs_up_1:
Christian
AKA "Painter"
VMF'06 - German Gamblers
Bigdaddy Mark
I've been looking at a reference picture with the engine on the hoist. Your engine is fantastic!
What is a disk punch?
Bigdaddy Mark wrote:What is a disk punch?
This.
Nansen
Post by Nansen »
Yep, it is what Tracy linked to. Usefull tool.
Erik
sgtryan13
Post by sgtryan13 »
Ok, come on, now you're just showing off! :big_grin:
Great job, as usual, the aircraft look awesome, and your hangar deck is going to come alive with all the maintenance you are showing going on in there.
Nansen
Post by Nansen »
Here is a heads up for those building the LHDs. When building the Harriers, mount the landing gear on the wings before the main gear. I installed PE gear from WEM and learned this the hard way. When the wheels are mounted on the wings it is easy peasy to get the correct hight on the main gear so all four wheels touch the deck. Since I messed it up I had to scratch build the main gear since the original was eaten by the carpet monster when I tried to remove it after the glue had dried.
Erik
boomstick68
Good tip sir! Your aircraft will inspire me to finish the 48 I have yet to finish for my Nimitz. :thumbs_up_1:
Nansen
Post by Nansen »
48!!! Well Sir, that is pretty much the whole Norwegian Air Force.
boomstick68
:rolf_3:
Bigdaddy Mark
Again good heads up, and yet another crack me up.
Nansen
Post by Nansen »
13 pieces of PE on a 1/350 Harrier. And yet three more to do... :doh_1:
Nansen
Post by Nansen »
Even though I managed 2,5 hours at the bench today, I don't have much to show... The Humvees got antennas and are now ready for a dullcoat. After this I went back to the Harriers. I have not seen weapons for 1/350 airplanes (have not really been looking) so I decided to scratch some. I built a Lantirn target pod and two GBU-12 since I prefer jets in "air to mud" configuration. I made the bombs from 1 mm styrene rod sanded into approx size using a Dremel, sandpaper and a file. This took a while since I managed to break several rods in the process. Fins were made with led foil from a wine bottle. The bombs are no beauties, but I think they will do when mounted under the Harriers. 1:1 Toothpick for scale.
Erik
