1/700 Amagi diorama
marijn van gils
Re: 1/700 Amagi diorama
Many thanks guys!
- Milan Kuliffay
Marijn, excelent and precise work
If you own a good documentation, it is allways possible to make a model with fine details.
Good luck, I'm looking forward for your next modelling steps.
NOVA73
Hi.
Superb work very PE as I like. Details and processing especially at this scale are exceptional.
Lovely.
Best regard,
Alain.
Lovely.
Best regard,
Alain.
- blacman
everything what I would like to write has been written already...
So KEEP goning!!
- JIM BAUMANN
very good--especially a your model will allow the viewer to actually see the underside of the flight deck without a mirror!
JB
JB
marijn van gils
Many thanks guys! Your words are motivating me a lot to put some more work in it!
Yes, the fact that these details will remain very visible is one of the reasons why I got interested in this scene. I always loved all the details under the overhanging decks, and under the AA and other platforms, which are so typical with IJN carriers.
But at the same time, I only have to do half of them, as the overhanging deck at the bows and the entire port side is under water!
Win-win!
Marijn
Win-win!
Marijn
Truly striking work, Marijn.
marijn van gils
Thanks Dan!
lascar
What a great job !!!!!!!!!!!!!!!!
- Eric33
Bonjour Marijn,
Always a real visual pleasure to see your new work, still amazing !
I also respect a lot people like you who have so much courage and perseverance to work on this kind of project, so big, so detailed, and so time-consuming !
I will go this year for first time at the Eindhoven SMC, in Oct. I hope to see it finished, and perhaps also some of your "old" works ? (because you're living not far and come by car, I suppose), like "Lexington Last Battle", and some small dioramas (like your famous 1/700-1/35 Highlander statue, which made me know your name for 1st time).
Eric PHILIPPE
https://www.facebook.com/eric.philippe.108
Working on:
- "End of a Greywolf", 1/700 diorama
- "La d�faite", 1/72 France 40' AFV diorama
Working on:
Scott56
Not sure how you do all the tiny detail. In short I am in awe.
I'll be watching for updates.
Scott
Salisbury, NC
USS Iowa BB61 1943 post refit
1:200 Trumpeter w/ Pontos detail up with deck
USS Missouri BB63 1945 1:350
In planning T2-SE-A2 tanker AO-82
Salisbury, NC
marijn van gils
Many thanks Lascar, Scott and Eric!
Good eyesight, a steady hand, and a bit of patience does help though, as do many years of practice.
Eric, it's a really great show, especially for armour and figures (they will have Bill Horan as special guest!), so I'm sure you won't regret! This year, it will be a two day show, so it will be more worthwhile to make the trip too. And I would love to meet you there!
If me and my family are in good health (which normally should be the case) I'll be there. And since my club normally has a clubstand there, I'll be bringing some older stuff too. I'll make sure to bring those two, and if you have any more requests, just send me a message a week before the show.
It would be nice if this dio would be finished by then, but since don't seem to be able to put enough hours into modelling nowadays, and this projects demands a quite involved paintjob (which is of course big part of the fun), I doubt it will be ready. I'll bring it as work in progress for the clubstand anyway, but I guess I better put some more work in it now...
Marijn
One by one! And redoing a lot that went on croocked the first time...Scott56 wrote:Not sure how you do all the tiny detail.
Marijn
marijn van gils
Meanwhile, I finished the stern area.
The main element is the boat deck. This is the detail on the underside of it in the kit part. Quite good for 1/700, and with limited visibility in normal upright position more than acceptable:
But visibility will be higher on this diorama, so I sanded the detail down, and continued to thin the part as much as possible. I messed that up though, by overdoing one side, which became too thin. Not only made it this side very fragile, it also made the starboard AA-gun bulwark visibly thinner than the port one:
So I corrected my self-inflicted problem by applying a thin layer of Magic Sculp epoxy putty, and resanding carefully after hardening:
Here you see the difference this makes on the bulwarks:
I also cut away the port gangway part which will be 'under water', and carefully 'detached' the starboard gangway. The latter will be permanently attached to the hull, while the boat-deck will remain loose for easier painting:
Now, I only had to add a couple of details to the underside. They are a mix of generic PE, some cannibalised parts from the Lionroar PE set for Unryu, and stretched sprue:
And the topside also needed some details. They are made from leftover PE pieces, plastic sheet, stretched sprue, and a couple of parts from the Lionroar set:
After scratchbuilding the rearmost AA gun platform, I had these parts ready. They will remain detached for painting, but afterwards will quite easily click in place:
And this is how it looks like when put together. Only railings will follow later:
One more pic of the real thing (many thanks to Dan Kaplan for maximizing the detail on it!):
And it is sometimes too easy to forget the actual size of 1/700 scale models, so I had to include a match in at least one photo
Any comments and critiques are welcome!
Marijn
Marijn
Yeah, I've got a comment. You are a friggin' magician! Wow - that is superb work. Very inspiring.marijn van gils wrote:Any comments and critiques are welcome!
- Goodwood
It's a good thing you're building this in a modular fashion, mate, because that looks to be one wicked-challenging paint job, even for a magician (heh, thanks Martin!) like yourself...
Awesome detail work!
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
On the ways:
In the stash:
- Daniele
Amazing and inspirational work , thanks for showing
- medicmike
Wow this build just keeps getting better and better!
Just finished:
1/350 USS Columbia 1945
Current projects:
1/700 USS Catamount 1960
1/700 USS Helena 1942
1/350 USS San Francisco 1944
Current projects:
- Angeliccypher
If this is your idea of a couple I would probably vomit from intimidation at what you consider extensive! Either way, looking good.marijn van gils wrote:Now, I only had to add a couple of details to the underside.
Gabriel
Nanond
Jaw-dropping. Can't find a proper word.
I'm following this with great interest. Actually I'm still amaze with your Lexington. Your book is amazing and very detail. I'll use it to create a scene of Hornet after I finish my 1:350 Tone.
Thank you for sharing
Nanond Nopparat
Nanond Nopparat
marijn van gils
Many thanks everyone!!!
Haha, magician! I wish�
It takes a lot of work, but luckily I love doing it!
Well, my idea of extensive would probably be all details on the entire ship when it's finished. But that will still take some time, so you have a while to get a bucket ready!
Marijn
From my armor and figure modelling years, I'm used to assembling as much as possible before painting. It also helps a lot with weathering. But of course accessibility has to be kept in mind, so planning this out with ship models is a nice new challenge for me!Goodwood wrote:It's a good thing you're building this in a modular fashion
Angeliccypher wrote:If this is your idea of a couple I would probably vomit from intimidation at what you consider extensive!
Many thanks Nanond! I'm following your Tone with great interest too! Your detailing work looks amazing, and Tone is one of my favorite cruisers. She would make a fantastic Kure '45 subject too! Now wouldn't that be something?Nanond wrote:I'm following this with great interest. Actually I'm still amaze with your Lexington. Your book is amazing and very detail. I'll use it to create a scene of Hornet after I finish my 1:350 Tone.
Marijn
