1/700 Bretagne-1855 scratch The largest wooden wall warship
SG1
Re: 1/700 Bretagne-1855 scratch The largest wooden wall wars
Post by SG1 »
wefalck wrote: Ninitinol as a metal will not 'react' to any paint ...
YES, i guess it wouldn't start to sizzle :big_grin: . Apologies for using an incorrect term, i was enquiring about adhesion of enamels to nitinol, need for a primer etc
JIM BAUMANN
Post by JIM BAUMANN »
I use thinned enamel--
but usually indelible marker ( pentel) paint-- no thickness gain
sometimes I resort to various shades of brown 'sharpie' pens
cheers
JIM B
JIM BAUMANN
Hello all again-
-multiple vacations in summer, classic cars ,
paddlesteamer trips et al conspired to ration model-making progress
( but now have large and small progress to report !
small progress....
Making the cat heads( massive strong davit) for the anchors
annotated photos are self explanatory
steam pipes and funnels
and BIIIiiiiiiG progress....
The custom 3-D package is here... at last !!
a small selection of the goodies....
maxim
Post by maxim »
Cool!
Great that you got all these 3D printed parts! :thumbs_up_1:
wefalck
Post by wefalck »
Looking forward to all these parts being painted and installed ! 3D-printing seems to be the future of modelling ...
Eberhard
Image Image Image Image
JIM BAUMANN
I could make 5-10 or so barrels fairly identical
but could not manage a 130 odd....!!
same with gunport lids, the sqaure ones are OK
but the split gun port lids .....with a semi-circle in each side....(!)
to fit over the barrel;....
in 1/700 ....
are way beyond ,me to make repeatably, in quality and number ( in those numbers !! )
Apropos Gun ports, and the attaching tongues.....
a little more information here below as to how and why the tongues
Iceman 29
Post by Iceman 29 »
:thumbs_up_1:
Pascal
Yuth
Post by Yuth »
An impressive work as usual, and these lovely 3D parts will be well used I guess !
Can't wait for the future updates ! :)
In 1:700 we trust
There are three kinds of people: the living, the dead and those who go to sea.
bgire
Post by bgire »
:thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
marijn van gils
Post by marijn van gils »
Fantastic work Jim! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
The 3D-printed parts look fantastic! For the guns etc. they are certainly the best solution by far. And for the tops, they save you A LOT of scratchbuilding work!
The lips on the gun ports are very clever too.
I always found the catheads to be an important visual element of a man o' war. It somehow adds a lot to it's character, a bit like eyebrows to a person.
I have been quite inactive posting here the last couple of months, but still following with great interest!
Especially the sails... And I have a question!
This is an experimental sail of yours, with unvarnished paper:
The glue for the bolt ropes looks messy, as you wrote.
I guess because it soakes into the paper?
But I guess the varnish prevents this from happening with the final sails?
What varnish do you use, and how do you apply it?
I would be worried about little glue spots anyway, even without the soaking effect. Do you get them, and if so can your remove them? With a little dab of varnish maybe?
I am mostly worried that glue spots will affect the translucency of the sail. Does a sail appear darker or lighter at a glue spot when lit from behind?
pascalemod
Post by pascalemod »
The 3D printed port solution is superb. Do you have a friend doing these for you Jim, or the company is open to designing and at least receiving files - printing - based on instructions?
JIM BAUMANN
Hello @ Marijinn
that is a very valid question!
obviously I experimented first... ( on my 1/400 Mary Rose !) so also applicable to your Victory/ Redoutable works
viewtopic.php?f=60&t=163736&start=40#p710302
viewtopic.php?f=60&t=163736&start=60#p711283
viewtopic.php?f=60&t=163736&start=60#p711627
In 1/700-- same deal I sprayed the front and back of the paper ( to soak in ) whilst still flat
with Matt Humbrol Matt Kote ( in the glass jar ) enamel varnish
That renders it impervious to moisture in the air ( important with the ink-jet printed sails- ! )
when the wires are glued on all around as per image below, the CA glue and thinned white glue does s not show up.
when the sails are installed to the model they will be total (!) matt coat misted with Windsor and Newton artist quality Matt varnish
( acrylic which will not react with any enamel )
--this will homogenise the whole thing
( wires glued on )
HTH
@ Pascal--I shall ask.....
cheers
JB
Sszabi
Post by Sszabi »
There are some lovely details on this little boat... I especially like the sails! :thumbs_up_1:
marijn van gils
Many thanks Jim! That helps a lot indeed! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Frank Spahr
Post by Frank Spahr »
Most impressive progress and very helpful explanations as to how it�s done, Jim!
Those 3D printed parts will sure make a big difference, well done you!
VMF'06 - German Gamblers
JIM BAUMANN
Thank you all for your interest and kind words !
Progress is ongoing-- slow but steady now that the weather has turned more typically Northern European ( English !)
( wet, even wetter and then windy ) which in the absence of classic car activity does chain me to the model bench more effectively
Wikipedia entry on Bretagne.... broadly accurate.
https://en.wikipedia.org/wiki/French_sh ... gne_(1855)
but this caused me some thought and consternation...
The main battery of Bretagne used 36-pounder long guns, the heaviest available calibre, instead of the more modern 30-pounder long gun on which other ships standardised their armament. The aft of the ship was round and featured gun ports, like on Napol�on on her successors. Although she carried 130 guns of various calibres, Bretagne featured no less than 180 gun ports; this allowed the crew to reinforce the artillery on one arc if needed and time permitting, such as before a shore bombardment, and fire up to 80 guns on one target.
So far so good..... :smallsmile: :thumbs_up_1:
... but then this..... caused some thoughts and wobbles
The ultimate increase in French capital ship design, Bretagne increased the number of heavy guns on the lower battery to 18 on each side, from the 15 of the Bretagne of 1766 and 16 on the Oc�ans. In the original design, half of these guns were 36-pounder long guns, as to maximise firepower at the price of standardisation on 30-pounder long guns that typically prevailed at the time, the other half being 60-pounder Paixhans guns. The middle deck fielded 18 30-pounder short guns and another 18 Paixhans guns of 60 pounds. The upper battery was armed with thirty-eight 30-pounder howitzers. Two 50-pounders and eighteen 30-pounder caronades complemented the armament on the deck. This gave Bretagne a broadside of 2,924 pounds (1,431 kilograms), compared to the 2,400 of the original Oc�an design.
now then.... after consulting a number of experts in the field of French warships of this era....( cheers-- you know who you are...! :thumbs_up_1: :wave_1: )
( with considerably more knowledge and better reference libraries than I have.....
It would suggest the above Paixhan theory perhaps to be slightly flawed for my depicted era of 1856...? ==> as the sources consulted by the above exports of the period makes no mention of these having actually been installed ( at this time )...
checking the sparse selection of photos was inconclusive either way, and contemporary paintings ( these also inconclusive ! ) led me to the following decision!
For the sake of the models appearance....
( symmetry of gun barrel lengths and appearance )
To have the 1 st battery( bottom row) consist of all 36 pdrs ( as per first quote)
with the 2 nd Battery (middle row and 3 rd Battery ( upper row) consist of all 30 pdrs.
The weather main deck will features carronades and muzzle loading guns-as well as
' a brace of canon de 50 '
anyhow onwards to tangible things in 1/700
The image below shows the difference 'twixt 36 pdrs and the Paixhan shell guns ( shorter barrel and no muzzle flare )
( these are small items in 1/700! )
I hope this will vindicate my decision as above !
The very small gun-port lids feature a scale thickness and have the correct steps in profile on the underside.
( the upper batteries-- split into upper and lower lids are much smaller still!)
Noteworthy is the previously described gluing tongue
A trial install of a unpainted gun barrel into a selection of the apertures in the hull....
was encouraging in appearance !
It did also however reveal that all my initial drilling into the hull for the gun-ports......
( thread page 1 and 2) was not all of an entirely uniform depth... necessitating a test fit-and cutting to length of each barrel.
( ....up to 0.4 mm variation :scratch: -which does not sound much-
- but would equal to 280 mm in real-life 1-1 scale)
though its nothing that a quick swipe with a sanding stick cannot change! :cool_1:
The barrels that have been installed so far were bedded on to a dollop of white glue at the inboard end to give a cushion==> and an even and strong grab.
The white glue slower setting time also allowed tuning of the angle and heights of the barrels for some time! ( wiggle room time)
The gunport lids were installed using the handy and ( much! ) aforementioned glue tongues.... :cool_2:
.......and using a good dollop of white glue to obtain a secure joint
( the glue dollop ends up going up behind the inside edge of the PE brass square in the side of the hull--giving secure adhesion
Early days still-- but the look and effect is increasingly promising !
The lids--once set and tuned--will receive a slight wash and very very light drybrush
onwards on to more lids ... and then the 2 rows of 30 pdrs will be next !
Thereafter the ship will be mounted on her sea base-....
-.......as it is getting increasingly more delicate to handle with all the protrusions
held on mainly with my will-power !! :big_grin:
maxim
Post by maxim »
According to Winfield and Roberts (French Warships in the Age of Sail 1786-1861), the armament in 1855 was:
lower deck: 18 x 36-pounder, 18 x 22 cm No. 1 shell guns
middle deck: 18 x 30-pounder No. 2, 18 x 22 cm No. 2 shell guns
upper deck: 38 x 30-pounder no. 3
superstructure decks: 2 x 50-pounder, 18 x 30-pounder carronades
wefalck
Post by wefalck »
Those dimensions tally with my contemporary original sources for French artilllery of the time.
Jim, why did you set the guns at the lower edge of the gunports, for practical reasons? Normally, when the barrel is horizontal, they should be about in the middle of the gunport.
Eberhard
JIM BAUMANN
Well--it looks I will be pulling some guns.... shell shell
My guns are indeed not dead centre--it was intentional
( I reckoned that whilst not in action but under sail the guns would not be elevated
the position of the guns is in within lower third-- based on what's local to me... :big_grin:
do you ( all) think they need pulling > adjusting?
see Victory below
