USS Alaska - why?
EJFoeth
Re: USS Alaska - why?
Post by EJFoeth »
The North Vietnamese always demanded that both aerial and naval bombardment would stop before engaging in peace talks, but this never happened (until the end). I don't think they preferred aerial over naval bombardment or really saw the battleship as a particularly important threat (on the threat scale of being bombed all the time). Having a battleship within firing range is the same as having bombers doing flyby's overhead; not really inspiring if you want to talk peace.
Lesforan
Post by Lesforan »
I think we are pretty much in agreement here on the utility of battleships in the bombardment and fire-support role of littoral targets. Their strong points remain the same as always: ability to put massive amounts of ordinance on targets in short time periods; ability to do so with minimum exposure of crews to defensive fire; no risk of expensive aircraft; superior protection against attack.
The limitation of naval artillery vs. aircraft in terms of range has been addressed by cruise missiles. At some cost in airframes as these are not reusable. The possible use of armed drones may eliminate that problem.
One does not need a battleship to be a missile launch platform. Smaller ships can handle this role well.
Probably the biggest drawback to battleships is the crew size required. Were battleships to be put back into use, they would need to be up-to-date in terms of modern systems that would not require huge crews.
Since all warships are a compromise between speed, protection, and firepower, the Alaskas could be the basis of a modern equivalent vessel. The large guns needed for effective shore bombardment would require a large hull. The ship could be fitted with different missile systems for both attack and defense. There would be room for helicopters and fixed-wing attack drones. Automated systems as used on current missile cruisers could result in much smaller crew sizes than previous battleships.
Armor protection for these ships could be light and limited to that needed to resist counterfire from shore batteries. The large guns carried (maybe 12") would allow them to bombard targets while out of range from most shore batteries. Cruise missile defense would be provided by defensive missile systems, with CIWS for close-in work.
Les Foran
On the Oregon Trail
JWintjes
Post by JWintjes »
Although this will probably have catastrophic results, I'll nevertheless say it:
A couple of - what, years? don't know... ago, we had a similar suggestion, and Chuck suggested something that at the time I was sceptical about; nowadays however I think he's got an excellent point.
Modern coastal batteries - ie last-generation SPGs in the 155mm range with high mobility, burst-fire capability and base-bleeding LR shells - would probably make life impossibly hard for a ship the size of Alaska and with the protection of a heavy cruiser..
Let's assume you have one of these ships, and Mr. Evildoer uses his mobile coastal battery to rain tandem-HEAT submunitions onto the superstructure of your ship. It might still float afterwards, but it will probably be a charred, smouldering float...
Bottom line - I think Chuck's basic point, that modern artillery developments have made battleship-sized ships as coastal bombardment tools nearly useless, is spot on. If you want to lay waste to a piece of real estate on the coast, do some carpet bombing from 30.000ft+ above.
Jorit
PS: Yeah, shmasteroid, I said it - come and get some! :big_grin: :big_grin:
Filipe Ramires
Post by Filipe Ramires »
JWintjes wrote:PS: Yeah, shmasteroid, I said it - come and get some! :big_grin: :big_grin:
NASA reports moon size round object approaching Earth....!!!!! :heh:
"Build few and build fast,
John Fisher
Lesforan
Post by Lesforan »
Jorit,
Modern 12" guns afloat vs. modern 6" guns ashore. Where would the "rain of fire" come from if the ship stayed out of range of the shore guns?
The ship should be able to pinpoint the shore batteries by radar-tracking the 6" shells to their point of origin. Even mobile batteries can't move that fast.
Les Foran
On the Oregon Trail
JWintjes
Post by JWintjes »
Lesforan wrote:Jorit,
Les,
three problems:
a) The 6" technology is already there; modern 12" guns are not; if we want to compare technology that does exist, it's latest-generation 6" against WW2-generation 16".
b) A latest-generation SPG has scoot'n shoot capability; PzH 2000 for example can go into position, fire 3 rounds and move out of position again within 90 seconds; scoot to the next position, fire another stick of 3 rounds, and so on.
c) Already existing 6" LR shells have around 40 km range, about the same as the max range of a 16" gun. Of course you could design a 16" LR shell, but already over that distance the shell has, if I remember correctly, a flight time of roundabout 80 seconds - which means that your target won't be there anymore when your shell hits the target area. Now, that's just one SPG; obviously, they always come in groups of three or four, so what you essentially have to fight sequences of 3-shell-bursts raining down on you.
Let's just say I'm sceptical. The thing is, a SPG is not as inexpensive as it was decades ago, but it is not by any stretch of imagination a high-value target. If you lose a half-dozen SPGs and in turn hammer your battleship/cruiser/whatever to dust, you have a maior PR victory.
I'm not at all against mounting a gun that's bigger than 6" on a ship; but I seriously wonder whether putting one modern 8" or even 10" gun on a modern frigate-sized platform might be a more useful option. In fact, the German navy has done some trials with mounting a 6" SPG turret on a frigate instead of a 3" OTO gun; now, that ship was a standard frigate, helodeck and all. Let's assume you have a multipurpose ship that could carry two of these - quite a considerable coastal bombardment platform, I'd say.
Jorit
Lesforan
Post by Lesforan »
Jorit,
Yes, I'd say so.
Les Foran
On the Oregon Trail
Cliffy B
Post by Cliffy B »
JWintjes wrote: a) The 6" technology is already there; modern 12" guns are not; if we want to compare technology that does exist, it's latest-generation 6" against WW2-generation 16".
Modern no, but the USN does have 12" guns that are 1980's vintage that were designed and proven to fit in a Des Moines Class 8"/55 turret. They would be reduced to twin turrets but they worked. The USN axed them though due to politics. Dave knows a lot more about those guns though. Could you weigh in on them Dave?
JWintjes
Post by JWintjes »
Just found the link on navweaps:
http://www.navweaps.com/Weapons/WNGER_6 ... rg_pic.jpg
That's a feasibility study. Problems encountered were apparently software integration and insufficient structural stability of the hull to withstand the stresses of sustained firing; both don't seem to be insurmountable.
Some sort of coastal assault frigate mounting two of these turrets should well be possible.
Jorit
Busto963
Post by Busto963 »
Les,
three problems:
Jorit
Nooo!
The only reason the fleet is within range of counter battery fire is that air supremacy has been established; ergo this is no a "duel" - it is a mugging. And if the fleet has done its job - it will be serving up the pain.
Long before the ships are within range - the entire area of operations will be subject to intense scrutiny from space, Reconnaissance planes, and possibly spys. Then the fleet, supported by bombers, SSGNs, tacair, and possibly conventional ballistic missiles; will launch massive cruise missile, drone, air strikes, attacks to destroy/neutralize enemy radars, communications, command posts, ammunition depots, troop concentrations, and of course airfields. The enemy communications links and targeting data will be subject to jamming, cyber attack etc..
The only reason the SPG battery has survived this strike is that it has been hiding (this itself is a victory for the fleet). If and when the enemy turns on his radars, launches reconnaissance aircraft and orders his SPGs fire, or move, they will be subjected to intense aerial interdiction from drones, or strike aircraft, and counter battery fire from the fleet.
And the ships are also shooting and moving constantly *as they fire* and probably faster than the SPGs can displace, and probably with less restrictions on maneuver than the SPGs, which have to use bridges, take specific roads through the city etc.. This makes the ships a tough target for the SPGs.
And btw, enemy artillery is always a high priority target.
Lesforan
Post by Lesforan »
Works for me!
Les
Les Foran
On the Oregon Trail
navydavesof
Post by navydavesof »
When considering any practical use of gunnery/artillery, the above arguments are only true when considering peer competitors. Peer competitors such as China or Russia�or those very proficient at using Chinese or Russian systems�are the only powers capable of combating a ship conducting gunnery strikes with any kind of effective counter battery fire. Somalia won't be conducting intricate counter battery fire. However, exploring the rational of a rain of 155mm fire requires the following.
A paramount concern with any kind of ordnance-on-target issue, being either artillery, missiles, or TACAIR, is how long it takes for the assets to arrive on target. A lot of the time this turns into a speed over range issue. Projectiles will always arrive on target fastest, but they still take time to get there. This is where you have to either shoot at where the target is going to be when your munitions arrive. If the target is still, then it's not much of a problem. However, a moving target like these SPGs or a ship are concerned, you have to figure out where the target is going. The 155mm coastal counter battery fire would not be able to find the ship attacking its coast, especially from over the horizon. Even the GPS guided LRLAP projectiles would be of no use here. You would must have a guidance system that can continue to change course in flight and follow the target.
This is where you must have laser guided rounds. Laser guided rounds need a laser designator/illuminator somewhere to designate the target. This requires some sort of vehicle mounting a laser designator, aircraft most likely, to designate the ship. UAV is the best way to do this. However, this is a two way street. The attacking ship firing guided rounds will most likely have UAVs of its own operating within eye shot of the battlefield. Then it boils back down to a question of who gets the first shots in. Who will be more successful? The ship will most likely have a better chance of detecting and shooting down the coastal battery's UAVs or helicopters doing the designating.
This is not to say that the ship will always win, but since the ship is an autonomous machine mounting radars that can detect foot ball sized targets from hundreds of miles and carries a substantial AAW capability, the ship holds a huge advantage over the shore batteries. If talking about shore batteries vs a battleship, even if the shore batteries begin to land shots, the battleship will be able to operate after sustaining a huge amount of damage whereas the shore batteries are rapidly neutralized with one-shot-one kill.
This also depends on a great deal of variables, and each case can be considered.
Busto963
Post by Busto963 »
navydavesof wrote:When considering any practical use of gunnery/artillery, the above arguments are only true when considering peer competitors. Peer competitors such as China or Russia�or those very proficient at using Chinese or Russian systems�are the only powers capable of combating a ship conducting gunnery strikes with any kind of effective counter battery fire. Somalia won't be conducting intricate counter battery fire. However, exploring the rational of a rain of 155mm fire requires the following.
Excellent points.
I think that current thinking is that SPGs will *not* be dueling ships - if a country feels threatened by a fleet, it is going to respond with shore based cruise missiles, or ballistic missiles with conventional warheads, or air strikes. And then of course there are the SSKs and mines.
I do not think that the fleet automatically wins, in this scenario, in fact, the defender can have a tremendous advantage - especially with submarines. As always, the attack assumes overwhelming fire against the defender. There are no duels in modern warfare.
navydavesof
The Alaskas were meant as a super heavy cruiser. They were supposed to chase down cruisers of any sort and sink them. There is no other answer.
On a modern level, they would be the most capable new-construction ship the USN could build. Since a BB would most likely not be built, a CB or CC would take its place with modern gunnery techniques, missile emplacements, radar equipment, and UAV/H-60 embarking capability.
The CB/CC would be most capable. Seeing how we could produce TWO, and maybe three to four 30,000 ton CB/CCs for the cost of ONE 100,000 ton CVN, we would benefit greatly from the CB/CC. The CB/CC would provide SIX 12" guns per ship as opposedd to the 60-90 aircraf on the single CVN. The deck, side, and below water protection would harden it against all modern threats.
A 12" gun armed ship would provide SUPERIOR and dominating NSFS for the foreseeable future. All other concerns aside, NSFS is paramount in modern warfare. Next, it would provide a heavily survivable platform to fire well over 120 cruise missiles.
This type of ship is heavily needed and utilized aboard the USS North Carolina would satisfy the Navy's needs for over 25 years.
Lesforan
Post by Lesforan »
NavyDave,
I agree with your statement, but I don't understand your statement concerning the USS North Carolina.
Reading through this thread again a year later, something occurs to me. If both sides are using drones as laser-designator aircraft, perhaps a need exists for anti-drone drones. Specialized drones carrying small air-to-air missiles to take out the enemy's spotter drones. This would be perfectly analogous to the first use of fighter aircraft to take out the other side's spotter planes.
It also seems to me the biggest threat from shore-based defenses will come in confined waters, probably from heavy anti-ship missiles.
As far as mobile shore-based artillery verses bombardment ships, this would involve moving targets out of sight of each other.
Flight time of shells from either side would make hits very difficult. If it is hard to predict the position of a moving target at time of impact, I would think it would be almost impossible to predict the location of a target that is not moving at the time of counterfiring. A moving target moving on a bearing is somewhat predictable. A stationary target is free to move in any direction after being fired upon. A target designator system and steerable munition would be needed to ensure a hit.
Les
Les Foran
On the Oregon Trail
Russ2146
Post by Russ2146 »
:scratch:
Les, I think Dave said that we would deed a designator and laser guided pojectile.
navydavesof
Russ2146 wrote::scratch:
Yes. Moving targets no longer provide an advantage. As long as there is a UAV in range, you can follow a vehicle with a laser designator. The 155mm round fired from the ship over 30nm away will chase down a maneuvering target.
Lesforan wrote:I agree with your statement, but I don't understand your statement concerning the USS North Carolina.
Thanks. I wrote too quickly! I am so sorry!!! Reactivating any Iowa BB or even te NC would be significantly less money than a new build CB/CC, and BB-55 would be worth the money you could put into her to get 30+ years out of an existing BB. However, getting a 35-45 year ship with totally new construction and technology would be great AS LONG AS it is constructed with the heavy armor and compartmentalization it is intended to receive. Even the Chinese ABMs would be stopped by the armored decks of the new-build BB/CB/CC. Even with the NC or an Iowa, one of these ABMs would be detonated by the ship's main deck and then stopped by the second deck horizontal armor. Then the ship could proceed to do its buisiness.
Perhaps! There are now 2' long air to ground missiles that UAVs can mount. Air to air will likely be capable as well. However, a RAM mount could take it out, too.
Oh yes, and this is why the WWII deck layered armor and Littorio type side armor is excellently suited against ASMs.
As stated above, no matter where the target goes, laser guidance follows the target until projectile impact.
carr
Post by carr »
Lesforan
Post by Lesforan »
Bob,
I'm not sure myself about mid-course correction capability for conventionally fired shells. But don't overlook the fact that the ship would not be engaging the target with only one gun.
A ship of the type we are discussing would be equipped with 6-9 heavy guns, in at least three turrets. A good fire control system could send each shell to a different point of impact within the area that the moving target would be capable of reaching after time of firing. This would expand the size of the "laser basket" to include 6-9 baskets. Presumably, there would be overlap of these zones, allowing more than one shell to strike a single target.
Unless the moving target is heavily armored, shells set for low-altitude air burst would also greatly expand their destructive radius.
Les
Les Foran
On the Oregon Trail
Lesforan
Post by Lesforan »
Navydave,
My argument goes back to a view I posted on this forum many years ago. Based on an estimate I read in "Conway's History of the Ship", a heavy conventional anti-ship missile has about the same effect on a ship as a 14" shell. So, armored ships protected against 14" shellfire would also be protected against heavy anti-ship missiles. Presumably, an upstart country with nuclear weapons would not want to expend them on targets such as ships.
Putting this into modern context, since there are no more heavy-gun warships to engage, modern warships are not protected against 14" gunfire. The traditional thinking that warships need to be built to withstand attacks from similar warships has carried into the postwar era. With the proliferation of guided missile-armed surface ships, this theory has fallen by the wayside. Any country's missile ships are vulnerable to any other country's missile ships. The only exceptions I can think of are the Russian Kirov-type "battle cruisers" and the USN missile carrying converted battleships.
I think this fact represents a flaw in our thinking. I think the Russians were onto a good thing in building these missile ships, and we should have followed their example. You could argue that the converted Iowas were the counter, but these remained old ships while the Kirovs were new construction.
Like a lot of things, in the end it comes down to money. Aside from the matters of metal fatigue in the hulls and conversion costs, a major problem with using these old capital ships is the number of crew required. A new-build ship would have its build cost somewhat offset by having its service life begin new and having a smaller crew. Also, it could be built with a hardened superstructure for better survivability.
Les
Les Foran
On the Oregon Trail
