Sleepwalker wrote:...You can scribe also vertical lines at hangar deck plating...
That�s something I still have to do, I know...
I couldn�t find any (decent) shell plating details or plans for any Casablanca CVE. Those that came with the AOTS book on the Gambier Bay are almost useless, in my idea. So, I had to use some "artistic license", coupled with some real CVE hull photos. One of the things that you�ll imediatelly notice, if comparing with other "heavier" warships, is that the plating is very thin, almost impossible to see. On the distance, you can only see "lines" across the entire hull, while on a battleship, you can easily see the different plates.
I still have to finish the propellers shaft housing and the bow, and then, I�ll start adding some paint....
Thanks for the comments...
Hello Jose!
Manila is going ok, and if you think that your plating is needing to get thinner , what about using litho, as ARH does? If you apply litho to the "recessed" plates, the others will get thinner........... just some sugestion, but I think your plating is very good...........
Nice regards: Jimmy
p.s. quero dizer que se as placas mais externas te parecem mais grossas, � comparara��o com plantas, vc pode afin�-las aplicando litho nas placas mais profundas.� s� sugest�o, porque mexer num servi�o j� pronto pode n�o ser bom.....
hEY jIMMY, vc me parece ser brasileiro, escreve t�o bem o portugu�s.....
Hei Chai�a por onde andas meu velho??
Ah, o Bismarck est� sendo erigido aqui no meu estaleiro.
Abra�os
norberto1 wrote:hEY jIMMY, vc me parece ser brasileiro, escreve t�o bem o portugu�s.....
Abra�os
Hello Norberto, yes, I'm brazilian... como esta o andamento do Bismarck? Se precisar de ajuda me escreva em meu mail........The "Manila' for Chaica is very interesting and he is progressing and we follow........ Por que a maior dificuldade de levar adiante um modelo � enxergar as partes.............. send you my best regards, from Brazil....
Jmmy
Make your influence positive!
Breton Fisherman's Prayer
Jose Chaica wrote:I decided to use a different approach to the hull, rather than those which are usually presented here. Instead of covering the hull with fiber glass and/or resin, I decided to cover the whole hull in plastic ONLY, for at least two reasons...
OMG! I'm a dumb Why didn't I think of doing that to cover a hull!? I know this is a quote from an older post and I'm slow about keeping current with builds anymore but this needs to have attention called to it once again.
After 6 months "laid-up", it�s time to re-start work on the Manila Bay...More pictures soon....
Looking forward to it!
Too much time modelling the same subject, has the tendency to "burn" some fuses inside your head. When I sense that something like that is about to happen, I have to stop, otherwise, I won�t do anything good.
Cadman wrote:Something tells me that after this build is done, that you may never want to see another 1/72 P-47 again.
Well...I must say that up until now, I�m finding Academy�s 1/72 P-47 Razorback a very fine model. I�m already in the process of glueing all the wing halves together, and I must say that assembling this model, is a good experience, as it is a little,simple but yet reasonable detailed kit. I�m not experiencing any major flaws......Ahhhh, and with all this 37 planes, I must be experiencing the same kind of feelings that Mr. Henri Ford had, when he looked at his first assembly line...
I was busy during the last 2 weeks, so I couldn�t advance much further on Manila Bay�s hull, but last weekend, I managed to apply some putty over the plastic joints.
Always wear mask !!! Don�t ask me how I found that out !!!!
After a couple hours of work, this is the result...
I still have to apply some more putty over some "rebel" joints, and after that, its time to do a LOT of sanding !!!
