Calling all Kriegsmarine Zerstörer fans
Dick J
Re: Calling all Kriegsmarine Zerst�rer fans
Post by Dick J »
thomastmcc wrote:is there any scale plans of the z class in 1/72 ?
You will have to find another way to specify the class. The "Z", as the thread implies, stands for "Zerst�rer" which is German for Destroyer. There is no single class identified as "z class".
thomastmcc
Post by thomastmcc »
sorry mate narvik class ..
Dick J
Post by Dick J »
thomastmcc wrote:sorry mate narvik class ..
I presume you mean the Type 1936A destroyers, also called the Z-23 class. (Z-23 to Z-30) "Narvik class" is an unofficial designation that came about because a number of them unofficially adopted the names of destroyers lost at Narvik. But from Z-23 on, none received any official designation other than the "Z" number.
biggles2
Post by biggles2 »
Could anyone confirm if German destroyers on the Spanish Neutrality Patrols had their flotilla numbers on the hull as per pre-war photos? And were they the same numbers as seen on these photos? :wave_1:
biegacz90
Post by biegacz90 »
Does anyone know anything about the pipe on the forward funnel? Were they on the 1934 only?
biggles2
Post by biggles2 »
Different shipyards where the destroyers were built used different piping configurations, if that's any help. :wave_1:
Dick J
Post by Dick J »
The funnel pipes appeared on both the Z1 and Z17 classes. All 6 Z17's were built by Deschimag, Bremen and had the same pattern of pipes. The patterns on the 16 Z1 class differed by builder. In your photo collage, the top left shot marked as "Z17?" is actually one of the Z1 to Z4 group. This group was built by Deutsche Werke, Kiel. The Z5 to Z8 group was built by Deschimag, Bremen. The Z9 to Z13 group was built by Germania Werft, Kiel. And the Z14 to Z16 group was built by Blohm & Voss, Hamburg. The Z9 and Z14 groups also had pipes on the after stack. After 1943, a number of the surviving units no longer had the visible pipes. I have no documentation to determine whether the pipes were enclosed within a modified stack or if they were simply eliminated. Their funnel caps were shortened at the same time.
biegacz90
Post by biegacz90 »
Thanks it really help me. I don't have to make pipe for my Z-43 model :big_grin:
Haijun watcher
Post by Haijun watcher »
Ahem, would someone please respond to my post below?
Haijun watcher wrote:Dick J,
Thank you very much for your feedback. Still, upon doing a lot more digging on the internet, I decided that I will be instead building the kit as Z-39, but during her stint in the Gulf of Finland.
It's because at the time, she also sported her own unique dazzle camouflage, as shown in the picture below:
Z37 is the top one, Z39 is the bottom one.
Source: Marineart.it
And here's an actual photo of Z39 during her stint in the Gulf of Finland in 1944.
Source: Book: German destroyers of World War II by Gerhard Koop, Klaus-Peter Schmolk
Still, both photos above only show the port side of the ship. Does anyone here know if the starboard side of the ship was identical?
If not, could any of you please point out a source which shows the starboard side?
Dick J
Post by Dick J »
Perhaps nobody answered because, like me, they haven't seen anything anywhere that shows the other side. I wouldn't mind seeing that myself, though.
Haijun watcher
Dick J wrote:Perhaps nobody answered because, like me, they haven't seen anything anywhere that shows the other side. I wouldn't mind seeing that myself, though.
Would the starboard side simply mirror the port side pattern? Or mirroring paint scheme patterns is not really common in German warships?
maxim
Post by maxim »
According to Leon and Asmussen, German Naval Camouflage 1942-1945 these scheme was usually used on supply ships, minelayers and merchantmen - and Z 39 was an exception. I have not found any comment for the other side. I would assume that it was identical.
biegacz90
Post by biegacz90 »
step by step I'm preparing to paint my Z-43 model and I have a question
Does anyone know the color of rafts? In gallery I found many zerstorer and the rafts were in many color, like gray, green, yellow, brown. And north star are producing black. So which color is correct ? :help_1: :anyone:
robertmelvin
Post by robertmelvin »
thomas
I would doubt a 1/72 scale kit, just looking at the relative size of my Revell P.T. 109 build. But, that would be a great subject, or set of subjects, or something in 1/144 or even 1/200. I built up Revell's 1/144 Fletcher and it is quite impressive in size. Even at 1/200 it would a big ship model. In fact, if the 1/200 trend is going to continue and flourish, I think they are going to have to offer up some smaller ships besides battleships and aircraft carriers. Most of us don't have a lot of space to display many, if any, of those things, let alone the cost. But, some DD's, DE's or even cruisers would be good candidates for 1/200 treatment. A 1/200 Samuel B. Roberts or U.S.S. Johnston anyone?
Bob
thomastmcc
thomas
Bob
thanks bob a 1/72 scale plan would be better for me ..
thomas
Maarten Sch�nfeld
Post by Maarten Sch�nfeld »
When modeling these German destroyers from scratch the book 'Deutsche Zerstoerer 1935-1945 - Vom Original zum Modell' is a must. The book contains elaborate original and model plans. Sorry if you can't read German, but you'll have to work your way through that, if you want to tackle a subject like this in earnest.
http://www.das-geschichtsbuch.de/produc ... -1945.html
With the book a set of plans is also published:
http://www.das-geschichtsbuch.de/produc ... a1099286ae
However, the scale of these plans is predominantly 1:100, so for building in 1:72 you will have to do your math, and it might be a good idea to have yourself some enlargements made at your local copy shop, provided they can handle the size of these plans.
By the way, it helps if you acquaint yourself with the right nomenclature regarding German destroyers, it helps when you are searching for information: https://en.wikipedia.org/wiki/German_Wo ... destroyers
Roger Whittaker +9/13/2023
maxim
Post by maxim »
Mike W
Post by Mike W »
biegacz90 wrote:step by step I'm preparing to paint my Z-43 model and I have a question
That's also a question I would like an answer too. The only info I have is in a German Naval camouflage book, which states they were sometimes painted over when camouflage was applied but nothing to say what the actual colour was. They seem to be mostly depicted as some kind of Sandy-yellow colour.
thanks
Mike
Mike W
Post by Mike W »
Does anyone know of an easy fix that requires minimal surgery for the incorrect bridge on Trumpeter's 1/700 Z-7? The problem is that they have provided a bridge with rounded front when in wartime it would be a square bridge.
thanks
Mike
biggles2
Post by biggles2 »
Mike W wrote:Does anyone know of an easy fix that requires minimal surgery for the incorrect bridge on Trumpeter's 1/700 Z-7? The problem is that they have provided a bridge with rounded front when in wartime it would be a square bridge.
thanks
Mike
According to New Vanguard (Osprey) "German Destroyers 1939 - 45", Z7 (Type 34A Paul Jacobi Class) was built with a square front bridge, starting with Z6. So Trumpeter got that wrong to begin with. The Trumpeter model is more representative of the preceding class (Type 34) Z1 - Z4, and Type 34A Z5, pre-1938, after which they were all refitted with a square bridge. Maybe you could kit-bash a later date destroyer bridge. :wave_1:
