Bob sent me some photo's he took .Here are a couple of the sharp spine at the stern .It was acompleshed by inleting wire in the plug .This was a charecteristic of the T3s and had to be put in .
Richard J OMalley wrote:Thank you for your comments .How did you know about the upcoming Slava build ? Do you have spies ?
Hi Richard,
No spies, but just the eyes.
You had mentioned about your plan to build one under topic 1/72 scratch build Slava class cruiser by Andrew (Ticonderoga)
Mayu
Hi Richard my appologies for not responding sooner but I have just caught up on your T3 hull , you make an excellent job and when fully fitted its a model that will generate some considerable interest.
Hi
Had some problems getting the rear part of the mold off hull #3 so it was time to build a better mouse trap .I had to cut up the stern mold to get it off the hull .It was getting beat up hitting it with a hammer to get it to slide back .The new back half will be in two pieces making it a four part mold .I will be putting in cylinder head alingment dowles to keep it all square .The new hulls will also have the prop shaft housings pre drilled and a brass tube all ready installed .
My friend Nelson came over to help and brought his camera so here are some photo's .
This is were the new stern will be split making it a upper and lower mold . Nelson cut out a template then I transferd it to two pieces of formica .
Bob did a running test on his T3 tanker
Displacement about 41 lbs
Hull and motors 16 lbs
Electronics 1 lb
Batteries 16 lbs
Lead ballast 8 lbs
Bob says it will twist within it's own length,has a large turning radius using rudder alone and is quite fast for the amount of weight .
Hi Phil
My camera is MIA and to top it off I can't post pictures on to photobucket .Nelson comes over now and then and brings his camera then post for me .Thanks for checking in !
