1/144 Kiev by Dave Wooley
russclark
Re: 1/144 Kiev by Dave Wooley
Post by russclark »
good looking k 25,s dave,nice work on the roters.when i scribe thin brass or use a pounce wheel the brass always kinks and bends :heh: .do you have this problem and if you do any words of wisdom :thumbs_up_1:
Post by Dave Wooley »
russclark wrote:good looking k 25,s dave,nice work on the roters.when i scribe thin brass or use a pounce wheel the brass always kinks and bends :heh: .do you have this problem and if you do any words of wisdom :thumbs_up_1:
Hi Russ Ii must confess that the rotors came with the resin moulding. I have used brass sheet but prefer Litho . As ARH has pointed out so well you can scribe . wheel , mark and bend litho but it is difficult to solder where as brass is so easy .
Dave Wooley All the best to you Russ and have a relaxing break . but keep the build going!!!!
Neptune
Post by Neptune »
Incredible work once again Dave.
What colour did you paint the canopy windows? It doesn't even look like painted! Great job on this special helo. The line of Yak's is pretty impressive and the deck of the ship too of course!
The merchant shipyard
Hi Roel The canopy windows on the Ka25 are covered with a Humbrol metallic matt 56 . Having seen the front end of a number of photos of the Ka25s covered in canvas I thought of doing that with the folded rotors, just a thought ?
Thankfully the Yaks , have a clear conopy . I also noticed in various fly by shots on Kiev a small mobile crane, the odd truck, and a small fire fighting tender any closer in pictures of these vehicles? Must get back on the build proper , still quite a collection of outstanding jobs . I haven't even completed the ships boats yet ? :doh_1: :huh:
Dave Wooley All the very best to you and have a good festive break :thumbs_up_1: :wave_1:
GTDEATH13
Post by GTDEATH13 »
I have these two photos from Novorosisk...
The colour one is for colour reference and the other is the closer I have...
Here is one from kiev...
NIKOS (NICK)
GTDEATH13
Post by GTDEATH13 »
Found some more...
These are from Kuznetsov but the vehicles look pretty much the same...
ADMIRAL KUZNETSOV (138).jpg (8.79 KiB) Viewed 1846 times
Got some more from Kuznetsov if you are interested Dave... :wave_1: :wave_1:
hope I helped...
NIKOS (NICK)
Hi Nick Every picture helps thanks for posting those . I wasn't to sure of how the foam tender looked but I have a better Idea now. More photos of the deck vehicles are always appriciated. :thumbs_up_1: :wave_1:
carr
Post by carr »
Thank you Bob :thumbs_up_1: :wave_1:
Yannis Karystinos
Post by Yannis Karystinos »
Dave i hope these will help.
Regards
Yannis
Deck vehicle 08 kuznetsov.jpg (26.94 KiB) Viewed 1606 times
Close ups , "wonderful" Just what I am looking for , thank you Yannis . If there are any other pictures around showing deck vehicles , close in if possible I would appriciate the help . :woo_hoo:
Yannis Karystinos
Glad to be of help :wave_1: .
I keep sending photos of the Kuznetsov's vehicles because they seem to be of the same type with Kiev's. I tried to crosscheck that but the Kiev's pictures i found are black and white and show only silhouetes which match with Kuznetsov's.
Dave I think it's a good idea to also use White Ensign's set of deck vehicles for Kuznetsov as reference.
http://www.modelwarships.com/reviews/pe ... equip.html
Best regards
Yannis
Deck vehicles 12 Kuznetsov.jpg (50.55 KiB) Viewed 1535 times
Deck vehicles 14 Kuznetsov.jpg (18.9 KiB) Viewed 1531 times
boatman
Post by boatman »
Well dave i keep lookin at your build an it just seems to get better an better i only hope my nimitz turns out this excellent
chris
Hi Yannis thank you this is just what I need. Once again all this will go along way to help. Using the information you sent down previously I have made a start on three tow vehicles. I drew up a working sketch of the parts and this is the result. I know it�s hard to see a tow truck in this collection of styrene bits But it is there ready to assemble . No doubt there are parts that will require more thought but as ARH has often said one picture speaks a thousand words. Thank you all for your impute it really does take the guess work out of the job . .
boatman wrote:Well dave i keep lookin at your build an it just seems to get better an better i only hope my nimitz turns out this excellent
chris
Hi Chris From what I have seen of your Nimitz build so far it is going to be a stunning model when completed.
Yannis Karystinos
Hi Dave.
When you combine information with skills the outcome is always beautiful. I�m happy you found the info I sent you useful and I can see you wasted no time in building these towing vehicles. Your ability to break down complex shapes to simpler ones always amazes me. If you need anything else regarding the Kiev I will be more than glad to assist.
Best regards
Yannis
Yannis Karystinos wrote:Hi Dave.
Best regards
Yannis
Thank you Yannis
I trust you all had a good break and enjoyed the holiday . Good to be back .
As mentioned previously work began on three tow vehicles .Once again this
does diverge away from the ship but it is very relevant to this ship .
The tow vehicles are fairly simple in design and this helps when scratch building.
A start was made on the assembly of the vehicles bodies using the pre cut parts.
The lower part of the wheel arches are fitted into place and holed drilled to accept the axels.
With the inner axel { aluminum tube } set into place with in the vehicle body
work could commence enclosing the top and sides
With the body covered over and wheel arches completed one set of tires
are fitted to each inner axel . The seat and raised base is also prepared
along with the steering column .
Fillers is applied to the top and sloping sides and sanded down .The tow is now
ready for spray painting .
I was slightly uncertain as to the shade of the colour used , as some photos
show a pale yellow others a bright yellow . Kiev did in fact have her tow
vehicles in bright yellow with orange chevron shown on the top surface .
The final stage was to prepare the orange chevrons using a small section of
decal sheet painted orange. { Thanks Roy for the idea} The tires are in fact
painted very dark grey .
Here is some idea of the scale of this tiny { for me any way} vehicle .
I also managed to make the pin , so the tow bar will fit into place on the tow vehicle .
The tow vehicle with a Yak 38 . All I have to do now is complete the other two?
Work has started on finishing the detail work on the walkways then work can
begin on installing all the ships rails. The follow on project to Kiev in almost in
place and should be an interesting scratch build but for now back to Kiev and more to follow .
Bill Waldorf
Waldorf Productions
Waldorf Productions
Post by Bill Waldorf »
Simply amazing!! The methodical methods you use are an inspiration. Lot's of parts on a small vehicle. I don't think alot of folks realize the time it takes to pull off a build such as this, not to mention the patience. Mine wears thin occasionally! Really great job, Dave! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
roy allen
Post by roy allen »
I don't think you should have posted the pic of the tow vehicle next to the tin of paint?
Now i know you can build tiny things i might start to badger you to build a static 1/700 or 1/350 waterline model for our table at Telford 2010 :heh: :heh: :heh:
Ace work Dave :thumbs_up_1:
Roy :wave_1:
