1/350 RICHELIEU Dakar 1940-41
- Jeff Dundee
Re: 1/350 RICHELIEU Dakar 1940-41
Nice work Nicolas, your EZ Line should be at your House by Tuesday, wednesday in th� worst case.
- Christian M.
- Location: Cologne / Germany, sometimes Poznan/ Poland and Chessington/ UK
Hi Nicolas,
good to see you back. I was unfortunately by my own very long "off" after a car accident, but I re-start again soon too with a new project.
Good to see that you are working further on your Richelieu now.
- Kodai
Joe Simon
She looks great!
- LE BOSCO
thanks gentlemen for your kind words
christian I hope that you have health et and i am happy of see soon here your new work
for continue the work ,I start by the two pulleys (12 parts) present under the charge masts .
the chains with hook are made by Jean .the same parts ready to be painted .the red arrow indicates the "compas magnetique �talon" (I do not know the name in English)
I also prepare oars for painting (white ensign and Jean Mahieux)
I received my wire EZ line, So I took care of pulleys and cranes cables
I took advantage of the characteristic of EZ wire (elasticity) to carry out the cabling on my workshop .I took the dimension between the place where the pulleys are attached to the castle and the tip of charging mast((55mm )so I cut the wire EZ at 40 mm .
the wire longest will go to the winch drum. and same mounting stretched at 55mm
the same installed
before placing the second crane ,I glued the "compas magn�tique �talon "
and install from photographs, empty cradles, crates, tarpaulins, oil barrels and wooden planks
Contrary to what I thought, this area, seemed to be empty the day of the catapult testing
see you soon for the next progress
cheers
Nicolas
the same installed
cheers
Nicolas
EJFoeth
Nice clean construction!
- LE BOSCO
HI gentlemen
thank's EJFoeth
Pics of the completed area after laying the second cabling
happy with the result and I can go to another area ..
cheers
Nicolas
thank's EJFoeth
cheers
Nicolas
- Jabberwock
Zut alors!
Jabb
Jabb
HMS Hood, the big one!
- LE BOSCO
very astonishing commentJabberwock wrote:Zut alors!
cheers
Nicolas
Brilliant work! I love how you approach your work and the solutions you employ to get the results you want.
- LE BOSCO
Oh thank a lot Martin
it's true that I always look for solutions for the result that I want....this may be why my project is too long in the time
cheers
Nicolas
cheers
Nicolas
Joe Simon
She is beautiful!!!
- Kodai
Impressive, very impressive...nice work LE BOSCO....
Congratulation..
regards.
Congratulation..
regards.
Uchuu Senkan Yamato 2199.
- LE BOSCO
thank a lot at you both
a progress very soon
cheers
Nicolas
cheers
Nicolas
Pierre Marchal
j'ai beau chercher,je ne reconnais pas le bismark
- bgire
That's because you missed the "c" before the "k"Pierre Marchal wrote:j'ai beau chercher,je ne reconnais pas le bismark
_Bruno
- Christian M.
Only 1 word is fitting for this... P E R F E C T !!!
- LE BOSCO
HI gentlemen
Pierre ,yet with all the efforts that I make, to make a resembling model
thank'a lot Christian
today no fof naval ...but of the railway
indeed there is "some time" I had prepared the locomotive and car for the diorama,but nothing had been completed. now this has been done
in the order ,the locomotive
then the gondola cars loaded with crates, barrels (red wine for the "cambuse"? ) planks
the covered cars
and finally
some cars are not right, because my background has small undulations;)
see you soon for the next step
Nicolas
nicolas
the covered cars
and finally
Nicolas
nicolas
- bgire
Oh I see... I was thinking this might have been the effect of the wine barrels spilling somethingLE BOSCO wrote:some cars are not right, because my background has small undulations;)
_Bruno
- LE BOSCO
HI Brunobgire wrote:... I was thinking this might have been the effect of the wine barrels spilling something...
may be that the alcohol vapors,have not arranged my vision
cheers
Nicolas
