1/144 Kiev by Dave Wooley
Re: 1/144 Kiev by Dave Wooley
Post by Dave Wooley »
Thank you Atom 44 your help is appriciated. :thumbs_up_1: :wave_1:
As mentioned in my last post I�ve been busy working once again on a wheeled vehicle , as seen aboard Kiev . The vehicle in question is the GAZ foam tender as seen here.
further photos reveal the detail needed to form the cab and truck bed .
Following my usual pattern a simple drawing was made that allowed all the parts to be cut to size and prepared ready for assembly.
Dave Wooley more to come. :thumbs_up_1: :wave_1:
ARH
Post by ARH »
Looks like another great build coming up, will it be working Dave, you may need it to put out the fire, your working that fast, :heh: :heh: :heh: :thumbs_up_1: :thumbs_up_1: :wave_1: :wave_1:
Simple but effective.
ARH wrote:Looks like another great build coming up, will it be working Dave, you may need it to put out the fire, your working that fast, :heh: :heh: :heh: :thumbs_up_1: :thumbs_up_1: :wave_1: :wave_1:
Hi Ron It me amazes that after 4 years building I can still stoke up the "fires of enthusiasm". :woo_hoo:
russclark
Post by russclark »
your the man dave,how you can draw up a set of templets from a drawing is un :thumbs_up_1: real
raivo
Post by raivo »
Some time ago I think to build gaz-66 but I to change my mind. I start build "Vanya".
http://www.kotelnikov.net/downloads/
There is two gaz-66 models good details.
H Raivo Thanks for your help much appriciated. It seems that I'm not to far out with the build
Yannis Karystinos
Post by Yannis Karystinos »
Dave i just found these.
I hope it's not too late.
Best regards
Yannis
Hi Yannis These shots are just wonderful and it's never to late . Thank you so much for your help .
Working on this GAZ foam truck is an interesting departure from working
on the ship and was some what of a challenge .
The basic idea was to lay the cab profile and the flat bed on sections of
Evergreen H section .
The next stage involved the building up of the cab, which included back
and internal bulkheads .It is at this stage that the Bed is separated from the
cab to allow the back of the cab body to be fitted and lined up accurately .
Next the middle section which along with the cab profile will form the support
for the body .
Progress thus far and parts to be added.
Four axle supports are fitted
Each axle is fitted into place to test symmetry and clearances.
The lay out so far with the addition of the cab body taking form.
Next the body panel is set against the profiles of the cab ready to be folded round .
The grills on the front were put in place prior to the body being fitted.
The body panel is eased around the cab profile.
Dave Wooley more to come . My thanks to all those that have sent photos over .
They have proved to be more than helpful. :thumbs_up_1: :wave_1:
Capit�o Norbert
Post by Capit�o Norbert »
Hey Dave amazing work on trucks...
is needed very patience to do it..
congratulations :thumbs_up_1:
Atom44
Post by Atom44 »
Steregushij
Stereguzij
Stereguzij
Capit�o Norbert wrote:Hey Dave amazing work on trucks...
Thank you Norbert .
Hi Atom 44 Thank you for your help with the pictures .
With the cab body fitted the upper and lower sections of the roof and windscreen
pillars are set into place.
Next each wheel , tyre and lock nut was fitted .
All four wheels fitted , It now looks more like a truck ?
A comparison of deck vehicles , still in the raw. Work can begin on the remainder
of the fittings and I will be getting down to work on Kiev, once these are painted, I promise !.
Dave Wooley more to come :thumbs_up_1: :wave_1:
Capit�o Norbert
wonderfull :thumbs_up_1: :thumbs_up_1:
Hi Norbert Thanks for your kind comment. The problem now is trying to identify the colour scheme used on the truck as deployed to Kiev? I noted that a colour picture was very kindly posted and that I am thankfull for but it looks like the foam truck deployed on the Kuznetsov and I fear there will be difference. For example what colour would the cab be and are the foam mixing tanks and attendent pipe work painted the same as that in the Kuznetsov picture which would imply the tanks are red and black ? Help needed !!! :scratch: :scratch:
russclark
Post by russclark »
great work on the trucks dave,i knew all along you were a draftman :cool_2: .i keep telling myself to draft every thing in three elevations.but after seeing your results i am going to.if things are cut more close to size the less filling and sanding,which is a good thing :thumbs_up_1:
Atom44
Post by Atom44 »
Dave Wooley wrote:Hi Norbert Thanks for your kind comment. The problem now is trying to identify the colour scheme used on the truck as deployed to Kiev? I noted that a colour picture was very kindly posted and that I am thankfull for but it looks like the foam truck deployed on the Kuznetsov and I fear there will be difference. For example what colour would the cab be and are the foam mixing tanks and attendent pipe work painted the same as that in the Kuznetsov picture which would imply the tanks are red and black ? Help needed !!! :scratch: :scratch:
Hallo Dave! Do not wary...
The color on the truck (GAZ 66 / ??? 66) is simple - khaki (????). It is dark green color for military truck (it is standard color for military trucks in USSR and Russia).
The frame and bampers have black color.
I have drived sometimes this type (GAZ 66 / ??? 66) in russians army.
Thank you Atom 44 for your help . That is just the information needed. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
