When looking to scratch a fitting such as the SS-N-12 loading carriage the
easiest method is to reduce the build into series of sections. Lower carriage
frame, middle transit carriage and upper missile cradle . All the other smaller fittings
can be made and added at the right stage and as the build progresses. .
First the lower carriage frame . This is made from a strip of Evergreen H section .
Before any cuts are made the various openings along the length of the frame are
made using two pin vices as there are two different diameters of circular openings.
The next step was to mark and cut the sections from the lower frame. these
will eventually be the cut outs for the lower traction boggys that will sit on
the athwartships deck rails .
Some thought was needed as to how the upper missile cradle was to be made .
Using a simple but accurate universal cutter work could begin on this delicate
part of the build
As the openings in the side of the missile cradle frame where square a simple
method needed to be found to reproduce this effect. .A series of small sections
where cut to size using the photo of the carriage as reference. In order to hold all
the small square sections together a narrow strip of styrene forming the top and
bottom of each side was cut to length.
To ensure that the assembly of each side was the same both where fitted to a
strip of double sided tape .
Each side in now complete
The next stage was to assemble the two sections of the upper missile cradle
Fitting the inner support sections
Now the upper traction guide
This was followed by the middle transit carriage which is shorter in length than
the upper and lower sections but provides support for the missile cradle .
The progress so far . The next task is to put this lot together and scratch build
the SS-N-12 but that's for next time.
Dave Wooley more to come
