Hi Jim This build them small is catching !!!! but I have a very long way to go yet before I can say "small"JIM BAUMANN wrote:I like your methodical approach.
sharp and effective!
JIM B![]()
JIM B![]()
Hi Nick Bending styrene requires no other medium other than the fingers. You can "stroke" styrene and it will take up any bend you want .GTDEATH13 wrote:I revised the thread and have a question for you Dave:
How do you bend your plastic? Hot water? Hot air? Both, depending on the size and thickness ?
Hi Roel Warping can be a problem. The way I avoid this problem is not to place any stress on the parts as they are being put together.Neptune wrote:Wise words. My internet is a little wasted so I'm limited in amount of time online.
Great to see this carriage, great styrene skills once again. For me the most "annoying" feature of styrene is that it tends to bend when you try to cut small gaps or small strips. With 1mm thickness or something alike, when you cut it doesn't stay straight... I hate that, since I need a lot of 1mm strips for detailing etc. For now I've scavenged some of the Ark ones delivered with the kit, but I'm not sure if I'll have enough of it left for all the rails on deck. Maybe I'll have to buy Evergreen ones after all.
Anyhow, You don't seem to have that problem up till now, how did you avoid this warping?
Hi James I'm pleased that you can gain from this build that's what I hope it will achieve . and thanks for your kind words.johnny canuck wrote:I just love watching the way you work. Your level of skill with the plastic is something I hope to achieve some day.
Keep the photos coming as I am learning soooooo much.(and hopefully applying to my build)
Thank you Richard much appriciatedRichard J OMalley wrote:Truly amazing !
Jim I will never know how you manage to work at such amazingly small scales and in close up it's even more remarkable. I'm learning you bet! See you at the FAA museum ?.JIM BAUMANN wrote:As ever-- the sahrp edges adn clean building are inspiring!
Jim Baumann
Hi Ron Always good to hear from you . I have a confession "master" I made a mistake , big error ! "Damit" a new set of superb pictures arrived showing clearly that the upper frame is in fact the same length as the lower carriage . Some tricky finger work was needed to avoid the men in white coats offering me a cosy place to rest my muddled brain. I had to rebuild the top frame . I managed to do it butARH wrote:Love the carriage and the missile, your getting better Dave, if that is posible.![]()
