1/144 Kiev by Dave Wooley
travelling_man
Re: 1/144 Kiev by Dave Wooley
Post by travelling_man »
Hi Dave
Awesome work and you're pushing me in the direction of getting my build back out and just letting her moan about it! More importantly, your two builds of this and the Kirov make me want to build them too!!!!!
As for the pictures you are more than welcome! Very glad that I could help! Hopefully I can get some better ones for you! I will advise when they reply, but even if its in the negative, just make a list of any other areas you require specific shots of and I'll do my best to get, even in the no-go areas ;)
Steve
Post by Dave Wooley »
Neptune wrote:Another great update!
After attending a modelling exhibition with quite some ships, I noticed they all seemed to lack something. Models like Dave's have become a benchmark when I see a large scale model, and none on that exhibition came even close to it!
After thinking thoroughly why that was, I noticed it was the lack of detail, the door hinges and handles, the gratings which weren't really gratings etc. Small stuff, the stuff that takes a lot of time to make, yet those seem to be the things that take a model up a couple of levels! Congrats on the model and on the lessons learned once again!!!!
Thanks, apart from taking the time of building all these small bits and piece, for also taking the time of showing how it comes together.
Thanks Roel Rememeber it was yourself that got this ball rolling. I try to include what would be the small details and yes add enough of these and the model takes on more of a 3D effect. But I have to confess I just enjoy looking to see what's in this or that picture and try as best as I can to reproduce what I see. I'm not always successful , far from it and as I have said so many times my trash can has more bits than my work bench. I have just added a few more!!!! :thumbs_up_1: :wave_1:
roy allen
Post by roy allen »
Hi Dave :wave_1:
some lovely small detail going in to him at the moment :thumbs_up_1: :thumbs_up_1:
On a funny note my wife caught me looking at your build and was not amused to hear that i may at some time have to move to your scale as my eye sight gets worse. She obviously pondered on this and some time later suggested i consider laser eye treatment :heh: :heh: :heh:.
Roy
roy allen wrote:Hi Dave :wave_1:
Roy
Hi Roy I will be the first to admit I would be lost without my optical visor . I don't know if you have one but when I look at those 1:700 scales "fixing stanchion /rails " Even the visor would not help me there. :doh_1: :thumbs_up_1: :heh:
After seeing the �Trap Door� radar housing clearly shown by �Traveling man� Steve,
aboard the old Minsk. I had to set to and re-do the whole arrangement , as my
interpretation was far from looking like what it was suppose to be. Thankfully
my Mk1 version was easily removed from the deck right forward and salvaging
only the rectangular section which forms the door work could begin on re-shaping
this housing for the SS-N-12 mid course guidance radar. From what I can
deduce the trap door is elevated backwards when in use. But , and I am only
guessing here the 10 smaller housings or covers surrounding the door to
provide some form of locking mechanism ?
All the parts cut to size and laid out ready for assembly .
The bases for mounting each of the small housings are cut and set into place
surrounding the trap door along with the extended bases for the drive
motors/gear boxes? These in turn will be linked to hinges forming part of
the lifting mechanism and will be shown later.
The 10 small housings are made from Evergreen solid box section .
each is cut to size and a curved top formed with 4 ribs on each side.
Each rib is formed from .50mm styrene strip. Each one is fitted over size
and collectively cut to size .
All 10 fittings have a base this is slightly larger than the fitting.
The assembly so far . One part of the arrangement that really puzzled me was
the shape . Yes it's rectangular with curved ends but its not quite flat .
There is a gentle curve forward and the steel cover is off set. This only
becomes apparent in Steve�s photos .
I have off set the top cover and there is now a slight curve in the top.
Dave Wooley more to come :thumbs_up_1: :wave_1:
russclark wrote:i really like the gun platform,the way the unpainted styrene and brass contrast with the painted parts looks neat,it a shame to have to paint it all.this is why lots of pics of build progress is so important, it shows the great amount of work involved. your kiev and bill's indy both show this :thumbs_up_1:
Hi Russ You are quite right regarding the progress pictures. As an example of this many months back I cut to size all the life rafts and their chutes , grouped in various numbers to be located along the deck edging. Also included where large numbers of RULs and the measured lengths of safty rails All of this was fitted but not fixed into place , photographed and stowed away .Now those pictures are vital for relocating where these fittings are assigned to .
travelling_man
Hi Dave
Excellent work again!
WRT the hatch, it is hinged at the aft end. The 4 blocks either side port and starboard, plus the 2 on the forward side, house rams that extend over above a roller fitted on to the hatch, thus pushing the hatch down and locking it closed. To open, the 10 rams / pins are retracted freeing the hatch to be opened.
I will get you a clearer picture when I go again.
Steve
travelling_man wrote:Hi Dave
Steve
Hi Steve looking at your superb photo I thought as much . I also could just make out the catches above the locking piston . These are the sort of photos that are needed to do the job. Thanks Steve .By the way is the drive motor for openning the hatch electric ?
travelling_man
To be honest Dave I am not sure. If you look at the one photo taken of the aft end of the hatch there is a lot of pipework there but nothing I would say would have the strength to open a hatch that size. My guess is that there is some kind of hydraulic ram(s) inside. There is a lifting eye at the forward end of the hatch but again I would say not strong enough to lift by, my guess it is just a "hold back" for when the hatch was in the open position.
I have still not received a response to my email to Minsk world, so will try again, this time in Chinese.
Steve
The next part of this minor rebuild was to fit what looks like guides for the
locking pistons, once again a guessing job but they are there.
The guides are aligned to correspond with each cover . An eye plate is cut to
size and added to the top of the Trap Door .
Each guide is shaped from a length of styrene H section sliced diagonally to correspond to the
shape of that fitted around the edge of the Trap Door
With the 10 guides fitted the next step was to fit and align each cover on the base .
All the covers are fitted into place.
Turning the Trap Door through 180degrees assembly of the hinges was the next job.
With the hinges in position the drive motors could be added
The completed trap door on the fore deck of Kiev .
There is a gap between each of the hinges , in this gap are a number of fitting .
Their purpose is unknown but they can be added once the Trap Door is painted.
navydavesof
Post by navydavesof »
Dave....of all the things scratch builds you have done so far, this has to be the most impressive. You are truly inspirational. Thank you for the posts.
Neptune
Post by Neptune »
Great to see this! I'm thinking of something about this Trap Door, but I'll come back to it later after studying some more pics.
So, since I started this thing, how much % of the result is my property??? :big_grin: If I'm 50% (which I should be since without me you wouldn't have started this) shareholder I vote against sending it to the museum!!! :heh: :heh:
The merchant shipyard
ARH
Post by ARH »
Dave, This is one of the most comprehensive build on the board, and I congratulate you on your attention to detail, I look forward to seeing the model soon.
Simple but effective.
Neptune
Post by Neptune »
clearly the fittings are passing some liquids through their hinging points. I think some of them may be related to a glycol or steam heating system. The hatch is a large metal surface, placed in front of a ship, likely to take green water. Underneath should be a radar/electronics, which are prone to freezing in the intended operational area of this ship. So my bet would be that there are a couple of heating coils just underneath the surface of this hatch. The large parts near the big hinges of the hatch could either be for the same reason, fitted with a heating system, or they are gearboxes, which I sincerely doubt, since the opening hatch the bolts would be on top (to refill lube oil etc.), like on anchor/mooring winches, rather than on the side.
Just a couple of thoughts from a practical point of view.
travelling_man
Dave AWESOME yet again! Having seen this for real and close up let me say that it is spot on! The one difference, and I mention it out of interest and not a criticism in ANY way (nobody could EVER do that with your build) is the the guides.
The base of the guides are actually rollers as can be seen here
and the locking mechanism is a ram that is pushed out, the ram being circular with the lower part that slides over the roller being cut away, as seen here
I have also revisited the pictures after Roels post. If you look at this
It is quite clear that the pipework enters through the upper part of the hatch and the pipework rotates around the pivotal point as the hatch opens, which would tend to agree with Roels statement of possibly some kind of heating system
As I say, purely for interests sake!
As an aside, I stumpled across this link which has some more pics if interested http://commons.wikimedia.org/wiki/User: ... insk_World
I also found the answer to a question I had been wondering as to what the circled mounts were for
As can be seen in this image, I have my answer!
And Dave, you can just about make out your hatch on the gun deck on this image!
Steve
navydavesof wrote:Dave....of all the things scratch builds you have done so far, this has to be the most impressive. You are truly inspirational. Thank you for the posts.
Hi navydaves Thank you for the very kind comments . I make mistakes often through lack of any real information but where possible I try to correct them , at this rate I'll still be working on the model well into 2011 :thumbs_up_1: :wave_1:
Neptune wrote:Great to see this! I'm thinking of something about this Trap Door, but I'll come back to it later after studying some more pics.
Hi Roel good to hear from you. Well I can't disagree with that !!!!
Reading you ideas regarding the heating system on the Trap Door ,now that has a ring of truth . Considering that the ship operated in some cold conditions and if the Trap Door could not be opened then the Bazalt would have problems .Good thinking :thinking:
ARH wrote:Dave, This is one of the most comprehensive build on the board, and I congratulate you on your attention to detail, I look forward to seeing the model soon.
Thank you Ron coming as it does from the Master then that is a complement indeed . But Kiev is just one of many on this board and like your superb builds if it contributes in any way to helping others then it has done its job. You taught me that !!!! :thumbs_up_1: :wave_1:
travelling_man wrote:Dave AWESOME yet again! Having seen this for real and close up let me say that it is spot on! The one difference, and I mention it out of interest and not a criticism in ANY way (nobody could EVER do that with your build) is the the guides.
Steve
Steve this is awsome material and I really can't thank you enough . Now for a close inspection !!!!!!!
russclark
Post by russclark »
dave you keep moving the bar higher and higher, the way you can construct a part from a picture is a talent not many have.i am sure it takes lots of patience and time and a lot of skill :thumbs_up_1: :thumbs_up_1:
