1/100 HMS Zinnia ( 1915 )
Post by Dave Wooley »
Hi Laurent I've been watching carefully how you develop the plating using paper . It's a method I need to perfect for Rurik . The results achieved are excellent . thanks for showing how this is done . :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
Torpedo
Post by Torpedo »
Try to use Aluminium. This is quite resistable, but very good to sand and cut (even with a knife). And it provides the resistance you need for a R/C model.
Uli "Torpedo" Setzermann
http://www.marine-forum.de - Das Kaiserliche Marineforum
Currently Building: SM TrpBt B-110, SM TrpBt S-37
Upcoming: SMS Derfflinger
Laurent
Post by Laurent »
Hi all ,
at last , I decided to build the two bilge keels out of cardboard , seemed easier to me than glueing some aluminium or brass ... :big_grin:
hereby the results , as the remaining of the cardboard , it got a coat of G4 resin , it is tough enough to withstand handling and little beachings .
seen from under
Seen from above , a little L bar as reinforcement has been glued
I then applied a first coat of grey to the whole hull . this coat showed some places on the hull that need to be puttied & sanded ...
here under an area that will have to be smoothened , too much dents to me
the remaining of the hull is better
the bow at the starboard side is in better shape
a stern shot
Once the grey paint was dry & tough ( I waited 24 hours ) , I then put the black paint between the top of the load water line and the empty water line , don't know the name for that black strake , in french , it is called "faux col � mazout" , and after that , 24 hours later again , I applied the hull red .
that's it for today
I have to be ready for the november contest at our club ( a yearly contest where all the models built during the year are judged ) , but I don't think I'll be ready by then ... :lol_1:
Cheers ,
Laurent
Reid
Post by Reid »
O FANTASTIC!!! that looks great at it is all scale too!!!
Reid, PIO of the 48th Fleet
http://www.48thfleet.com
Avery Boyer
Post by Avery Boyer »
Something about it is just incredible! Fantastic work!! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Jefgte
Post by Jefgte »
Superb hull Laurent
Compliments
Jef :thumbs_up_1:
Current 1/700 WL
HMS Repulse
Dino Carancini
Post by Dino Carancini »
Superb! it looks really accurate! :thumbs_up_1:
Torpedo
Post by Torpedo »
Looks very realistic. What about the red colour? Was it that bright? The IG Kaiserliche Marine uses RAL 3011 which tends a little bit more to dark red/brown. They have found pieces from paint of a sunken ship which led to this colour.
***P.S. RAL is german standard, I don't know it something like this exists in other countries.
Laurent
Post by Laurent »
Hi Guys ,
Many thanks for the comments !
To Uli ,
Yes , RAL standards are known in the rest of Europe , it is used everywhere .
The hull red I use is a primer , sold in cans by "Motip" , the reference is 04055 , I've found that this red looks really realistic :
the grey & black paints I use are also primers , they have a semi-gloss finish, my experience with those paints is that they do fade a little after a few hours navigation on the pond ...
RAL 3011 should nearly match this Motip 04055 , but as far as we may rely on a computer screen , I'd say that 04055 is nearer to RAL 2002 ...
hereby a site with all the RAL references :
http://www.ultimedia.fr/nuancier.htm
Before that , when I used to paint my models with a brush , I used "Humbrol" #70 , but , for now , this reference is not right to me ...
Regards ,
Laurent
Andy G
Post by Andy G »
Hi Laurent - you stated in your last big update "too many dents"; but at a hull length of around 32" by 4", photos like this:
...really demonstrate the quality of the work. She looks marvellous! Big close-ups on digital cameras, lit with a low-angled light sources, always make things more noticeable than I bet they really are.
(And I'm not so far off an image like that myself - though your 2.8lb displacement (?) is a world away from my 110lb equivalent (!) )
Keep up the amazing work!
Andy
Hi laurent . Your plating and finished paint work is excellent . Very well explained. I'm looking forward to the rest of the build. Question do you spray the finished paint work with clear flat varnish? I find this gives a good protective surface? varnish :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
Laurent
Post by Laurent »
Hi Andy & Dave ,
thanks for your comments ...
Yes , those dents are not really noticeable , but as I'm a kind of a PITA , I want to get it right , my ambitions with this model are to go to the 2008 Belgian NAVIGA championship , just to see where I'm , so it has to be perfect and for now , it is not :eyebrows:
About the paint , I never put varnish on it , my sailing experiences tell me that there is no need to varnish acrylic paints .
But in this case , as I'll have to put transfer lettering & decals on the hull ( ship's name & depth marks ) , so I'll have to spray some varnish on it ...
I've found in the Motip range acrylic varnishes in cans , matt & semi-gloss.
Regards ,
Laurent
Laurent wrote:Hi Andy & Dave ,
Regards ,
Laurent
Hi laurent were is the venue in Belgian for the Naviga champs. I used to compete at Naviga in the 1970 and early 80s . Is this the "C" class championships or the motors. I'd like to go and see Naviga again before I get to old . As a matter of interest I use the Humbrol matt spray .
Laurent
Post by Laurent »
Hi Dave ,
I just want to play in the C class , no sailing championship with this one , as this model , like all the ones with only one propeller , are not really able to go astern ...
I might change my opinion , though , I just don't know how "Zinnia" will act on the water .
My next project should be "Mogador" , a 1938 french destroyer , with two propellers , much better to sail the NAVIGA figures , but this will be in a few years , I'm a slow builder and I have a commission after Zinnia ( my very first commission , you'll get the building report here ) ...
Regards ,
Laurent
Jefgte
Post by Jefgte »
:woo_hoo: :woo_hoo: :woo_hoo:
Mogador !!!!
Super Laurent :thumbs_up_1:
Jef :wave_1:
Current 1/700 WL
HMS Repulse
Edward Pinniger
Post by Edward Pinniger »
The paint has transformed the hull of your model - it really looks great. The plating looks particularly realistic - it's hard to imagine that this is made from strips of paper!
I'm definitely looking forward to seeing more updates on this build.
Laurent
Post by Laurent »
EPinniger wrote:The paint has transformed the hull of your model - it really looks great. The plating looks particularly realistic - it's hard to imagine that this is made from strips of paper!
Hi mister "E" ,
yes , indeed , you're right ...
I always say that modelling is like illusion , one can use a lot of materials , as long as you get the impression it is as the real stuff , then it is ...
brass , styrene , paper , whatever you use to build your models , once the surface is painted straight & clean , it looks like steel ...
Regards ,
Laurent
Laurent
Post by Laurent »
Hi all ,
I was meanwhile busy with the bulkwark around the main deck , with stanchions & deck stanchions , here again cardboard for the bulwark has been used , the stanchions are out of card either , the L shaped struts also , the whole has or will be impregnated with G4 resin :
I began also with the building of the trawl winch , everything will be out of wood , card & paper , except the shafts , the connecting rods , steam valves and brake handles :
the main gear , the teeth must still be done :
the two steam cylinders :
Any comment welcome !
Regards ,
Laurent
J. Soca
Post by J. Soca »
That's looing great Laurent :thumbs_up_1:, i still don't know how you guys do it, i once bought the 1/250 scale paper model of the Fuso i couldn't even finish half of the pagoda structure.
JIM BAUMANN
Post by JIM BAUMANN »
:thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
the pictures speak a thousand words!
Jim B :wave_1:
