Hi Guys,
Been a little while.......
I have over-fixated on accurizing the 5"54 Mk42 gun mounts. These things are half the size of the end of my thumbs!
The 1/96 BuShip drawings gave me the dimensions I needed to confirm the exact 1/350 l x w x h and I figured I had a little room to do some re-shaping as the WEM mounts did not look quite right to me, and were a little too large. This is arbitrary and specific at the same time; an oxy-moron.
The length, width and height, I got exact after doing some re-shaping on the gun mounts. The extreme difficulty was copying the curvature of the gun house, as it has curves on all corners. I used as many close ups of the gun mounts as I could find, and then locked in on a select few offering specific angle views and surface details. The WEM gun mounts would suffice, but not if you want them to look like the real gun mounts. No sooner do I say this, do I contradict myself, as I have chosen not to add on all of the grab irons on the sides, front and back!! I'm drawing the line here. As it was, I replaced the bug eye bases and cupolas; which will have clear domes. Additionally, I added on the bottoms made from plastruct I-beams, to more accurately copy the gun mount base perimeters like the real originals. Also, the brass barrels from BMK will be attached using an accurate shaped muzzle base made from some re-shaped and drilled styrene. The p/e doors had to be reduced in length and height to duplicate the BuShips drawings. On the real ones, the gun house side doors were flush mounted, and the outline should have been traced onto the sides, not adding on the p/e doors which made them stepped away for the gun house's exterior; modeler's prerogative.
If I continue changing things, I'll be further behind on this project next month than I am today!
I intend to take this DDG finished to the IPMS Nats this coming August.
Heck, the gun mounts are'nt even finished yet!
Check these out...
More sooner, Tony
