In modeling I always consider that there are two ways you can make a fitting
or part there of. To reproduce an exact miniature copy or to simulate what
is being viewed so that the part blends into what is being made. On this mini
build the later is the course I have taken.
The piping mounted on each plinth fits beneath that part of the launch
tube and it�s appearance simulated using styrene rod. One length is secured
into place by a length of H section the other by a length of brass tube .
The parts associated with the piping are assembled and made ready to be
fitted to the launch tube
One other outstanding job was to put the hinges on the access panels using
small strips of .31 brass wire , it does the job reasonably well. As the hinge is so
small the only method or tool I could use to set the part into place was a
discarded length of brass wire , tipped with a very tiny amount of cyano ,
This was followed by setting the piping into positions beneath each plinth.
Just above the piping is an access hatch , these where also added.
The remaining parts included the small platforms and an unidentified angular section ,
simple to make but I have no idea as to what this part is or its purpose , save
the fact that it is there.
The longer of the platforms was placed on the front lower edge between each
of the tubes. Here there is a slight difference to the picture taken by Steve aboard
Minsk and that seen on Kiev . On Minsk this platform has a half round grip or foot
rest fitted to the front of the platform .On Kiev this is a two rung ladder .
The prepared tube is placed in position on deck . Added to the side of the
tube is the folding platform set in the stowed position . Also the after end is slightly raised bringing the
tube to the horizontal position to take into account the sheer of the hull forward .
The job thus far Now for the rails !
Dave Wooley More to come
