If so, for any fine netting, I discovered something onboard of our ships. It's Flame Screen mesh. It's extremely fine, ranging from 1mm holes to approx 1cm holes (perhaps even available in larger or smaller than those). It's very fine woven steel mesh. Not exactly diamonds, rather squares, but by placing it angled 45� or pushing one side and pulling the opposite, the mesh can be distored to form diamonds. However in this scale I'm not sure if it will be good, as the mesh itself looks like a mesh, meaning that the "thread" in between the holes is actually overscale. Also the size has to be adapted, I think the smaller, the 1mm or smaller mesh is too small, I don't know all the sizes of this available.
At least it's finer than the brass webbing I've seen used for some radars.
Two things I've used in the past as "mesh" are women's nylons and the soft, flexible window screen material that you can get at any hardware store. You might also consider cheesecloth. Good luck!
Hi Roel Thanks for your input . This is the material that looked just the part till it was fitted to the crash barrier . As you say the scale effect is a problem, still scratching my head
Thank you Bob I'll look into that . All help and ideas much appreciated .
Just a small enquiry, why did you place the railing first? I normally put the bigger stuff first and the railing last (if I put any railing at all of course). Nice job on those railings though, sharp modelling and no sign of glue or paint drops anywhere!
And how about positioning, you can't draw on your nicely painted deck with a pencil I suppose? Or are you going to drill a small hole in the centre position on your deck, with a positioning pin in the equipment?
Neptune wrote:Just a small enquiry, why did you place the railing first? I normally put the bigger stuff first and the railing last (if I put any railing at all of course). Nice job on those railings though, sharp modelling and no sign of glue or paint drops anywhere!
Hi Roel That's the next set of photos ! Some times I find it easier to fit the rails first as these are a little bit tricky and I didn't want fittings to get in the way of positioning the rails. There are also other fittings including the PK-2 to be sited on the third level .
Capit�o Norbert wrote:Hi Wooley your model is fantastic, please do you have more pics to show us?
the painting looks superb too.
great from you
Hi Norbert Still working on some of the detail forward around the SS-N-12 launch tubes. The work is never ending! But I will be posting soon! Thanks for your support.
Peter that is just the material that would fit the scale and correspond to the appearance in the photos posted by Roel. Were can I source such material? Thanks for showing this. My trips to the craft stores didn't come up with the material needed. Either it was the right material but out of scale or the other way around.
Hi Peter this is how the mesh is on Kiev . each barrier on the model is 30mm long x 8mm deep . It looks lie the mesh is covering best part of the barrier? As the scale I am working to is 1:144 your mesh would fit , would it be wide enough to fit the depth of the barrier?
many thanks for your help it is very much appreciated
