IJN Yamato, 1/350, 1945 - COMPLETED
Joe Simon
Re: IJN Yamato, 1/350, 1945
Post by Joe Simon »
Dry fitted parts:
ImageIMG_6357 by Joseph Simon, on Flickr
ImageIMG_6359 by Joseph Simon, on Flickr
ImageIMG_6360 by Joseph Simon, on Flickr
ImageIMG_6369 by Joseph Simon, on Flickr
ImageIMG_6370 by Joseph Simon, on Flickr
ImageIMG_6374 by Joseph Simon, on Flickr
ImageIMG_6376 by Joseph Simon, on Flickr
ImageIMG_6379 by Joseph Simon, on Flickr
ImageIMG_6380 by Joseph Simon, on Flickr
Looking good, Joe. She'll be in San Marcos next year?
Post by ModelMonkey »
Amazing!
Continued beautiful work, Joe.
Is that just primer on the main directors?
Joe Simon
Post by Joe Simon »
Thank you Martin, Steve and Dan! Martin not sure about Texas. Dan yes primer on director.
GewoonWouter
Post by GewoonWouter »
Good to see Yamato back. Nice work Joe!
Joe Simon
Post by Joe Simon »
Thanks Gewoon! Here is the aft flight deck ready for installation. Also a comparison between the kit boat crane tracks and the Lion Roar replacements:
ImageIMG_3619 by Joseph Simon, on Flickr
ImageIMG_3639 by Joseph Simon, on Flickr
ImageIMG_6381 by Joseph Simon, on Flickr
ImageIMG_6383 by Joseph Simon, on Flickr
ImageIMG_6384 by Joseph Simon, on Flickr
ImageIMG_6387 by Joseph Simon, on Flickr
ImageIMG_6389 by Joseph Simon, on Flickr
ImageIMG_6391 by Joseph Simon, on Flickr
ImageIMG_6392 by Joseph Simon, on Flickr
Strategos Augustus
Post by Strategos Augustus »
It's looking very pretty!
I've always loved those two linoleum walking strips on the aircraft deck of the Yamato types. A very pleasing visual cue and your rendition is smashing!
Love that photo-etch work. Very sharp.
Joe Simon
Post by Joe Simon »
Thanks to both of you gentleman!
Joe Simon
Post by Joe Simon »
Aft deck finally installed. Still have to touch-up and blend it. Some prior in-progress shots are included:
ImageIMG_3596 by Joseph Simon, on Flickr
ImageIMG_3660 by Joseph Simon, on Flickr
ImageIMG_3654 by Joseph Simon, on Flickr
ImageIMG_6395 by Joseph Simon, on Flickr
ImageIMG_6399 by Joseph Simon, on Flickr
ImageIMG_6401 by Joseph Simon, on Flickr
ImageIMG_6406 by Joseph Simon, on Flickr
ImageIMG_6408 by Joseph Simon, on Flickr
ImageIMG_6410 by Joseph Simon, on Flickr
ImageIMG_6412 by Joseph Simon, on Flickr
Yamdul
Post by Yamdul »
Hello !
Very niiiice work ! :woo_hoo:
I got the pontos kit and I wonder how did you join the rails together and the rails on the dock ? I used thin CA but it�s very very fast, impossible to correct and I put to much of it which made some small �mountains� on the joints... visibles after painting... so messy :(
Joe Simon
Post by Joe Simon »
I use this tape cut in fine strips to secure my small items:
3M 301PLUS-1/2 Masking Tape, Performance Line, 12mm x 60 yd.
It is an automotive masking tape. To remove the tape I use BSI-151 CA kicker with a small clean paint brush. The tape slides off and leaves no gummy residue. That's why I use that tape.
The rails were sandwiched together with tweezers and thin CA was applied with a fine wire before installation.
The photo etch is painted first with automive etching primer then the main color.
After I glue the rails to each other they are lightly resprayed to hide glue marks and metal that shines through.
I dry brush them afterwards but before installation.
The deck has already been painted before the rails go on.
I tape the rails in with fine strips exposing the contact points.
I use a fine brush to paint Elmer glue on each contact point.
After drying for 24 hours I remove the tape with the CA and brush.
With a fine wire I apply small amount of CA to random point for reinforcement.
I then hand touch-up the paint to hide the glue. Hope this helps.
GewoonWouter
kudos that you glued the two part rails together. I gave up in the end and used a single part.
Nice update chap.
Really nice, Joe.
Joe Simon
Post by Joe Simon »
Screws and rudders in. The shafts are the stainless ones included in the kit. I did not like the look so I metalized them with MM Steel after a gloss black coat. The boat rack is in process of being installed also:
ImageIMG_4027 by Joseph Simon, on Flickr
ImageIMG_5583 by Joseph Simon, on Flickr
ImageIMG_6679 by Joseph Simon, on Flickr
ImageIMG_6681 by Joseph Simon, on Flickr
ImageIMG_6682 by Joseph Simon, on Flickr
ImageIMG_6683 by Joseph Simon, on Flickr
Joe Simon
Post by Joe Simon »
Some new shots of 1/350 Yamato, entire hull and flight deck:
ImageIMG_0060A by Joseph Simon, on Flickr
ImageIMG_0059A by Joseph Simon, on Flickr
ImageIMG_0058A by Joseph Simon, on Flickr
ImageIMG_0056A by Joseph Simon, on Flickr
ImageIMG_0054A by Joseph Simon, on Flickr
ImageIMG_0053A by Joseph Simon, on Flickr
Joe Simon
Post by Joe Simon »
Superstructure update. The lower section is painted (some touch up still required) and is ready to have the funnel installed next. Ass maintenance railing and red/green running lights:
ImageIMG_3713 by Joseph Simon, on Flickr
ImageIMG_3715 by Joseph Simon, on Flickr
ImageIMG_0094_A by Joseph Simon, on Flickr
ImageIMG_0111_A by Joseph Simon, on Flickr
ImageIMG_0112_A by Joseph Simon, on Flickr
ImageIMG_0113_A by Joseph Simon, on Flickr
ImageIMG_0114_A by Joseph Simon, on Flickr
ImageIMG_0115_A by Joseph Simon, on Flickr
ImageIMG_0118_A by Joseph Simon, on Flickr
It looks great, Joe.
Joe Simon
Post by Joe Simon »
Thanks Dan!
Return to “Completed Models”
