Singularity
Calling USS Missouri and New Jersey fans
Hey all,
Since the tamiya 1945 USS Missouri and New Jersey kits are almost impossible to find. I was wondering if there was a conversion available to convert these tamiya modern ship kits back to their 1945 luster. Since both ships are quite similar I would like to know any options for both. Also why is the tamiya Missouri much more expensive than the New Jersey? Thanks for your answers.
RandyM
Was able to do a bit more comparison work this weekend (daughter was home all last week on spring break: I love her to death but MAN can she and her friends be loud!). I concentrated on the bow section: I "built" one side using the blueprint profiles, and the other using profiles measured from the kit hull. In the first two images below, the grey surface is the BLUEPRINT and the red is the KIT. Keep in mind that while I put considerable time into getting the blueprint profiles as accurate as possible, there is no way to do the same with the kit: too many ways for error to creep in. BUT, they're pretty close. Anyway, the purpose of these two images is to show how the two surfaces look next to each other when viewed looking aft at the bow: it's pretty hard to see any real difference (partly because I haven't learned how to do rendering yet). In the third image, I overlaid the two surfaces onto the same side of the hull. As you can see, in the section modeled the trumpeter kit sits proud of the blueprints pretty much everywhere - that is, wherever you see red in this image, the trumpeter kit is "fatter" than the blueprints. I wish I could figure how to show you more graphically the magnitude of the difference, but I'm too much of a rookie with solidworks.
Finally, the next thing I did was begin looking at the maindeck. Floating Drydock says the camber of the maindeck is five feet at centerline. Reaching far back into my brain for high school geometry I came up with a circle of radius just over 300 feet on the prototype. So I used this value at each station and came up with a maindeck profile the entire length of the ship. This arc is shown in the fourth image below, along with a straight line representing how the kit's deck works for comparison. For reference, the max camber (which occurs at max beam) is 0.30" - certainly noticeable in 1/200 scale.
That's it for now.
That's it for now.
I don't believe a 5 ft camber in the deck! That is a lot and standing on say the fantail at about turret three where one can see all the way across the mid deck does not come to eye level when standing at the scuppers. , maybe a foot, but certainly not more. Hardly noticeable. The stern might rise that much from the turret three level, maybe.
Cheers. T
Cheers. T
RandyM
I tend to agree, based on my (very limited) experience aboard ship. Five feet in 53-feet seems a tremendous amount. I have both the ePlan book and the 1/96 drawings from Floating Drydock and the only place I've found this figure (so far) is an anecdotal comment at the beginning of the ePlan book. Misprint, perhaps? I've not sent a request to Mr. Walkowiak - I thought I'd first try to dig up some info on my own.
The 3d drawings look most amazing, especially as you begin to skin them.
Regards. Tom
Regards. Tom
- BB62vet
I honestly don't recall ANY camber to the main deck of NEW JERSEY. However, I'm not saying there isn't any, but 5"/53'-0" is W-A-Y out of the norm. This is where having access to the builder's drawings (not the Book of General Plans) would really help.
Where such a camber would be hyper apparent would be at the junction of the helicopter deck, which is more or less flat, and the main deck. I would be surprised if the fantail had any demonstrable camber as this area was used for heli parking and boats on dollies which would be most difficult to move on a slanted deck. The deck appears flat when one walks on it as well as visually. Will look at some of my photos. My model is certainly not seriously cambered aft.
Tom
Tom
RandyM
Lookie at what I found...
Over at Historical Naval Ships Association I found a file for New Jersey which contains a variety of frame drawings (note: I'm assuming it's ok to use - I was able to easily download them and this use seems to fall under their "personal/educational" category). This frame would be about 400-feet aft of the bow, so right in the widest section of the hull (ie., maximum camber). Note that this is a pretty detailed drawing. For reference, this frame is located at the forward end of the forward stack.
I rectified the image with respect to the third deck line (bottom of red rectangle), which one could safely assume is close to parallel with the base plane. Then I drew a rectangle with one edge on the third deck line (three downward-pointing red arrows), and the upper right corner coincident with the point at which the side of the hull meets the main deck. This way you can compare the top edge of the rectangle with the top edge of the main deck, all of which should theoretically provide you with a relative measure of the deck's camber (two arrows pointing at each other in upper-left).
Now, I realize that making detailed measurements/assumptions from such drawings is always a risky proposition, but I did it anyway. Since I know: the frame location, the width of the ship at that frame, and the half-width of the frame in the drawing, I can arrive at a fairly accurate scaling factor to move from the drawing to the ship.
Acknowledging all the various ways error can creep into the system, I see a camber of ~ 10-inches at this frame. Point is that even with the potential errors, and given that this appears to be a relatively detailed/accurate drawing, I find it hard to believe they would be THAT far off.
That same drawing is in one of my Battleship books, possibly Friedman.
Thanks! Tom
Thanks! Tom
- Builder 2010
The deck rises a bit from the scupper and then levels out. There has to be some rise to get water to run off. Most of the deck is flat. I don't know if that the dip toward the scuppers would be noticeable at 1:350. If you're building 1:96, maybe then.
zadmiral
Railings, ladders and catwalks
Hey I have to scratchbuild ladders and catwalks for my project.
Does anyone know what the gratings looked like that connected the 40mm mk51 director tubs on the after main director on an Iowa circa 1945?
Also the platform at the highest level of the stacks? were they diamond or square or something else?
Also how wide were the vertical ladders leading to these positions.? All the pictures Ive seen aren't detailed enough to divulge this info.
Any help?
mc
Any help?
mc
RandyM
Ok, here's what I've done now. The whole deck camber thing is sort of turning into a crusade for me. Curiously, I've been unable to find any definitive data - something you'd think would be well-published given the immense interest that continues to surround these ships (or is that just wishful thinking?). The earlier find (drawing of a mid-ship frame) - while not "proof" - is fairly compelling in terms of disputing the 5-foot camber figure. I've been thinking back to my days stationed on a USCG WHEC. There was what I remember to be a noticeable camber on that ship (in pre-FRAM configuration you could walk side to side just aft of the 5-inch mount). So I set about trying to find camber data for WHECs.
As luck would have it, I quickly found a RFQ from the CG for repair of CHASE (sister to RUSH), and in that document it clearly lists the ship's camber...
Six inches in 21-feet (these ships have a 42-foot beam) is another persuasive data point. Now, I *KNOW* I can't compare a WHEC's hull geometry with that of a BB, but my logic goes like this: I have distinct memory of feeling like I was "climbing a hill" when moving from the side to the center on my ship. Knowing that that "hill" was in fact only six-inches reinforces for me that there's just no way there would be 10-times that amount (60-inches) of rise in only twice the distance.
So I reached a sort of compromise - I decided to "pick" a camber of 12-inches and redraw the model. This is roughly the same ratio (rise/run) as for RUSH. For reference, 12-inches in 1/200 is just 0.060". This could easily be incorporated into Trumpeter's model with appropriate shimming/filling of the main deck. Here's what it looks like on the SW model:
Am I becoming obsessed???
Having been on the fantail of BB63 in a tropical downpour it is flat enough that the water does not noticeably run off.... I have seen the mid ships section in several places. I measured one with a caliper and found the mid ships deck flat, another reproduction of the same drawing suggested a small camber as you show. In weather a ship, even one of these rolls enough to direct water toward the scuppers. Note that the stern rises just about 5 feet above the mid ships sheer line.
Interesting! T
Interesting! T
- rtwpsom2
Camber serves two purposes. The more commonly known is to allow water to drain off, however the more important purpose of camber is to resist longitudinal torquing of the hull. It helps keep the bow from twisting left while the stern twists right.
NavyBuck
This is incorrect. I served aboard the Wisconsin from 1988 - 1990 and we were in drydock at Philly for several months in 1989.DBlack wrote:I'm not 100% positive, but I believe that the last Iowa drydocked at Philly was BB-62 in 1967/68. I'm guessing that that RDB photo is LBNSY, or possibly Pearl or Portsmouth...
BB63vet described being aboard New Jersey underway in a seaway and be in the bows looking aft and watching the ship twist! I am sure he could describe the effect better than my second hand missive. With her long narrow bow and great length a number of expansion joints were built into the superstructure, which is just that, non structural for hull stress. Some concern was expressed about the vulnerability of the long thin fore part, however because of the low volume here, not so much danger to the ship if flooded. It also led to the unusual rounded form at the bow at deck level, which allowed a lot of flare since the ship would be more likely to plow through the waves. this reduction in pitching moment probably added to gunnery stability at the expense of some spray dampness.
Some Caisson tests revealed a non optimal design in the anti torpedo system but construction was too far along for any substantive changes. Illinois and Kentucky were built of a modified design here. Every ship is a compromise. The Iowa's might have had the chance to face Yamato at Samar which would have been historically interesting. So the "glory" of the last battleship action went to Jessi Olendorf and his tired iron at Surigao Straight. Interesting that Willis Lee declined night combat at Philippine Sea due to his evaluation of the fleets ship to ship gunnery readiness. Out of practice from doing lots of escort AA screening and only shore bombardment. Hard to say what the Japanese readiness was at that point in the war!
As always a fascinating set of ship!
Tom
Tom
- BB62vet
The "twist" of the hull in the IOWAs is an interesting phenomenon - the bow in a different plane than that of the rest (from Turret 1 aft) of the ship in the opposite direction. I called this the "twisting Coke bottle effect". Yes, throughout the superstructure there are built-in hinged deck plates that hide the expansion joints built into the ship. These (I'm guessing) would be located throughout the hull, as well.
A couple of years ago I gave all my Warships International magazines to a fellow ship modeler who is into R/C warships and I felt at the time that I would not have a need for them. Well, this discussion of the "ultimate" BB duel (IOWA vs YAMATO) and other various actual actions during WWII bring back to mind various articles in WI that were action reports and subsequent reports written regarding the combat effectiveness and accuracy of the various U.S.N. large caliber weapons (12"/14"/16" bag guns, etc.) WI was fortunate (my collection went from 1971 thru the early 2000's) in having authors who did thorough research for their articles and these usually included ballistic charts, drawings, and pictorial shot patterns where needed to document their findings. While our fire control/radars were way ahead of the Japanese, there were deficiencies in our battleships which these articles describe. If anyone out there is able to locate the WI issues with battleship articles, by all means hang on to those and make copies if possible. If I had to make a guess as to an outcome of an IOWA/YAMATO encounter I would not hesitate to give the overall advantage to IOWA - greater speed/maneuverability, radars that were much advanced over YAMATO, and superior fire control direction (optics/radar) that would have allowed IOWA to know YAMATO's position/possible course well in advance of her adversary. I think this would have negated YAMATO's one advantage - 18.1" projectile with a longer range. And this doesn't take into account the individual CO of each ship and his experience/background in long range ship/ship gunnery.
Fliger747 mentions Willis Lee and night action (was that WASHINGTON?) - the NORTH CAROLINA class had vibration problems throughout their careers and this may have had an effect on Lee's decision making - as well as whether his gunnery dept. personnel were experienced or not at that particular time.
Willis Lee's one battleship night action was in Washington of Savo Island, where in an astounding gun duel scored 15 hits and receiving none in return. Of course SODAK came off not so well, but with no penetrations of her armored box. Sargent Shriver was abard SODAK at that time as a junior officer. Not sure what Lees available battle line was at Philippine Sea, but certainly their secondary role for a long long time as escorts had dulled their combat efficiency.
The Iowa's 16" 50 Cal weapon was probably the finest ever put to sea. The super heavy 2700 lb AP shell probably had at least as good penetration as Yamato's larger caliber weapon, due to a higher sectional density. Such a battle was always subject to the fortunes of war, or as my Naval Aviator chums might say, "Lucky beats good, any day". Being on the winning team later in the war, there was much to be commended in playing the game close to the vest. Jelicoe was said to be the only man on either side in WWI that could loose the war in an afternoon.
RandyM
Mystery solved - at least for me. I've been searching for additional data on maindeck camber, with no real success. Last night I decided to model the main and 01 decks based on the FDD blueprints. As I was finishing up, I noticed a note on the (1/96) plans:
Note the INCH unit following the 5. This note - and all the other similar notes on the various drawing sheets (once I knew to look for them) - clearly says FIVE INCHES in 53-feet. I had been previously referring to the FDD Missouri ePlan book as shown:
I had never considered the units to be the problem, because I incorrectly assumed such a large ship would have more camber than "just" 5-inches.
Anyway, now I can sleep a bit better
- Builder 2010
That's 0.014" in 1:350. That would be fundamentally imperceptible. You can include it if you want, by it's a couple of layers of extra paint mid-deck. According to the plans, it's not a linear slope anyway. It's more severe at the scuppers and is almost flat mid-deck. There's stuff you need to include for an accurate model and stuff that's neurotic to do. You're the modeler, you make the choice.
