But what if the main deck camber is different from that of the second superstructure deck?
:big_grin:
Post by Fliger747 »
Always a possibility, but as mentioned, imperceptible for a model of this scale. I did see that the fellow scratch building an aft section of BB63 at the time the kamikaze struck did use a very large camber, possibly the 5' figure. Generally most superstructure decks (other than flight decks) follow the lower deck camber simplifying lengths of supports and bulkhead heights. Not guaranteed however.
An earlier question had regarded linoleum, bridge deck color and brass.
Photo is current state of BB63 bridge.
Regards: Tom
Builder 2010
Post by Builder 2010 »
Pity the poor sailor who was claustrophobic... just look at that door. Was it open or closed in normal running? What took place in the oval, armored house directly above this one?
Post by Fliger747 »
This is the coning tower on the nav level where the a ships wheel and engine order telegraphs are located. An unarmored con station was also located on the 08 level of the fire control tower. The level above this one was for fire control, spotting periscopes etc were used for target designation. A ladder connects the two levels at the aft. The armored door was closed at appropriate condition levels. BB63vet might have a better idea as to what the NJ protocol was during Vietnam steaming. Generally for normal steaming these would be left open.
anj4de
Post by anj4de »
Cliffy B wrote:I can offer an opinion on the 1980's versions available from both as I have one of each; BUY THE TAMIYA ONE!!!!!!! It may have detail-less bulkheads but it measures our correctly and all the parts are properly shaped, sized, and placed. All it needs is some detailing (GMM and WEM have PE for them) and she's golden! The Trumpy kits may have bulkhead detailing but its not very accurate at all. Some suffer from the "we never looked at a photo of the real thing and just slapped some random ladders and what not on and called it a day" syndrome....not cool!
The only major issue you'll have with either is the flight deck is not elevated above the main deck like on the real ships and the unique helo parking areas are not addressed at all. ALL of them depict BB-62 and BB-62 only. Look at photos of the after main decks to see what I mean. All 4 ships had different layouts of wood/non-skid. Raising the flight deck and adding the ramps that lead helos from it to the main deck is simple. Re-scribing the deck is another issue. One approach is to buy a generic wooden deck sheet and cut your own. That's what I'm about to do to replicate BB-64's deck since she had full wood and no non-skid save for the flight deck and the ramps. The parking area was ALL wood with tie downs. In my opinion she looks the best with that layout. Some photos of BB-63 for example show the entire stern up to the superstructure as non-skid; YUCK! But I digress.
I can tell you from my experience walking the decks of BB-64 on a weekly basis that the Tamiya kit is one you want. It will take A LOT of scratch building and detailing work to get the Trumpy kits looking nice. Detailing is one thing. Having to remove and add/move/correct almost every deck and bulkhead detail is NOT a good thing.
Also like Builder said, the fit is MILES better with the Tamiya kit. The deck is 3 pieces but once you glue the hull together and to the waterline plate, you don't even notice the deck is 3 pieces. It has about a 0.25mm worth of slop in it and I have to use a pair of pliers to grab onto the turret lugs to remove the pieces. I'd love it if Trumpy would have decks with fit that good and they have one piece hulls!
Obviously it all boils down to how accurate of a kit you want and how much work you want to put it into but in all honest the Tamiya kit out of the box blows the Trumpy kit out of the water even if it waterline only which is the only real strike against the Tamiya kit.
-Mike
Hello Mike, all
I have now put togther the raw build of both, a Trumpeter and a Tamiya kit and I see what you mean! Tamiya all the way...! One thing that was also already mentioned were the nicer main gun turrets on the Trumpeter kit. What I find stange though is that they are bigger then Tamiya's, so which ones are size wise more correct, please? The barrels on the Trumpeter one are a lot shorter then Tamiya's! Is it possible that they were taken over from the NC or SD class ships that had shorter 16" main guns? The JAG turrets that are sometimes mentioned seem to be no longer made, the JAG web page shows no sign of military add on parts any more :-(
@Mike...did a bit of reading on the modern Wisconsin and what ammazed me the most was, that after she was finally modernized she did not even serve 3 years before being put away again. Considering the major overhaul she must still be in like new condition. You got yourself a great ship there, NOS as old car owners would say. Does the museum crew make sure movable parts are moved once in a while to ensure they stay movable? Are the turrets moved, does the radar move and what about the machinery. Even without screws manually turning the engines could not hurt if thats possible. When was the last dry dock period of the ship? And is the current anchorage in salt or sweet water? I have been on the North Carolina some years ago and she looks like she got stuck in mud, not sure if that is a good thing for the hull. I hope Wisconsin is afloat in sweet water...
thanks
Uwe
Cliffy B
Post by Cliffy B »
Uwe,
JAG Turrets - JAG was bought by Admiralty Model Works a few years back so you'll have to look for them. They still offer the whole JAG line at the same prices. Freetime Hobbies still has the turrets listed for order. I'm considering grabbing a set soon because as you say, the Tamiya turrets are a bit bland but I "think" they're more accurate. Given the rest of the kit is more accurate than the Trumpy I'm inclined to think they are but I'll have to measure first and compare to plans. That being said, the Tamiya turrets being bland really isn't that big of a problem since all you need to do is add some bits of plastic here and there and viola!
BB-64 - Everything is pretty much frozen. We can still open hatches and scuttles as needed but if we don't need access they are generally still sealed up, mainly to keep them weather tight. She's berthed in Norfolk, VA and we certainly get hurricanes from time to time so all the exterior doors and hatches are all either sealed up or in perfect working order so we can make sure she's buttoned up.
When they brought her in, they had the foresight to prepare the berth with regards to silt and other bottom muck. They constructed a concrete cradle for her that is higher than the bottom so all that crap and crud stays outside. She's moored with sections of of our anchor chain at 8 places along the length of the ship. Not sure if its really her anchor chain or just stock they got from the yard though. We still move with the tide, hurricane, or large river traffic (CVN or cruise liner). She's moored in the Elizabeth River (fresh water) right around the corner from Newport News Naval Shipyard, Norfolk Naval Shipyard, and the slew of other smaller yards. The Portsmouth International Marine Terminal and the Portsmouth USCG Base is down river from us and within sight if you stand on the fantail. The river is very active and watching the traffic going by all day is one of the perks of being aboard, at least in my opinion :cool_1: Tugs, barges, merchies of all shapes and forms, USN, USCG, US Army, etc...
Last summer they actually cleaned and painted the lower hull while she's moored and open to the public! A team from one of the yards up river brought a work boat over for about a month. They cleaned the hull, checked and repaired any of the seals on the myriad of inlets and outlets, tested the thickness of the hull plating, and then painted the hull with paint that dries underwater if you can believe it. Stuff cost something like $500 a gallon (do the math :faint: ) but that was still cheaper and quicker then towing up her to the yard (right around the corner) and dry docking her. They've told us she won't need to do that for another 10-15 years.
-Mike
BB62vet
Post by BB62vet »
Re. the camber - I can believe the 5" in 53 feet, NOT 5 FT in 53 feet. The E Plan must be a typo.
Re. the armored pilot house within the nav. bridge - the ship is conned from here during normal operation. Entering/Leaving port is usually done from the 08 Level Conning Station. The 17" thick armored door is elec. operated and in the OPEN position for normal operation. Only during General Quarters would the door be closed. I don't recall us having it closed during our 1968-69 Westpac deployment in NEW JERSEY, but it may have been at one time or another.
Re. NORTH CAROLINA - she's stuck in the mud due to being positioned East/West in the slip that was cut west of the Cape Fear River in 1960. It will be a task to drag her out for needed drydocking and hull work which is now behind schedule due to monetary problems from what I've read recently. Plans are to put her in a new position north/south (parallel) with the river when she returns from her Norfolk drydocking (whenever that occurs). This would be consistant with the current way museum ships are moored in order to let the tidal flow and current help keep the hull clean and keep down on maintenance costs. Her hull will be painted w/epoxy paint as have the IOWAs in more recent times.
zadmiral
Post by zadmiral »
Anybody have an idea what the platform gratings looked like around the highest level of the stack hoods circa 1945?. I know they weren't solid.
Anybody?
Builder 2010
Here's an overhead that shows the stack, but the resolution isn't good enough to see if it's solid or not. It certainly looks solid. This was the Iowa during a WWII refit.
Here's another shot of the Gibbs and Cox 1:48 definitive scale model that was at the Smithsonian.
And one more of a Fine Arts 1:192 model.
Unfortunately, not of these shots are conclusive, but I'm guessing that leaving them solid is not a problem. If you're working at 1:350, any grating is hugely oversized anyway.
Cliffy B
Post by Cliffy B »
NavSource has a high res version of the BB-61 construction shot. The upper platform is indeed grating while the lower one has too much of a glare to tell for sure. The deck inside the searchlight platform is solid but that doesn't mean the access platform surrounding the funnel is or isn't.
http://www.navsource.org/archives/01/61a.htm
http://navsource.org/archives/01/061/016101c.jpg
Here's a color shot of BB-61's after funnel. Resolution isn't that great but it might help.
http://www.navsource.org/archives/01/016191.jpg
Here's BB-62's forward stack again with a grating platform.
http://www.navsource.org/archives/01/016259.jpg
BB-62's after funnel in 1943
http://navsource.org/archives/01/062/016255a.jpg
I can confirm that BB-64's current funnel platforms are gratings as well if that helps.
zadmiral
Post by zadmiral »
Thanks Cliffy
These photos do help.
Now I can get to making gratings.
Post by Fliger747 »
Definitely a grating around the top of the stack. Thanks for the link Cliffy!
Cheers: T
Builder 2010
The last shot also showed clearly the amount of tension the antenna wire down runner puts on the cross wire. Also the over head of the Iowa shows the antenna lead-in towers that lie between the midships AA tubs. I tried to capture this on my rendition.
And with the radio rigging,
Post by Fliger747 »
Very nice indeed. Rigging must fall into the PITA (not the animal rights organization) category.
I don't know how one would do it, but signal halyards usually ave a bit of slack in them since they are running rigging, so to speak.
Thanks for the updates.... Tom
James M
Post by James M »
Here are a couple of more detailed shots of the Iowa's funnel
James
Builder 2010
I used the tan E-Z Line for the signal halyards and black for the radio rigging. At 0.003" it's a very fine line which is necessary for 1:350 ships. I don't know how you could get slack to look right. Even in bigger scales getting lines to sag properly is a skill I haven't mastered. It's most difficult in putting foot ropes under sailing ship masts. Thread is small calibers wants to do its own thing. The nice thing about E-Z Line which I think is pure Lycra or some other elastomer, is that it will spring back if you bump it (which I did many times). It also stick instantly with CA which made the 90� up-link to the cross lines very easy to do. Bring the wire up, press it against and down a bit to put tension of both lines, and then put a tiny drop of thin CA, and Voila, instant connection. Clip the remaining string close and it's done.
What are those bars that circle around the funnel above the walkway? Are they hand holds or some kind of antenna? That sure settles the question as to whether it's solid or a grating. Again, in 1:350 that grating will be hard to duplicate.
Post by Fliger747 »
Hand holds, though not certain of the reason for the arrangement.
Being able to instantly stick with ca would be an advantage! Not being an expert at all with sprue, but I think some have been able to install a sag with this material. The bounce back of the ez thread sounds like another advantage.
Good looking ship!
Regards. Tom
Builder 2010
I'm thinking that they could also be foot rails. You could move up from one to the next holding onto the funnel's rim. I too was confused by their staggered arrangement. I know a person who would know the answer.
I first tried stretched sprue which I had used on some models in the past and the results were terrible. I had seen E-Z Line demostrated at a train show for use in stringing model telephone poles. They made two gauges: 003 and 007. The 003 is perfectly suited for ship rigging.
Post by Fliger747 »
Sounds like a good product. If anything on a layout is asking for destruction it is telephone and power lines.
Cheers. T
James M
Post by James M »
They're hand hold and foot holds so the crew can put the canvas cover over the opening if needed.
Found this photo on navsource showing the rear stack.
http://www.navsource.org/archives/01/0161015.jpg
