- rtwpsom2
Looking good, randy, keep it up.
RandyM
Sorry if covered before, but I'm too lazy tonight to search: why no optical rangefinder on Turret One?
- Cliffy B
It was considered too low to the water, too unreliable (coincidence instead of stereoscopic because of how low to the water it was), and as a result was removed for weight reasons during the Korean War reactivations. They plated over the hole in the side of the turret but not its full thickness. See the photo below.
Here's an interior shot of BB-64's Turret I, starboard side.
RandyM
Thanks! I learned something today. And it's only 8:00.
Turret three retained the rangefinder both for redundancy and it was not as affected by spray as turret one. Optically the longer range finder base was potentially more accurate than the shorter ones aloft in the MK38 directors. Radar theoretically made the optics less necessary.
Cheers. T
Cheers. T
RandyM
Next three "I'm a dumb guy" questions:
Refer to the first image: what are the items labeled '1' and '2'? They appear to have been present throughout the entire life of Missouri. I'm betting they are not called "lumps."
Now look at the item labeled '3' in the first image. This appears to be some sort of massive bracket: my reference photos seem to imply it showed up with Turret #1's optical rangefinder was removed. Anyone know its story?
Finally, refer to the second image. The items pointed to appear to be part of the turret's ventilation system (total guess). However on later images these areas appear to have been plugged. Again, does anyone know the story?
Randy
Randy
The lumps are housings for the periscopes for the pointer and trainer, one of each both sides. There is a cover on the front of the lump much like the ones on the dual 5" 38 mounts. Inspection of the other items you mention suggest these are vents. Cliffy B could provide the full story here. At first I thought the item number 3 was a counterweight due to the removal of the rangefinder, but these do not appear to be made of a very substantial plate.
Cheers. Tom
Cheers. Tom
RandyM
Thanks Tom. Right after posting, I found this photo, which reinforces your assumption: that is, that the "bracket" is dissociated from the rangefinder since they are both present in this image (although I do not believe this is a photo of Missouri).
I believe I looked under the lip and found vent screening. That photo is one of the surviving SODAK's, Mass?
Cheers. T
Cheers. T
- James M
Those are called farewater vents. They are sheet metal extensions of the turret ventilation system.
They're designed to keep seawater out of the ventilation system.
The WWII picture of the Iowa's turret 3 shows the original vents with screens attached
Today the Missouri and Wisconsin have them on number 1 turret and the Iowa and New Jersey don't have them at all.
The Iowa had them installed late in WWII but they were removed during her modernization. Hers were different as they curved inward towards the turret.
RandyM
Tom and James: EXCELLENT info and insight - thanks to you both. It's amusing how easily a photo can be misinterpreted - I've been incorrectly assuming those pieces were solid cast parts. Your descriptions make perfect sense.
- john53
Hello, great thread. I just ordered the Tamiya 1/700 Iowa and have a color question.
I have scoured the web and gotten a lot of half answers. I want to do the camo scheme
from the campaign in 1944 after the Iowa left Pearl. My dad's best friend was on her during WWII
and would love to do it in his memory. My best guess is when she left the Atlantic she had a gray
black dazzle scheme then was repainted in Pearl to a dark blue and gray scheme, measure 32, design 1B?
I see a lot of pictures but none in color showing both port and starboard. Is there a schematic showing this scheme
outside of the one Tamiya does? Thanks---John
- James M
The Iowa left the Atlantic shortly after returning Roosevelt to the US in Dec of 43.
At that time she was painted in Measure 22.
http://navsource.org/archives/01/061/016143f.jpg
When she got to Funafuti Atoll they started to repaint her in the Measure 32 scheme.
This scheme is dull black and Haze Grey.
What looks like a feathered edge camouflage is really just an incomplete paint job.
They sortied for the Kwajalein raids before they got it done.
Port side incomplete
http://www.navsource.org/archives/01/016153.jpg
Starboard side incomplete.
http://navsource.org/archives/01/061/016144p.jpg
Sometime between late Jan 45 and June 45 they repainted the dull black in Sea Blue (5-S) but left the 16" gun barrels dull black.
http://www.navsource.org/archives/01/016301c.jpg
Port side completed in Sea Blue
http://ww2db.com/images/ship_iowa84.jpg
http://navsource.org/archives/01/056/015604t.jpg
Starboard side completed in Sea Blue
http://navsource.org/archives/01/061/016107.jpg
http://navsource.org/archives/01/061/016142.jpg
- BB62vet
Randy M:
In addition to the answers to your 1/2 items in the photos you attached, I have this to add to Tom's reply:
1/2 - Those elevation & training hoods containing the periscopes are for LOCAL control of the turret - in other words, each turret has inside it the capabilities to fire from Local control - i.e. from the turret itself. There are "small" mech. computers for range, direction, etc. inside each turret (well, originally there were) and those periscope hoods are part of the local system. This was a redundancy built into the ship so as a last resort (if the main FC systems were knocked out) if the turret was still functioning it could return fire. I recall in NORTH CAROLINA's 16" turret these consoles were quite in the way of moving around inside. NEW JERSEY's turret was similar if not identical - it's been a while since I have been inside those monsters.
RandyM
Thanks Hank - that helps a lot. I took some artistic license with the internal configuration of these hoods in my virtual model (current state of turret 2 shown). I have begun the process of creating / printing frames necessary to install a new after third of the Trumpeter hull, but in the meantime have continued modeling the entire ship. While I originally was questioning the tremendous amount of time invested to do this, it turns out the research required to "get it right" is actually quite challenging: I've learned quite a lot about these ships already.
- john53
James thanks for the camo information, VERY informative. So that's what those objects
are sticking out of the sides of the turrets are. Optical sights? Always wondered when I was a kid
back in the days before Woodstock what those protrusions were on my Revell USS New Jersey
and Missouri main turrets were. Guess an old dog can learn new tricks.---John
RandyM
need some details help
Can anyone help with the following:
Amidships there are six (3x / side) quad 40mm mounts. Each mount has an associated director tub. I am looking for definitive information on the support structure for the four aft tubs (arrows in photo below). The FDD plans are vague in this area. I believe I have the fwd tub correctly mounted - it is attached to the middle 40mm tub via cantilevered supports. But the other two pair are currently floating in space, which is beyond the current level of technology for the era.
Also in the middle 40mm tub, but an the aft edge, is something called a cupola. It appears the middle director tub mounts to this, but I cannot tell - I cannot find photos of this area which show sufficient detail.
Any help much appreciated.
Randy
Randy
Russ2146
http://historylink101.com/ww2_navy/org/ ... /6109.html
http://www.hnsa.org/doc/plans/bb64.pdf Third Page
If you want, I have mid 40's booklet of general plans for missouri in pdf. It may be optical, but your three mount bank of 40's does not seem to overlap the aft stack enough.
Send PM with your email address if you want the missouri. I have offered them to HNSA but they responded that they are not clear enough for them.
Russ
- James M
This photo is on Navsouce. Shows the area pretty well
http://navsource.org/archives/01/063/016383f.jpg
- Cliffy B
Stillwell's books on BB-62 and 63 have plans in the back and both show a small inset drawing detailing that area. If you can't get a hold of a copy let me know.
