RandyM
Post by RandyM »
Russ: see first photo below, which is dead abeam of the area. This should be accurate to within a few scale inches (based on blueprints)... but you never know. Please tell me if you think something's amiss (ignore the color/textures - I don't know how to do that yet). Will send a PM with email address... THANKS.
James: ARRRRRGGGHHHH. Great photo, especially of the mounts for the center tub. BUT, check out the second photo below, which shows... a) your photo of Missouri, b) a photo of the same area but on Iowa, and c) the area as shown in my model. Missouri seems to have some sort of additional structure/cover (the piece with all the rivets/bolts. Also, there appears to be a substantial post at the inboard edge of the tub. On Iowa, there is a similar post but it appears to be less in diameter and different in shape - maybe a conduit or drain pipe? So now I'm questioning whether Missouri/Iowa were identical in this area - they both seem to have brackets running fore/aft (arrows) that are attached to the upper (center) 40mm tub, while in the photo you posted of Missouri, the forward director tub appears to be mounted to that central post - MAYBE. Drives me nuts, especially because I modeled the Iowa mounts in the na�ve believe that there would be no reason for different yards to do it differently (the plumbing is not yet there...).
Cliff: I have Sumrall's (excellent) book on Iowas, but that's all. Anything you can share would be much appreciated.
Thanks as always to all.
Randy
James M
Post by James M »
The Iowa and New Jersey are different then Missouri in respect of where they are located and the amount of bracing.
Wisconsin is closest to Missouri.
Your red arrow is a pointing to a I beam reenforcement bracket that is probably the same on both Iowa and Missouri.
It looks the same in the two photos, even the heavier support beam below the gun tub looks to be in place on Missouri. I think you have it right on the model.
The heavier support beam on the model needs to moved in line with the outboard brace though.
It also looks like there is an additional brace under the gun tub that Iowa doesn't have. Outboard of the main brace.
It looks like the post is reenforcement support / wiring trunk for the director.
The bolted brace going towards the center of the tub is probably the armored wiring trunk for the director that would also add strength to the director tubs.
With that tub hanging out there and the guns firing, it had to create a lot of movement which would be bad for the director.
It also looks like the upper director tub is supported by the same support.
I'll look for some better pictures of that area from Missouri and Wisconsin.
James
RandyM
Post by RandyM »
Success - I think. Thanks to all... I think I've now got a good understanding of how the three director tubs are mounted. The photos and drawings you provided helped me to better-interpret the blueprints, and suddenly - as they say - the light bulb went on and all the weird angles and shapes in various photos made sense.
I've been holding off looking at how this is handled in the pontos set - and I haven't looked at the kit parts either - mainly because this would all be considered secondary data. The good news is, I did look at the Pontos instruction set tonight and it appears they basically have the same system going on.
Anyway, thanks again to everyone, and if anyone can come up with better photos, PLEASE forward them. I've got so much time into this effort now that I want it to be accurate as possible. The bad news... looking thru the Pontos set this evening has got me worried that I'll start building before my research is done :)
It'll take me a while to update the (3d) model, but when done I'll be glad to share.
Randy
Post by Fliger747 »
Randy
Very impressive progress on the auto cad of the ship.
However do get around to building the actual model! Looking forward to your iteration of this fine ship.
Regards. Tom
RandyM
Post by RandyM »
Tom: thanks. This "virtual modeling" thing is a whole new world to me, and has taken on a life of its own. It seems to have morphed into a great research tool for me.
Regarding starting the physical model, I promised myself I'd repair Boston prior to starting on this ship. The PE parts arrived last week so now I have no excuses...
James M
Post by James M »
I find for every hour I work on my model I spend two researching.
Your cad model looks like a great way the understand the details and build the model better.
James
RandyM
Post by RandyM »
I think I may need an intervention... Spent some time working on the 40mm tower directors, and on the supports for the midships mk37 directors. Ok, you might be asking yourself "who in his right mind would spend all that time on a virtual model???" Well, first of all, who says I'm in my right mind? Aside from that, I've truly learned a ton about the 1940s fit of these ships. Just as important, I'm getting a feel for the level of detail I can attain in 1/200 based on the dimensions of some of the detail parts I'm modeling in virtual-world. Finally, I'm developing the parts needed to "convert" the aft third of the trumpeter hull into something more accurate. Once I have the parts modeled I'm going to "print" them out in ABS.
Lastly, I was messing around with the "camera" in SolidWorks tonight. Have you ever wondered what it might have been like to walk around on one of these ships? (those of us who never have, that is...). These photos show current state of the model. As always, if you see anything stupid or just plane (weak pun) wrong... speak up. I'm trying to maintain accuracy to within three inches for those things which I have primary documentation.
rtwpsom2
Post by rtwpsom2 »
Randy, try to emulate pictures you have seen. That is, put the camera where the photographer was standing and try to copy his depth of field. It'll do wonders for your ego when you get things right. :-D
BB62vet
Question re. Access Hatches on IOWA class BBs.
Post by BB62vet »
Recently, one of our members building the Trumpeter 1:200 MISSOURI kit remarked about taking out one of the two hatches underneath the 16" turrets. This comment got me to wondering about this as it's been 10 years since I was on board NEW JERSEY and I honestly could not remember whether the turrets had one or two hatches. During my tour aboard NEW JERSEY I was in Turrets 2 & 3, but not Turret 1. In all my reference materials I have only two photos of a 16" turret showing the 2 hatches, but these were not clear and definitive.
So, I've today gotten two first hand sources to reply - CliffyB on WISCONSIN and my consultant friend Dick Landgraff on IOWA. The correct answer is TWO hatches on all IOWA class 16"-50 cal. turrets - also, this would include the 16"-45 cal turrets on the NORTH CAROLINA class and SDAKOTA class, as well. Both of these battleship guys have photos of the hatches on their respective ships - CliffyB's are on his Photobucket page. Dick's photos are .bmp files, so I can't upload them to the forum.
Dick gave me some info on the turret hatches: the stbd. hatch is a smaller, auxiliary hatch, not normally used for personnel but for handing up spare parts, etc. and for additional fresh air when the ventilation system is off. This hatch weighs 500 lbs. and will knock a person out if it is dropped open - it has NO safety gear to open or close it automatically, so has danger warnings posted on it. Dick was part of the inspection staff when IOWA was in storage in Benicia, CA prior to being donated as a museum ship; he is now their Naval Architect. In addition, he also was on the LBNSYD Eng./design staff that helped finish fitting out NEW JERSEY in 1968 prior to our departure for WesPac 68-69.
So, I hope this information is helpful to others building the 1:200 MISSOURI kit. I'm posting this on the Main Forum in hopes that all concerned will see this post.
bigjimslade
Post by bigjimslade »
RandyM wrote:Ok, here's what I've done now. The whole deck camber thing is sort of turning into a crusade for me. Curiously, I've been unable to find any definitive data - something you'd think would be well-published given the immense interest that continues to surround these ships (or is that just wishful thinking?). The earlier find (drawing of a mid-ship frame) - while not "proof" - is fairly compelling in terms of disputing the 5-foot camber figure. I've been thinking back to my days stationed on a USCG WHEC. There was what I remember to be a noticeable camber on that ship (in pre-FRAM configuration you could walk side to side just aft of the 5-inch mount). So I set about trying to find camber data for WHECs.
The height of the main relative to the deck edge varies throughout the length. The design profile is a parabola.
Between frames 155 and 163 where the top of the sheer is level, the center of the deck is 5" above the height. In other words, in this range, the deck is 53' above the baseline and the center is 53'-5".
The center height is 53'-5" from frame 70 to frame 182. At the side rise fore and after, they get closer to the center. From these points, the center rises with the sides, but at a slower rate to that there is no rise at the bow and stern.
Here's a stern section I made from my printer.
http://s1319.photobucket.com/user/bigji ... c.jpg.html
I have to take a trip to NARA to get more data.
Grandad
Iowa class rigging
Post by Grandad »
Hi Folks, can anyone please help me to find, preferably online, a source to show the rigging detail of this class. I've just bought the Trumpeter 1/200 and the rigging details are zilch. Grandad
Grandad
roger-antrobus.magix.net
EJFoeth
Re: Iowa class rigging
Post by EJFoeth »
Try the Floating Drydock's USS Missouri planbook (on CD). It contains nearly all information you need to build the USS Missouri; it's a wonderful reference.
BB62vet
Post by BB62vet »
Grandad:
Well, to answer your question, I'll start with a question - what time period are you planning on building your 1:200 MISSOURI? WWII, late '40s, Korean War Era, mid '50s, or '80s configuration? Once you answer this question, I could give you a better answer.
E.J. Foeth's replly is only partiallly correct - IF you are building the 1945 version of MISSOURI THEN the plan or eplan book from TFD is what you would need.
In additon, I would also recommend (once again after you have determined your time period) purchasing the available plans for MISSOURI from TFD (The Floating Drydock). Go to their website and see what's available. I did this for my NEW JERSEY project using the same kit. Each of the IOWAs vary in their configuration, one from the other. They are NOT all the same during a given period of service. Just like Nelson's VICTORY, the ship changed thru the years; to build the 1805 version is not like building the 1765 version right out of the yard.
So, since you've spent some Geld on the model, spend some time and figure your plan of construction, as well! The results will speak for themselves.
I would also recommend the Pontos super detail set w/either blue or teak deck (once again, depending on your time period).
EJFoeth
Post by EJFoeth »
Err, yes, that is correct :thumbs_up_1:
RandyM
current status
Post by RandyM »
Can you tell what this is?
Still have some work to do. The machine I can use at work for this project has a max part size of 10", so I'm going to have to print the keel in two or three sections. I spent a lot of time creating the frame members such that their face angles are all continuously tangent with respect to the "skin" they will carry. I sized them to accept .020 sheeting. We'll see how many revisions I need to achieve something that's actually workable.
Post by Fliger747 »
Just the perspective makes it look narrow. Keep up the great work!
Tom
RandyM
a few more views...
Post by RandyM »
Here are a few more views. All frames have been added. The entire structure is ~ 26 inches long. It replaces the aft 17.5 inches of the Trumpeter hull (look at the upper-right quadrant of the first picture and you can see the notch in the keel where it will mate to the hull). At this point the kit matches very closely the Floating Drydocks blueprints, so I should be able to achieve a seamless transition.
At the sheer, the kit hull has a 0.04" wide by 0.12" step to accept the main deck. I have included this in the frames, but since the corrected hull has a much tighter angle (hull side to maindeck) in the after sections than does the kit hull, I'll have to "notch" the maindeck piece at certain frames to accommodate - otherwise there would not have been enough material left for the frame to stay in one piece.
The keel will assemble from four notched pieces.
Once I cut the kit hull (and I probably won't do this until I'm certain the whole concept will work: I'm not too crazy about trying to explain to my wife why I had to buy a second kit...) I'll be able to get a very accurate trace of the section at that point: from that I'll create an adapter piece which will provide a surface on which to start the sheeting.
I'll try to print the first batch this coming week: much of the success/failure of this first experiment will depend on the accuracy of the printer (0.004") and its ability to maintain the outer surface shapes of each frame.
Finally, I may add the five-inch camber to the frames :)
BB62vet
Post by BB62vet »
RandyM -
Excellent work!!
Let's see now - the IOWA Class Hull Replacement Module, including easy to read instructions in English, French, German, and Romulan will be available when????
And, I would also assume this kit will feature a photo-enhanced, step-by-step CD for those of us of the s-l-o-w to grasp it faction. All for the low price of.......................... :big_grin:
Seriously, you've really done a great job on this - I'll be tuned in for the next chapter!
bigjimslade
Great work!
If you're doing this as plank on bulkhead, I'd suggest laser cutting this rather than 3d printing. I know you can't get the curves on the frame but those could be shaped afterwards.
I don't know what level of accuracy you're going for. You might want to include the extension of the keel into the tunnel. The tunnel starts at Frame 140. The keel remains on the baseline until frame 166-1/2 (with the tunnel on either side) then tapers into the top of the tunnel at frame 168-3/4.
The bilge keels end at frame 150, so you'll have a little of them in your section as well.
RandyM
Post by RandyM »
Wrapping up for the weekend...
First I created a "tailcone" for the extreme stern (does "transom" apply to this type of hull???). My plan is to print this and use it to create a pattern for a resin part.
Next I scanned/measured the kit's after maindeck and created an accurate representation in my project. Then I overlayed it onto the assembly. This allowed me to really compare how the "accurized" frames would fare into the kit's deck footprint. With the exception of three of four which needed minor adjustments, everything lined up well within my tolerance of error. As shown in the first image, if you look carefully along the outer edge of the deck you can see the occasional frame sitting just proud. All overages are less than 0.02" (ABS is a PITA to work, but this level of smoothing is within my level of patience).
While doing this, I noticed a design error in the way I was handling the tops of the frames, so I took care of that.
Finally, the above exercise pointed something else out. I've seen lots of comments regarding the aft deadrise of the kit's deck. If you look at the second and third photos, you'll see how this issue manifests itself in my project. Image #2 is a side view (starboard) showing the frames and how they relate to the maindeck if it were completely flat. As you can see the frames on the right (corresponding to the area of the #3 16-inch turret) are coplanar with the deck. Moving aft (to the left) you can see the tops of the frames begin to steadily rise. Finally at the far left side you can see the tail cone. The top edge of this piece should be flush with the top edge of the maindeck. The third image gives a better view of the very stern and shows that if the maindeck were flat, it would be off 0.20". You can also see the nearby frames sticking up thru the deck. NOTE: this assumes a flat deck - I have not studied in detail how the kit's hull rises at the stern.
To bigjimslade: since I've got 100+ hours into this so far (ok, it's probably closer to 300 but a lot of that is due to the Solidworks learning curve and besides, my wife already thinks I'm a bit of a dork and if she knew how much time I REALLY have in this....) and haven't even touched the kit (except to measure it), my goal is to improve the stern as much as is practicable. So please make as many suggestions as you see fit. I do not understand what you mean about the keel (I can visualize your description, sort of). But I have been under the assumption that the keel simply follows the tunnel. The only photo I have of the area is shown below - and it is not definitive. Can you provide further info?
Good point about the bilge keels - I'll either reconstruct or blend the kit's parts in.
To Hank: thank you. If this effort turns out well-enough that others would want a copy, I'll certainly look at making it available on a limited basis.
