1/144 Kiev by Dave Wooley
- Dave Wooley
Re: 1/144 Kiev by Dave Wooley
Hi Norbert Thank you for that but Barry Deans book has been part of my collection for some time. In fact it has served me well , I certainly would have found it difficult to move forward to build Kiev without it. BUT I would love to lay my hands on "The Anatomy of the Aviation cruiser Kiev"
- Dave Wooley
As mentioned more of the small item are being fitted into place starting aft
and working forward. Here the first job was to lay on the ships name in Cyrillic
letting KNEB . Next the Soviet emblem which embosses the stern . The emblem
was bespoked along with the Cyrillic lettering and a compass cutter was used
to lift it from the sheet .
As the emblem is self adhesive all that was required was to lay it over the raised disk .
The next job was to cut out the styrene corrugated surface that will be fixed
beneath the port opening
Paint the surface black
.This corrugated surface is fitted into place .
The next job was to make using discarded sections of 4 bar rail the rails as fitted
across each of the openings and fit these to the pre-prepared deck sections .
The deck section plus fitted rails are eased into the opening
Each of the deck surfaces are placed into position within the openings . Now that
I�m confident they will fit both can be removed and reset as a permanent fixing.
One of the other signage jobs is the Kiev�s crest , I�ll have a go at preparing this one .
Dave Wooley more to come
- russclark
hi dave, i see you have been moving along splendidly.your kiev is looking very good,so much detail and done so very well,and i mean dam good
.i wish i lived closer to these model shows,not to look at models so much but to maybe meet some of you exellent builders
- Dave Wooley
Hi Russ You are always welcome . We frequently get visitors from OZ TF72 these guys time it when the major shows are around which is one a month at the hight of the season, somewhere in the UK . If you ever want to pay a visit give me a call .russclark wrote:hi dave, i see you have been moving along splendidly.your kiev is looking very good,so much detail and done so very well,and i mean dam good.i wish i lived closer to these model shows,not to look at models so much but to maybe meet some of you exellent builders
- Ticonderoga
Hello Dave, inspirational work as usual, wonderful.Dave Wooley wrote:As mentioned more of the small item are being fitted into place starting aft
When you said the emblem is bespoke, did you mean that you made it yourself, or did you have it made? I will need the same type of thing for Varyag and it would be really helpful to know how, or where, you were able to "obtain" such great detail.
Andrew
- Dave Wooley
Hi Andrew Thanks for you kind comments .The lettering and Soviet emblem was made to order { I supplied the original} from Barry's Model Lettering www.modellettering.com he's the only producer in the UK providing large scale Russian lettering, Numerals {naval} and emblems .Ticonderoga wrote:Hello Dave, inspirational work as usual, wonderful.Dave Wooley wrote:As mentioned more of the small item are being fitted into place starting aft
to lift it from the sheet .![]()
Andrew
- Dave Wooley
Just some progress shots
- ARH
Hi Dave, I think you should be put away for causing us modelers mental crualty with all this splendid work,
keep up the good work my friend.
Simple but effective.
- Dave Wooley
Hi Ron always good to hear from you , I always refer back to your work I am still learning Master .ARH wrote:Hi Dave, I think you should be put away for causing us modelers mental crualty with all this splendid work,![]()
- gtbred
just a great buildup Dave!
- mitchell300
Kiev by Dave Wooley:
Laid down:2006 jan 18(?)
Launched:2007 apr 16
Commisioned: To be done
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
Ships in dock:
Ships in repair:
- kalkurap
Dave, this is looking fantastic. You have made a steady progress, the model is looking really impressive.
INS Veer: 1/100 scale, under construction!
- Dave Wooley
Hi gtbred getting there , slowly . Looking at Bill's Santee build and how the deck crew and deck activity lift a superb model onto a different level, I would like to try and achieve that .gtbred wrote:just a great buildup Dave!![]()
- Dave Wooley
Hi Kalkurap Thanks , yes I couldn't wait to get a shot of a number of Yak38s on the flight deck, a bit of a photo opportunity as they say . They have gone back into the hanger! whilst I carry on finishing off some of the deck details.kalkurap wrote:Dave, this is looking fantastic. You have made a steady progress, the model is looking really impressive.
- Dave Wooley
Hi Mitchell300 It's an open bet as to which ship enters service first . The modified Gorshkov for the Indian Navy or my Kiev ? both have had a rather extended BUILD period!!!!mitchell300 wrote:Kiev by Dave Wooley:
- Rui Matos
Hi DaveDave Wooley wrote: BUT I would love to lay my hands on "The Anatomy of the Aviation cruiser Kiev"![]()
Dave Wooley![]()
You have just written the ultimate reference for anyone interested in making the Kiev IN ANY SCALE!
When you have the model finished, you just need to write it all down, add the images and take it to a publisher
BZ on the most amazing replica
See you in Telford
Rui
- Dave Wooley
Hi Rui Good to hear from you and I shall be looking forward to seeing you again at Telford . You have given me some food for thoughtRui Matos wrote:Hi DaveDave Wooley wrote: BUT I would love to lay my hands on "The Anatomy of the Aviation cruiser Kiev"![]()
Dave Wooley![]()
See you in Telford
Rui
- Rui Matos
Eheheh
Well, this is one of the things that these forum are for: food for thought!
Keep up - you're almost there!
Rui
Rui
- JIM BAUMANN
with Telford merely a month away.....
I guess she will not be finished in time eh...?
Model looks stunning!!
Much admiration of your tenacity!
JB
JB
- Dave Wooley
Hi Jim I'm biting at the bitt for Telford but Kiev needs more work yet , and I can't have the commissioning of the ship without a crew!!!JIM BAUMANN wrote:with Telford merely a month away.....
JB
