- BB62vet
RandyM -
I think you've hit on the right strategy to correct the hull problem. I'm in a holding pattern on the hull anyway, so a possible modification set is worth the wait.
If I can come up with any photos of the IOWAs in drydock showing the tunnel, flat keel, skegs, etc. I'll post them.
bigjimslade
You can see the keel in the center of your photo. It's in the very center rising up to from the floor to ceiling.RandyM wrote:Wrapping up for the weekend...
To bigjimslade: since I've got 100+ hours into this so far (ok, it's probably closer to 300 but a lot of that is due to the Solidworks learning curve and besides, my wife already thinks I'm a bit of a dork and if she knew how much time I REALLY have in this....) and haven't even touched the kit (except to measure it), my goal is to improve the stern as much as is practicable. So please make as many suggestions as you see fit. I do not understand what you mean about the keel (I can visualize your description, sort of). But I have been under the assumption that the keel simply follows the tunnel. The only photo I have of the area is shown below - and it is not definitive. Can you provide further info?
I have a lot of data on this. I have not come up with a good way of sharing it. I wish i could do a quicky image post to this forum.
BTW. . . . How much does Solidworks run? They don't list prices.
- pbudzik
Jim...You have to call the Solidworks rep. They probably have several prices depending on what part of it you need and what you can convince them you are going to use it for, but I wouldn't be surprised if they try and stick you for at least 5K.
You can enroll in a community college course and and get an educational edition for what they consider a nominal amount, but they come with a number of restrictions as well as time limitations.
As with any software, there are ways around, especially if you know a college engineering student
Paul
Paul
RandyM
Two comments:
Does anyone have detailed information regarding the shape of the tunnel? I've been looking in more detail at what few photos I can find, and they seem to indicate the skegs are parallel to each other. However the data I have from FloatingDryDock shows that the tunnel is wider at the entrance than at the exit.
Anyone have definitive data?
Jim - First, I sent you two PMs. Next, I would echo Paul's comments re: Solidworks pricing. My company's engineering department maintains 12 seats, most of which are "standard" level. We have several premier seats and some add-on options (thermal modeling, circuitry routing, etc.). All in, I think this averages out to ~ $5k/seat for these licenses. In other words, it's not inexpensive. HOWEVER, they (Solidworks) have a very aggressive community outreach program - contact them and tell them you are a hobbyist/enthusiast and not using the software commercially and they may cut you a deal.
- BB62vet
Randy -
I will check all the plans I have this evening when I'm back at my shop. I think the skegs are parallel and the alley between is flat leading up to the centerline end of the keel. I'll also check photos, etc. for any other info and post early tomorrow a.m.
What type of file extension does Solidworks use? I know ACad is .dwg, but I'm not familiar with SW. Can you export the files as a .dxf or .dwg? or as a 2D file in either extension? What exactly are you looking to find in SolidWorks? We have a couple guys who do mech. skid design at work and I can always ask them if I know what to ask them
I was online last night, but there is nothing online that I could find that showed the tunnel or the interior of the underside of the ships.
Time to head out for the week,
bigjimslade
Randy, check your email. I sent you a couple of plans showing details you asked for. I have the source data for the tunnel. However, it's extremely difficult to read I have been building my own data tables, comparing what it looks like is in the printed tables with my own drawn shapes. This allows me to tell if the 8 is really a 3 or the 6 is really a 5.RandyM wrote:Two comments:
- BB62vet
RandyM wrote:
As for the alley between, it is flat according to the various drawings.
Only two photos I have found so far, and neither shows the alleyway going forward - everything disappears into black.
Hope this helps your design.
I checked all my drawings last night (Sumrall, Chesley, Floating Drydock) and all indicate that the twin skegs are parallel to each other - they are not constructed at any sort of angle inboard or outboard. The only comment on this I would make is that the skegs taper towards their aft ends (screw end) in thickness, but their centerlines are parallel. I am reaching out to one of my BB consultants who worked on NEW JERSEY to see if he might have a better idea of the layout of the skegs, etc.Does anyone have detailed information regarding the shape of the tunnel? I've been looking in more detail at what few photos I can find, and they seem to indicate the skegs are parallel to each other. However the data I have from FloatingDryDock shows that the tunnel is wider at the entrance than at the exit.
bigjimslade
This is the shape of the skegs inboard.
http://s1319.photobucket.com/user/bigji ... e.jpg.html
It's wide in the front, narrows, then flares out slightly.
RandyM
finally, some hardware...
Finally moving out of the electronic and into the physical domain.
First print job underway, should be done tomorrow at noon. Includes the four keels, the five forward supports, and four frames.
RandyM
(sorry for the photo: I'm in the office and in my enthusiasm to share, didn't notice the background paperwork).
Here are the first batch of parts, still on their build tray. Next stop is the cleaning vat, then home for trial fit/cleanup.
For those who are a) interested and b) inexperienced with the process, these parts were built using an "FDM" (Fused Deposition Modeling) printer. They are made of ABS plastic. The white stuff is a water-soluble support material. This is forms a bond between the parts and the build tray, and also provides support for any areas which cantilever in space (eg., you can't print on air).
From what I can see so far, I'm pretty happy. The all-important edge face curves appear to have been replicated accurately (at least to my eye).
For FDM, it looks pretty tight! FDM is usually the cheapest and lowest-resolution option out there
JeremySea
Hi all,
I'm building a 1/350 USS IOWA with the Pontos 1984 detail set. It's a first for me with this PE set, so I've run into a few problems that maybe you guys can help me out with. The doors and hatches for the PE are not marked in the manual and I'm wondering if anyone knows the exact placement of the different types of doors and hatches. Also there seems to be a lot of modifications not mentioned as well. I've been scouring the forums for different photos for references, but I'm curious to know if anybody has any specific references for the modern Iowa such as port holes and other small details. Unfortunately I haven't found anybody else using the pontos Iowa conversion kit, so I got no easy how to guide to follow. Anyways, any answers would be helpful and hopefully I'll be able to post pictures of my progress because my i phone takes pictures too large to upload. Thanks guys.
Anything worth doing is worth overdoing, moderation is for cowards.
Building:
1/350 USS Iowa 1984 with Pontos kit
Completed:
1/350 Yamato with Eduard kit
Building:
Completed:
bigjimslade
Do you have the Floating Drydock plan book?
bigjimslade
Interesting. My printer software creates support out of the print material (ABS, PLA). The support is thin so that you can pop it out with your fingers.RandyM wrote: The white stuff is a water-soluble support material. This is forms a bond between the parts and the build tray, and also provides support for any areas which cantilever in space (eg., you can't print on air).
RandyM
Remaining parts are complete. I have assembled the keel and the first frames (no pics, sorry), so now I need to clean these parts up and assemble them onto the keel. I'm using a jig to keep everything square since I have yet to cut the hull. Next step will be to prove to myself that I can adequately sheet this assembly, then cut the hull, create the transition piece, and assemble everything.
- BB62vet
Randy,
This is very interesting - I'm following your progress and so far it does look doable - will certainly be interested to see how the hull sheathing goes. Keep up the great innovative work!!
Some of the scratch builders using a similar hull method in wood have put styrofoam etc
Between the ribs and then sanded them to contour which would provide a backing for the styrene, or one could use a light weight fiberglass cloth.
Looks to be an interesting project!
Cheers. Tom
Cheers. Tom
NavyBuck
BB62vet wrote:Tom,
True - the carpenter's mates of WWII/Korea were real craftsmen when it came to wood and so forth. The open fantail of the IOWAs makes for a wonderful setting, esp. with the large tents that (esp. in NJ's case) are usually erected aft of Turret 3.
While the general configuration of the IOWAs in their post-'80s appearance is similar (weapons, electronics, etc.) the one difference is the deck plating - it differs from ship to ship (back aft near Turret 3, etc.). Don't know the reason for this unless it was due to the condition of the existing teak on that particular ship when it was modernized.
In the case of the Wisconsin, the entire original teak deck was replaced by new teak during her 1988-90 reactivation. The OIC of the precom unit (and subsequent CO), CAPT J.M. Bleach was very vocal about limiting the amount of non-skid on the main deck. For this reason, the teak extends further aft on the Wisconsin than on her sister ships.
- TimW42
Hi all--
I'm still fairly new to ship modeling (I've done aircraft/armor for years). Am currently immersed in the 1/200th Missouri and had a question:
What are those oxygen bottle-looking things that line the bulkheads of the O-1 level? Water for the firefighting system perhaps?
Thanks!
Tim W.
Thanks!
Tim W.
- Navy2000
They are just what you said, Oxygen bottles. They also have acetylene bottles in other areas as well.
Duane
Duane
George W. Bush CVN 77, Makin Island LHD 8,
Port Royal CG 72, Cole DDG 67, The Sullivans DDG 68
Chicago CG 11
Chicago CG 11
