navydavesof
Post by navydavesof »
Fliger747 wrote:
Randy:
This looks quite revolutionary in some ways. Cheers from all around for tackling this project!
Another not so obvious modification to the ships on late refit was the addition of about another inch of plate around the combat center area. You can see the plate added on in this photo of the Port side from the 01 level.
This was 1 1/2" HY-80. This provided fragmentation protection to the Combat Engagement Center. It was added in 1985.
BB62vet
Post by BB62vet »
Randy - Looking good!!! Don't worry about the project - it will (and WE will) be here when you get back!!!
Tom, James M, NavyDavesof, et al -
The additional armor added in the '80s is all described in detail by Richard Landgraff in his book History of the Long Beach Naval Ship Yard. There are some interesting photos of the actual reconstruction of MISSOURI's armored CEC and Spook room. While they occupy the same space as on NEW JERSEY, the two ships are configured differently internally. Problems that arose on NEW JERSEY re. the redireciton of existing HVAC supply/elec. service to the Spook Room was modified and corrected on MISSOURI. These sort of problems arose due to the lack of (nonexistant) communications between the CIA "know it alls", NAVSEA design group back east, and the local shipyard construction & design groups. Long Beach Nav. Shipyd. was both ship's assigned Planning Yard and as such was responsible for the detailed drawings & construction of the reactivation effort. Thus, there are various differences between the east coast (IA & WI) and west coast (NJ & MO) ships. NEW JERSEY, of course, is obviously different due to her mid-60's reactivation & refit to her conning tower.
R.Ricardo
Post by R.Ricardo »
Hi to all,
Please, I have a question about Tamiya's Missouri. Today I received the new Missouri Kagero's book and in a superficial comparation between the kit and book plans the only substancial difference I see is the main turret's shape. Kit turret rear part is largest than plans, about 3,0mm to 4,0mm. Comparing with pictures I'm not sure about what's the most correct the kit or the plan. Has someone one idea about it? There are other reported issues on this kit?
Thank you in advance,
Best Regards,
Ricardo
Post by Fliger747 »
This was not the first time lack of communication between agencies had effect on this class. In retrospective it seems ludicrous the Bu Ord designed a larger turret with a larger barbette ring than Bureau of Construction and Repair had allowed for in their design! Yes a foot or two does matter!
RandyM
Post by RandyM »
Field update. I asked one of my engineers to unload the printer this morning and send me a photo of the results. Don't tell my daughter, but I'm very interested to get home and see how they fit :)
Note how the printer decided to support the aft-most section.
(I don't have photoshop on this laptop and have never tried to resize with the default windows photo viewer. So if the photo is gigantic, please pardon)
BB62vet
Post by BB62vet »
Randy,
This is really getting interesting!! Can't wait to see what your assessment is of the shell parts and their fit.
I'm sure by now that your daughter understands that all things must be put into perspective....and wait her turn :jump_1:
bigjimslade
Post by bigjimslade »
RandyM wrote:Field update. I asked one of my engineers to unload the printer this morning and send me a photo of the results. Don't tell my daughter, but I'm very interested to get home and see how they fit :)
Is it difficult to do bows and sterns in Solidworks?
It is in Turbocad and I am wondering if you have the same problem.
rtwpsom2
Post by rtwpsom2 »
bigjimslade wrote:Is it difficult to do bows and sterns in Solidworks?
Yes.
bigjimslade
Yes.
I can cross it off as an improvement then.
Randy's picture above shows a missing stern piece.
You can see the very same problem in mine
http://i1319.photobucket.com/albums/t66 ... c8a8de.jpg
You can't continue the loft of the hull frames to the point of the stern.
I had to create a plug of nearly the identical shape and size using Turbocad. That plug is in place in the picture. That is created using lofts going sideways.
The great similarity here made me suspect the Solidworks has the same kinds of limitations that Turbocad does.
RandyM
Post by RandyM »
It was difficult at first, most likely due to my lack of knowledge of SW. I originally tried to create the shell of the entire hull all in one piece. With such a complex shape, this proved to be challenging - the software didn't react well, and it bogged my (very fast) system to the point that I decided there had to be a better way.
So I spent a good amount of time building a complete half-loft based on the curves provided in the FDD plans. For reference, this is a view of the (starboard) loft from the aft quarter.
From there I split the hull into sections based on the amount of curvature in each, and I cut the bow and stern at the fore and aft perpendiculars. This turned out to be a good approach, as I was able to readily create shells of each section and then reassemble them into a complete hull. The bow and stern sections turned out very well. In the most recent photo of the shells, the tailcone is missing only because I printed it previously with the frames and keel (look back a few posts/pages for the photo).
bigjimslade
What type of construct do you use to create the bow? In Turbocad, I have to make that three pieces (at least) -- Top, middle, bottom. The stern I can make in one loft. I tend to run into problems at the bottom where the profile is a circular arc.
RandyM
Post by RandyM »
I used a boundary surface with appropriate edge constraints on the starboard half, then just did a body mirror for the port side.
RandyM
Post by RandyM »
(Note that I have also posted a question which is below the first group of photos...)
Results of first experiment: hesitant success. Collected the shells from the office this AM, and spent about 30 minutes cleaning them up. After that, they basically "clicked" onto the keel/frame assembly. So I removed them, taped them together, and reassembled for some photos. If you'd like to see some different views, let me know.
Several points to note:
1. as is typical of 3D-printed material, the surface texture is not "production ready" - it shows each layer of plastic as very small ridges. This can be readily corrected via sanding / filling, which I haven't yet begun.
2. in the images in which you can compare relative heights of the two assemblies, keep in mind that the kit hull appears to be sitting higher because it is: the corrected hull is sitting essentially flat on the floor while the kit hull is sitting on the fore/aft points.
For those who know about such things, I have also been working on modeling the #2 turret's 40mm mount. I noticed that the shield on this mount is shaped differently than the typical mounts: it rises up in the front rather than dipping down. Why? Is this used as some sort of field-of-fire limit to protect the director personnel sitting forward of the mount?
Post by Fliger747 »
Perhaps someone will know, but my guess is wind and spray and the additional possible depression would only be needed for abeam targets during an adverse roll such as manuvering. My recollection is that the firing interlocks for the quad mounts were not physical barriers, only the manually operated single mounts liberated from Army sources had those, usually a pipe arrangement to block the firing arcs.
The hull looks quite nice!
RandyM
Post by RandyM »
Weekend update... by the way, Happy Father's Day as appropriate. I spent a few hours this evening working on the conning tower and the 40mm mount on Turret 2. I continue to learn scads about the construction of these ships, and am generating what I think will turn out to be a great reference.
The conning tower hatch swings on its hinge :)
Cliffy B
Post by Cliffy B »
Question for you BB gurus out there. I was talking with Dave (navydave) tonight about the total number of shots the BB-61's fired in combat. Does anyone have or know where I can find a list of how many shells each ship fired in each war they were in? The only definitive numbers I have is roughly 6,800 for BB-62 in Vietnam, 600+ for BB-63 and almost 1,000 for BB-64 in the Gulf.
I'm curious as to how many were shot in WWII and Korea specifically. I've heard that the ships shot somewhere around 8,000 in Korea and I could have sworn I read somewhere that EACH ship shot that many. Dave brought up the propellant change though which would indicate that they would have had to change their barrels numerous times during Korea which I know they didn't do (numerous times that is).
Any and all help is appreciated as always.
BB62vet
Post by BB62vet »
Mike (Cliffy B),
I believe the 16" firing totals per ship per conflict are listed in a couple different texts - I will look tonight and post tomorrow a.m. with details.
Post by Fliger747 »
Not within 350 miles of my references but I think it was Sumrall that had the WWII totals, which were not huge. To take the ships out of front line service for barrel relining was a big consideration, most of the bombardment was left to the old battle wagons of pre war vintage. The fast fleet did some hit and run bombardment of Japan, which included Alaska, CB1.
With full charges the WWII era barrel life was probably 150 round/barrel or less.
Cheers. Tom
Ian Roberts
Post by Ian Roberts »
I'm interested to know the exact "type" of TDY jammers mounted on the Iowa in this shot: http://navsource.org/archives/01/061/016107a.jpg (they're visible at the whistle platform level just below the air defense level)
Anyone have any idea? From what I can tell, this is the earlier type without the back-to-back antennas and the prominent 10AFJ antenna pedestal (such as on this photo of the TDY aboard one of the DDRs). It looks to me like the versions aboard Iowa were basic corner reflectors that were static mounts (i.e., not trainable like the later TDYs). I think it's interesting how two TDYs are mounted - obviously to cover the port and starboard arcs for effective jamming.
Finding information on the TDY antenna has been incredibly difficult!
Russ2146
Post by Russ2146 »
My handy 1948 Booklet of General Plans of the Missouri lists the corner reflector antennas as TDQ's while the one forward on the whistle platform is a TDY. Give me your email in a PM and I'll send you the PDF of the booklet.
Russ
