1/350 HMS Hood (scratchbuild)
chuck
Re: 1/350 HMS Hood (scratchbuild)
Post by chuck »
EJFoeth wrote:
I added some semirandom detail with the voice pipes ending near the signaling area.
UHem. You forgot to hollow out the voice pipe. Voices don't carry in a solid plastic rod. :big_grin:
EJFoeth
Post by EJFoeth »
Thanks guys. If only I had 0.3mm tubing :big_grin: But that stupid stair :big_grin:
Post by ModelMonkey »
Exceptionally fine modeling and photography, too!
You are a true master.
EJFoeth
Post by EJFoeth »
So, experiment one with my new series of fine brushes, lining in black/umber and then highlighting by the light base colour plus white, trying to paint in the depth of color rather than a wash with drybrush. Now, some of these parts have already been treated slightly with the latter method
The aft searchlight platform is coming along nicely. The lines appear slightly excessive once added but look much nicer once dried. Some railing fell off, to be repaired! The ammo lockers were 'washed' in black and then the surface detail painted back on. Applying thin shadow lines there is a bit too difficult for me now, especially since I'm trying to get a feel how to properly mix the Humbrol, oils and thinner (Winsor & Newton Sansodor). Sometimes I need to correct so much it's back to washes!
With this black background the blue of the paint is not captured, but still there. Left turret lined, other one is not. More depth at the barrels, range finder and turret top plates. No special treatment for the bolts...
Left funnel untreated, right funnel lined in. More detail on the steam pipes and other minor surface details. Grill not yet painted nicely.
LE BOSCO
Post by LE BOSCO »
always a great pleasure to see your new progress EJFoeth :thumbs_up_1:
well done
cheers
Nicolas
JIM BAUMANN
Post by JIM BAUMANN »
my word-- your painting is looking pretty sharp!
......==> sort of follows with the dedication you have devoted to the construction...
If you are intending to flatcoat all;- or some--
I recommend the Windsor and Newton Galeria artist varnish matt
its very very matt and I have yet to see it ever frosting--unlike many hobby enamels
I cut it 60/40 with distilled water and spray at 15 ps or so...
watching you with interest
JIM B :wave_1:
EJFoeth
Post by EJFoeth »
Thanks both!
A coat hadn't entered my mind yet! The result is quite flat at the moment, except for the funnels (a bit too much oil). Speaking of oils and remembering your fair warning, I think I do like the lining and painting of detail to the pinwash and drybrush. Lots more work but that never stopped me :big_grin: Getting to work a brush and feel for when the paint is 'just right' will take some getting used to. One more hurdle to take; I know what can be done, so practice until it is done so.
Brilliant and effective technique! Absolutely lifelike. Your work is perfect.
EJFoeth
Post by EJFoeth »
thanks!
marijn van gils
Post by marijn van gils »
Great, you're on your way and it is looking very good!
EJFoeth wrote:Getting to work a brush and feel for when the paint is 'just right' will take some getting used to. One more hurdle to take; I know what can be done, so practice until it is done so.
Indeed, and it is a very personal matter too what works best. But getting both the dilution of the paint and the amount of paint on the brush right for the job at hand is indeed imperative. I probably spend about 1/5th of my painting time mixing paint and thinner, and removing excess paint from the brush, in order to get the paint to flow from the brush just the way I want it to.
Some more tips, for taking it even further:
- Be carefull with using white to lighten colours. For greys, it can work good and your results prove just that, but it can make other colours look "dead" or stone-like because white de-saturates colours. But also on a practical level it has disadvantages: white usually has a very heavy pigment en tends to dry very fast, and transfers these characteristics partly to any mix it is added to, making it more difficult for handpainting. I usually use a very light grey for lightening greys, or if I want to keep it "warm" a very light tan (usually Humbrol 148 light radome tan).
- Instead of simply painting all the deep parts dark and all the high parts light (like where a pin wash would flow), the control this technique offers allows you to paint according to the light. Light generally comes from above, causing deep shadows under detail and light on their top surface. Shading and highlighting in figure painting follows this principle heavily. The advantage is that since you emphasize natural shadows and highlights on the exact place where they occur, you can go much further without it looking axaggerated. So how to do it: paint dark shadows under overhanging detail, and paint only their top edge/surface in the highlight colour (but not the entire side).
- Filters. If you want to break the monotomy of large monochrome surfaces, you can apply filters. This is like a wash, but not intended to flow into the recesses but instead cover the entire surface, leaving a "filter" of another colour on top of the surface. The idea it is to subtly alter the bascolour with layers of very transarent other colours, in order to get a surface which has many tones in it and looks much more natural and alive.
It is mixed exactly like a wash: oils or enamels with white spirit or another thinner. But it is applied a bit differently: instead of taking a lot of paint on the brush and letting the paint flow freely over the surface, you make sure that there is not so much paint on the brush (by letting the excess soak into a rag or tisuue for example) and the paint only comes on the surface where the brush touches it.
To apply different colours, you can first wet the surface with some white spirit, and then apply irregular spots of heavily thinned paint of different colours. Usually, they need a bit of blending before drying to get a subtle result. On grey basecolours, I often use filters in different shades of blues, greens, red-browns, flesh-tone, ...
As the filters still do flow a bit into recesses, they are best applied before lining shadows or pinwashes.
Well, you said lots of work is no object! :)
Marijn
EJFoeth
Post by EJFoeth »
Thanks for the tips! I was already aware I am practicing with greys only and would have to do something better for other colors. Many of which are not on HMS Hood, fortunately. I still haven't figured out to do the decks but I suppose the tannish brown will work with white or lighter browns. I'll also try a run with light greys added to the base color, perhaps the light grey that is part of the mixture in the base color.
I've added some of the light tone to horizontal surfaces and the tip of ridges and so forth and most of the black below ridges etc. Only for the etch work (the lockers attached to the structure in the first image) I just added highlighted the relief; adding a thin line to the top of a 0.1mm etch line is a bit too much for me now. I also started to blend in highlights to horizontal surfaces of detail parts but haven't photographed those yet...
I've read & exercised with filters so I might give it another go. I certainly want to do it for the hull to let the various segments of the hull plating stand out slightly. It's cheating because that wasn't visible in real life, but some artistic license is allowed (try and stop me :) ).
You do seem to be fond of the flesh tone?
Brett M
Post by Brett M »
Just read through your whole build so far.....all I can say is incredible work! Those pompoms are insane with the amount of detail/time/work you've put into them.
Can't wait to see more as you progress!
Brett
Brett Matthews
EJFoeth
Post by EJFoeth »
thanks! Will continue to update, once I have those blasted stairs done at the superstructure levels (really difficult).
marijn van gils
EJFoeth wrote:I still haven't figured out to do the decks but I suppose the tannish brown will work with white or lighter browns.
Still be carefull with white; it can make tan browns a bit too "pastel"-like or even pinkish. Light beige and sand tones usually work good for lightening tan browns.
EJFoeth wrote:I'll also try a run with light greys added to the base color, perhaps the light grey that is part of the mixture in the base color.
Sounds good!
EJFoeth wrote:I've read & exercised with filters so I might give it another go. I certainly want to do it for the hull to let the various segments of the hull plating stand out slightly. It's cheating because that wasn't visible in real life, but some artistic license is allowed (try and stop me :) ).
I won't try to! :) We are anyway not building real ships but models, i.e. small 3D images of those ships. They are our representations of a certain reality, but a lot of interpretation happens on the way, and I feel so it should.
Filters can be used very effectively to set different panels apart. You can also use it to create subtle colour variation within panels too.
EJFoeth wrote:You do seem to be fond of the flesh tone?
Yep! It is a great light but warm colour that mixes easily with other colours. When used in filters, it also works good as a base for dusty effects.
Marijn
In striking contrast to EJ's fantastic micro-work, here's another model of Hood for comparison of scale, building style and detail.
Yes, it's made of Legos:
http://www.modelboats.co.uk/albums/memb ... 50&p=99317
Dino Carancini
Post by Dino Carancini »
...looking good EJ! :thumbs_up_1:
...but AP 507 C on the funnels and turrets!!! .... just kidding :big_grin: the black backdrop may cause some color alterations on digital cameras. Sometimes Photoshop can be succesfull balancing the white, and you get back the original colors, sometimes not ..
EJFoeth
Post by EJFoeth »
That's why they are not on the blog :big_grin: The turrets are coming along nicely. I added a small highlight to each of the individual bolts on top of the turret roofs... Painting in/on detail has been suggested to me on several occasions by figure painters and as I like that style the best of all painting styles I thought: fine, add two more years to your model.
EJFoeth
Post by EJFoeth »
Cats are an important part of my life and you've seen them in various of my posts. With the death of my Siamese cat Mouse we took it upon us to raise three new kittens. What should have been a perfectly good weekend just took a turn for the worse. An unleashed Alsatian broke into our backyard and took one of our Siamini's, more or less right in front of us. We managed to free Mary quickly, but she died 5 minutes later; she might have her neck broken.
This is how she is at the moment; her sister is biting her and wondering why she does not respond... the other cats are very much not at ease. We're really heartbroken at the moment. She'll be buried in the garden later today. She was 8 months old and by far the kindest cat we've had.
Pets are part of the family, and the loss of one is painful. My condolences, EJ.
JCRAY
Post by JCRAY »
We are so sorry. We have a Siamese she lights up our life. So Sad for you EJ.
John & Peggy
