1/100 HMS Zinnia ( 1915 )
Laurent
Post by Laurent »
Hi all ,
I didn't do a lot those last weeks
just glueing almost :censored_2: 80 rigols ( eyebrows ) to the portholes yesterday , a two hours job :
I used therefore 0,3 mm brass wire , wound around a 3,5 mm drill , it has been glued with CA glue ...
wishing you all a happy 2008 ,
Laurent
J. Soca
Post by J. Soca »
Fine work there Laurent :thumbs_up_1:
nick
Post by nick »
Really amazing!!
:thumbs_up_1:
Nichol Caballero
Avery Boyer
Post by Avery Boyer »
Looks so much like real plating! :thumbs_up_1: :thumbs_up_1:
Reid
Post by Reid »
o man NICE JOB!!
Reid, PIO of the 48th Fleet
http://www.48thfleet.com
Laurent
Post by Laurent »
Hi Guys ,
thanks for the comments !
Today , I was busy with the freeing ports , I try to do them moveable , like in reality ...
I did some attempts , some pictures will follow tomorrow ...
Regards ,
Laurent
Re: 1/100 HMS Zinnia ( 1915 )
Post by Guest »
I was going through my great grandfathers photo album and found a picture of the Zinnia. He served on her in the great war. I was doing a web search on the vessel when I found your build.
The photo is full length, port side, flying Royal Ensign about 13cm by 7cm, would a scanned copy help your build?
Regards
Richard
UK
Reid
Post by Reid »
WOW!! i love it when people do that kinda stuff... they pop in and say "i was on" or "i my ... was on" i think it really brings this hobby alive when you stories about you model from real people!!!
Avery Boyer
Guest wrote:I was going through my great grandfathers photo album and found a picture of the Zinnia. He served on her in the great war. I was doing a web search on the vessel when I found your build.
Regards
Richard
UK
How cool is that?? :thumbs_up_1:
Jimmy Conway
Post by Jimmy Conway »
Regards
Richard
UK
Richard, this photo will help and please all of us................ TIA!! :thumbs_up_1:
Nice regards: Jimmy
Make your influence positive!
Breton Fisherman's Prayer
Jimmy Conway
Laurent:
The plating is amazing and like real ships, full of imperfections...... Perfect!! :thumbs_up_1:
Nice regards: Jimmy :wave_1: :wave_1:
Post by Dave Wooley »
Nice job Laurent . Eye brows they can send you ga ga . I very much like your plating detail :thumbs_up_1:
Laurent
Post by Laurent »
Regards
Richard
UK
Hi Richard ,
Yes , I would be pleased to get a copy of this picture , but I would prefer to see this picture on this very forum , I'm not the kind of guy who wants to keep such information for himself ...
Many thanks anyway
Laurent
Edward Pinniger
Post by Edward Pinniger »
Looking very nice as usual! - particularly the hull plating detail.
I am soon going to have to make about 25 eyebrows for Peder Skram and 50-60+ for HMS Abdiel, a job I am not looking forward to - although I've had some success using metal wire ones as you have done, I'm considering ordering some PE ones from John R Haynes, which aren't too pricey.
Zinnia
Post by Zinnia »
I have added the photo of Zinnia to the pictures section.
Glad to be of help.
Richard
Devon, UK
Laurent
Post by Laurent »
Hi Guys ,
it's been a long while , he ?
I've been busy , a lot , those last weeks , so there couldn't be worked on Zinnia ...
I've built the washports , they are done in cardboard and are mobile , they swivel round a brass rod :
seen from inside :
I did them mobile to be sure that any green water coming on the decks will wash away while sailing , it really is a little model on the water
As many , I always have had problems with soldering brass ...
I decided once again to give it a try , and this time , I succeeded in soldering one of the mast's shrouds & rat lines and some two holes stanchions .
the stanchions are made out of a 0,5 mm wire , with 0,3 mm thick bras wire for the holes :
I did already 20 stanchions , still 50 to go
here under the after mast rigging , I used 0,5 mm wire for the shrouds and 0,3 mm wire for the rat lines :
other updates should come soon :wave_1:
Regards ,
Laurent
Andy G
Post by Andy G »
Soldering your own stanchions, eh? I'm watching with great interest! Lovely work, Laurent!
Andy
Hi Laurent Impresive and I do like your solder work .
Dave Wooley :thumbs_up_1: :thumbs_up_1: :wave_1:
Laurent
Post by Laurent »
Hi Guys ,
thanks for your inputs :thumbs_up_1:
This week , I worked a little on the two masts rigging .
here under my way of soldering the stays & ratlines :
the masts being fitted & rigged :
to fix the upper part of the stays , I use home made shackles , made in 0,3 mm brass wire
the stanchions holding the wheelhouse deck
I got from someone , an english man , a few days ago , a picture of the Zinnia , while at anchor , in february 1935 , this picture is very sharp :
Of course , if I had had this picture beforehand , I would have done some things different , I just see now that the ladder on the wheelhouse deck leading to the monkey bridge has been moved from the left side of the wheelhouse to the rear , I also see that the wheelhouse deck has been enlarged ...
:mad_2: :pout:
Well , some further works that will have to be executed , nothing worse , might be happy instead , I guess :woo_hoo:
Regards ,
Laurent
Avery Boyer
excellent work, very sharp and delicate! :thumbs_up_1: :thumbs_up_1: Can we have an overall view of your build as it is now? :cool_2:
(PS: I will have the QM plans copied this week and sent off to you :wave_1: )
