[quote="KRONMA"]
I too so think.
[quote]
Thank you very much Kronma!!
I think the mast is logical, there doesn't appear to be any other vertical support.
Here are a couple more photos for evidence..
http://www.mediafire.com/imageview.php? ... yt&thumb=4
http://www.mediafire.com/imageview.php? ... o0&thumb=4
I see you have posted much better photos. Thank you again!!!
The photo on the bottom left lets me see much more clearly
The whole mast is clear to see I think!!! The pattern seems to be consistent in all the photographs too.
When I was trying to find evidence for my proposal, I was quite excited when I looked at the photo of Borodino fitting out in the background. I think it is very interesting that it should be consistent with other photos in showing something that could be masts. But as Darius says, it was not clear enough to be conclusive.
http://www.mediafire.com/imageview.php? ... wm&thumb=4
and with the masts in blue.
http://www.mediafire.com/imageview.php? ... 2c&thumb=4
And thank you again for all your help, it is really appreciated. Ideas can only be good if there is evidence to back them up.
The model of Slava is incredible. I didn't kn ow it was radio controlled too!!! I want it!!
Hi Darius,
thanks for the photo of Orel. I don't know what happened by the steam pipes. The boom seems to go very near in this photograph, see "1" in this photograph.
http://www.mediafire.com/imageview.php? ... pt&thumb=6
You can maybe make out that the boom is above the level of the square base.
If you look at the "2" in my photo I think you can make out the back wall of the navigation bridge. The windows are consistent with going from side to side and are not in the correct arrangement for the starboard wall of the navigation bridge.
From your photo I can see some differences between Orel and Borodino, for example the width of the cabin behind the navigation bridge. Is this the captain's cabin in Orel too? I have had a look at your "2" and it looks like where the pulley is attached. I don't think the shape of the top necessarily has to be the same shape as the mast. It could be the same, it could be different. Also it is Orel and not Borodino and could be a different shape from Borodino. It is a different shape in the Orel plan than the Borodino photograph. I think it is better to take each ship individually...
Thanks as always
John
