1/350 DDG-95 Uss James E. Williams (Trumpeter + Pontos) Done
jph82697923
Re: 1/350 DDG-95 Uss James E. Williams (Trumpeter + Pontos)
Post by jph82697923 »
wow?fantastic?nice work?I have learned your skill?thx
Fossil_13000
Post by Fossil_13000 »
What a wonderful build. I am enamored by the detail you have put into the project. I have one question if you don't mind, you spoke of a taping technique for creating the small shading effect on the hull. Are you doing the base gray then overlaying a tape grid pattern on top then adding a light misting of white over it the get the shading effect?
I have attempted to use other methods to add more detail to the hull but what you have done is by far the best I have seen.
Would love your advice on proper shading technique.
Thanks and regards,
Koppalakki
Post by Koppalakki »
Fossil_13000 wrote:What a wonderful build. I am enamored by the detail you have put into the project. I have one question if you don't mind, you spoke of a taping technique for creating the small shading effect on the hull. Are you doing the base gray then overlaying a tape grid pattern on top then adding a light misting of white over it the get the shading effect?
Thanks and regards,
Hey,
Yes I use a tape method to produce the oil canning effect on the hull. Like you said, first the base grey, after that I start with the horizontal lines, which are tediously masked one line at a time, then sprayed with the base grey lightened with white.
After all the horizontal lines are done, I start masking and spraying the vertical lines one by one. And yes it's a tedious process and would prolly be easier with a self made specific mask. After all this is done I mist coat another lightened grey shade to tie and blend the effect down. This usually with reference in hand as it's not equally intense in every area.
Here's a few shot of a different project for examples:
The bow area only has the horizontal and vertical lines without the mist coat.
The stern with mist coat already applied.
Return to “Completed Models”
