About all I can say now is the down ladders are far steeper than the up ladders but y'all already know that
- Cliffy B
Which ladder(s) do you want?
RandyM
In exchange for your kind offer, I will share a very embarrassing moment in my brief career in USCG. After being aboard USCGC Rush for perhaps a week, GQ sounded, and I did not yet know the correct paths to get from below decks up to CIC where I worked. Anyway, I was "running" up one of those steep ladders (grab the rails and jump 2-3 treads at a time), only to discover in an very unfortunate way that the hatch OVER the ladder had already been closed/dogged. My head hit the hatch wheel so hard, they found me lying at the bottom of the ladder several minutes later. When asked why I didn't see the hatch, I told them the ladder was too steep to see the top while hurrying
I'm interested in two ladders: both on the 04 deck: at frame 92 the one leading up to 05, and at frame 110 the one leading down to 03. I would assume they are the same, but you never know...
- BB62vet
RandyM, Fliger747, CliffyB, etc. -
Re. Angle of Ladders
I will consult with my BB guru in Long Beach, CA (the one who worked on IA, MO, NJ, and WISC) and authored the LBNSYD book. If anyone knows the correct angle of ladders, it's him.
As Young Mr. Grace (Are You Being Served?) would say - "You've all done very well!!
From personal experience - USS STODDARD (DD-566) Gulf of Tonkin - 1966 - we took a 4 or 6" airburst to starboard one day @ change of watch around noon. I was on th stbd wing of the bridge handing over the IC phones and we immediatly went into GQ - I ran down the stbd side of the ship to MT. 33 (my GQ station) and can't recall actually touching the two flights of steep ladders from the bridge level (02 Level) to the main deck - I used my hands on the rails and slid down both. I think the VC were aiming at me because the following 3 air bursts seemd to follow my path back aft. No matter, we nailed their asses with an hour long barrage of both 3" and 5" fire - set the entire small island on fire. GO NAVY!!!!
Great story Hank! Not sure either of us would get past the first one like that today, the abilities of youth (spurred on by adrenalin)!
Regards Tom
Regards Tom
- Cliffy B
Oh man Hank! Eat it shore battery!!! Reminds me of the story when BB-64 took her one and only hit from a 6" shore battery in Korea. One hit the ship and a full broadside hit the shore battery. No more shore battery and half the island was blown away
I'll check those ladders tomorrow guys.
Dave brought up an interesting point during his trip to BB-61 yesterday in regards to 25mm Bushmasters and their locations on the BB-61 Class. BB-63 and 64 have base rings (1 per side) still attached to the deck aft of the 40mm saluting guns on those old 20mm tubs but nowhere else. Dave discovered a grand total of 4 on BB-61; 2 aft of the conning tower on the O5 and 2 on the after ABL decks, forward of the ABLs. Anyone know if BB-62 has any or any other info about them at all?
apfelzra1
radars on the Korean War USS Missouri
I'm modeling a 1951 USS Missouri from Tamiya's old (1985) 1:350 USS Missouri kit, which of course was designed for late WWII. I know from photos of the ship at this time that the large dish-shaped SK2 radar was gone from the foremast, but what replaced it? Also, what were the fire control radars used at this time? Thanks in advance for any assistance.
- BB62vet
Thanks, CliffyB!!!
RandyM - still working on an answer on the ladder angle.
Now - here's a question for you guys - the attached photo shows two pieces of equipment that were retained in the After Mk. 37 FC tub on NEW JERSEY in 1967 - they are Target Designators, but NOT Mk. 1's as were shipped on the WWII & Korea vintage IOWAs. I haven't been able to find any info on these units and have made a CAD drawing based on guesstimation and this one photo. So, any help on finding out the Mk, Mod, and data on these units would be appreciated.
The stbd TD is partially disassembled and the port TD is complete (I think). I have corresponded with Fliger747 re. this, but still no info as yet. These units were decommed on the ship in 1969 and removed later during her 1981-82 refit in Long Beach.
Below is a CAD rendering of the unit based on the description above:
Once again, Thanks for any assitance!
- Cliffy B
Sorry, I couldn't get the ladders today as we were too busy. I'll try again later this week. Think I'll go in early so I don't get caught up doing other things like today
- BB62vet
RandyM, et al:
Re. the ladders - my contact from the shipyard states that 65 deg. was perhaps the more common angle if you could say there was a standard. More likely, the ladders were placed at 10 deg. more than an industrial ladder would be placed in a similar situation. But, the consensus is that ladders were set at an angle that worked for that particular setting.
Hope this helps!
Hope this helps!
- Ronald47
BB62vet wrote: As Young Mr. Grace (Are You Being Served?) would say - "You've all done very well!!
Greetz, Ronald from the Netherlands.
My Blog: http://metusajunction.blogspot.com
My photos: https://www.flickr.com/people/52307730@N06/
Interesting about the ladders as that implies that there might not be a standard tread angle for manufacture of the ladders.
Cheers. T
Cheers. T
The USN specs I found declaring that inclined ladders shall be installed between 50 and 60 degrees. The tread design is such that different widths are available and bolt holes are provided with one elongated such as to allow some adjustment for the individual instalation.
T
T
- BB62vet
RandyM -
Have you a copy of the MISSOURI Plan Book (TFD)? If so, the scaled drawings should give you a very good idea of how the ladders were positioned, etc. If you were to blow up any particular page, an angle could be figured where needed.
A reply re. std. tread angles on ladders - I don't handle the structural drawings in my Eng. CAD group, but I'll ask my arch/struct. guru and see what he says. I am thinking there are stds. for industrial ladders, just maybe not military hardware where the angle is dictated by allowed space.
Certainly when the Iowa's were built there wasn't no stinkin OSHA....
HNSA had an interesting document on the specs for inclined and verticle ladders. There are three different tread widths, used dependent on the installed angle of the ladder. The awarthships ladders from 02 to 03 level abaft the flag bridge are certainly steeper than some of the fore and aft ladders such as to the bridge. These particular ladders replaced a verticle ladder at this location at some time in the ships early career.
T
T
- BB62vet
Fliger747 wrote:
Tom
do I detect a bit of closet distaste for our behavioral watchdogs???
And we wonder why things cost so much.
HNSA is a great source for shipboard technical info. I hope they continue to add to their online technical library.
And also most (if not all) the regulatory agencies that exist today "for the common good!".Certainly when the Iowa's were built there wasn't no stinkin OSHA....
Tom
HNSA also has an informative piece on doors and hatches. I am amazed however that the very detailed info on the MK37 fire control system mentioned the target designators, showed how they integrated in the schematic then never had another word about their operation. Somebody had to learn how to use them, hence a manual exists, or existed, somewhere!
Were there designators on the 011 level?
Cheers. Tom
Cheers. Tom
RandyM
Took a couple of screenshots showing two different style ladders...
First image shows the two ladders together... and how different they look. The 50-degree ladder is obviously too shallow. The 63-degree version was chosen to fit in the space available for the forward ladders between the 04 and 05 decks.
In this triple-ladder area back by the stack, it looks like the 58-degree version would fit just about perfectly.
RandyM
Ok, it's pucker time. After making some minor modifications to the hull skin design, I printed everything out (including the tailcone) at high resolution - took 16-hours this time.
Next I carefully aligned the shell pieces to the keel/frames and taped everything to the kit's aft maindeck piece (first photo below).
Then I inverted the correction assembly and placed in on the kit hull (which has the forward maindeck piece inserted/taped). I mated the deck pieces together and verified the kit stern and corrected stern line up (they do!). This gave me - theoretically - the precise location at which to cut the kit hull (second and third photos).
So now I have no excuse but to install a new blade and start scribing: wish me luck. I'll post photos of the decapitated hull just so you know I'm not pulling your leg(s)
I expect to have to cut the hull back another 1/2" or so to get the transition from accurate kit shape to corrected shape, but, baby steps as they say.
RandyM
As it turns out, Trumpeter plastic is pretty much PERFECT consistency for this sort of surgery. I scribed with a #24 blade down to about 1/3 the thickness of the hull (which is 0.10" in this area), then used a razor saw to cut through. The whole operation took ~ 10 minutes, and the cut is so clean I could probably re-attach the kit piece with a minimum of trouble.
Anyway, if you look at the photo carefully you can see that there is a fairly significant mismatch at the chine. This was expected, and I couldn't really do anything about it until I could get a really accurate cross-section of the kit hull in this area. Now all I have to do is scan the hull and determine how much more I need to cut back to transition into the corrected shape.
It's pretty nice to be working back in the physical domain, even if my first act on this kit was to cut a perfectly good hull in half... in the wrong axis
- BB62vet
RandyM,
After looking at your radical surgery on the hull, I'm feeling very queasy right now
But, it looks like you've got the handle on what needs to be done to arrive at a successful conclusion on this. I'm pulling for you ya, dude!!!
