Revell 1/350 USS Wasp LHD-1
Re: Revell 1/350 USS Wasp LHD-1
I'm a former helicopter mechanic* and we had to do that quite often to get our birds in and out of hangars from time to time . :thumbs_up_1:
*Civilian, non-military
kidcurrie42
Post by kidcurrie42 »
I am sure that the tail was folded before being put down below, Great work
Happy Modeling
John
Si Vis Pacem, Para Bellum
Nansen
Post by Nansen »
Thank you John. Yes, I agree. It meens modifying the tail. Should not be that difficult. And thank you for the pictures Tracy. Much appriciated.
Erik
LE BOSCO
Post by LE BOSCO »
HI Mansen
you end up with the same problem as the true,lack of space :smallsmile:
your illuminations are the most beautiful effect
best regards
nicolas
Nansen
Post by Nansen »
Thank you for the kind words, Nicolas.
The space issue will be solved with a little Heli modification :thinking:
Erik
Nansen
Post by Nansen »
One of the reasons why I really like this kit is the possibilities it gives to modelling different items. I re-sprayed the hangar walls and while waiting for the paint to dry I went back to the AAVs. Mine will be used to fill the well deck so I think I will get away with the fact that they are 1/285 scale. As long as they are not mixed with the original vehicles I think it will be okay (and of course the fact that modern 1/350 vehicles are not easy to find...). I bought the vehicles online from this store: http://www.ghqmodels.com/
These are WIP pictures. I sprayed them NATO green and hand painted the black and brown camo. I masked and sprayed the first AAVs I built, but I'm more happy with the hand painted ones in this scale. At the moment the vehicles have a white "wash" to blend and fade the camoflage colors. Next steps are some touch ups, a gloss coat, a black wash and some detailing followed by a dull coat and finally antennas. Rather easy actually.
Bigdaddy Mark
Post by Bigdaddy Mark »
First, no one will look in your well deck and say, "Hey I think those are a bit out of scale."
They are going to look down that tube and say, "Holy :censored_2:!! Those bad boys look real!!"
I'm following your build, and I keep picking up my jaw.
Your picture is backed up by my son, who told me I NEED green lights in the well deck.
Like your picture shows, I'm going to put green in the well deck, but at the top of the ramp I'm going with white.
I just started my build, and I'm going to do the USMC equipment, the LCAC and the aircraft first. This way I won't be tempted in hurrying threw them in the end.
Again, GREAT JOB so far.
~ Chester W. Nimitz ~
Nansen
Post by Nansen »
Thank you for the kind words, BigDaddy.
By "the top of the ramp", do you meen the ramp to the vehicle deck? I put two white LEDs there but should have used four.
I did the same as you when I started the kit. I finished a LCU and a LCAC and lots of vehicles before starting on the ship. The rest of the equipment will be done in and between shipbuilding. There is a ton of fork lifts, cranes and tractors to be made.
Erik
Bigdaddy Mark
I'm going to use LED strips, so I'm not sure what will fit. I did order a pot so I can tone things down if it's to bright.
Dave from Downunder
Post by Dave from Downunder »
I bought some of these deck vehicles from jag
http://www.jagcollective.com/wasp_deck_vehicles.htm
and from Iron shiprights
http://ironshipwrights.com/aavp7.jpg
http://ironshipwrights.com/lav25.jpg
http://ironshipwrights.com/pages/ch-53.jpg
They also had some M1A1's
I painted these up to populate the vehilce deck behind teh well deck. So to keep teh kits ones and teh WEM PE for ones that can be easily seen
Dave
1/350 Slipway:
USS John C Stennis
Stennis CBG 2002:
Operational:
CG73 USS Port Royal
DDG73 USS Decatur
CG57 USS Lake Champlain
FFG33 USS Jarrett
Planned
DD967 USS Elliott
USS Salt Lake City (SSN-716)
USS Jefferson City (SSN-759
Nansen
Post by Nansen »
I have ordered the JAG deck vehicles as well, but they have been bought by Admirality Model Works and it will take some time before they are back in production. The CH-53 looks interesting.
Nansen
Post by Nansen »
I was asked on another forum to post a picture with vehicles on the well deck. For my own amusement I think I will add some additional vehicles ie some Humvees and trucks.
Photo with green light on (I forgot to turn off the hobbyroom lights).
It is possible to see the white light on the vehicle deck
After the photo session I worked a bit on the AAVs. I gave them a heavy black wash using MIG Abteilung oils. I was a bit sceptical to this product, thinking it was some kind of modelling fashion jippo. However, even if these oils are expensive the tube will last for a long time and the paint it selves is very good.
The vehicles got antennas from streched sprue and are now ready for some detailing and touch-ups before the last dull coat.
Nansen
Post by Nansen »
Hmm, maybe I should try to convert Wasp into this? :cool_2:
I think you could fit that into Wasp's well deck... it would certainly cause some double-takes when people looked inside! :big_grin:
sgtryan13
Post by sgtryan13 »
Really awesome work goiung on here, well done, and well floor looks 100% better, glad I could help! The lighting effect you have achieved is particularly effective, looks perfect. :thumbs_up_1:
Nansen
Post by Nansen »
Okay... I would like to hear the story about who decided to include cockpit interiors for the AV-8B Harriers. This idea must have been thought of at a VERY late stage of WEMs Christmas party or another big event where lots of strong alcohol was consumed from bucketts and large jugs... :mad_2:
I have just binned both aircrafts after taking the challenge to install the PE cockpit interior. I will say it is impossible to fit this cockpit to the Harrier until someone shows me a picture of a finished one.
And now off to browse the online stores for spare airplanes...
Erik
Nansen
Post by Nansen »
Well... After the Harrier disaster I decided to go back to the hangar deck. Mine is getting a scratcbuilt roof and I cut the "main roof" from a 0.5mm Evergreen sheet. After a little sanding it fits like a glove and this helps on my self-esteem, being able to at least do some simple scratch work... It is still a bit long, but I was not really sure how long the roof needed to be so I made it longer than necessary.
I also made a missile cart as some sort of revenge over the crashed Harriers
Erik
Bigdaddy Mark
Eric
How much room will you have between the scratch built roof and the flight deck?
I was thinking about doing the same thing to hide the light strip.
Nansen
Post by Nansen »
I'm just about to test fit. My plan is also to put the leds in the roof, but I need to check the space as you mentioned. Will post as soon as I know.
