1/100 HMS Zinnia ( 1915 )
- Laurent
Hi Guys ,
not been able to answer earlier , sorry ...
Thanks for your words
I'm now drawing on the first layer the whole plating , where the IN & the OUT strakes go ( not forgetting some IN & OUT strakes there in between ) , where the laps go , where the water inlets & outlets , portholes , etc ...
on this hull , I will not bore holes where the portholes come , there will be some transparent plastic to materialise the portholes windows , with a black paper behind ...
later on , the superstructures will be hollow and then , the portholes & other windows will have to be made , as in the reality...
No pictures today , I should have drawn the whole plating by saturday & I should only then take pics...
See you !
Laurent
See you !
Laurent
Just call me the "Cereals Box Killer" , I guess
- Laurent
Hi Roel ,
My latest project took almost one year to be ready , so , I guess this one should take one year either , let's say november 2007 , ready to be shown at our club yearly "best of show models" ...
About the sharp bow , I've seen too many models with a very heavy unrealistic bow , I know how & why such errors happen & how they easily can be avoided ...
I maybe could write an article on this somewhere ...
I'm a kind of a annoying & captious nerd , I always consider that a hull is the most important part of a model .
When I see , study & eventually evaluate models , if the hull is distorded or not so well shaped , I don't look further on the model
I shouldn't do that , but heh ! I'm looking for perfection , even if I'm certainly not the most perfect & better model builder myself around here ...
Cheers ,
Laurent
Cheers ,
Laurent
- Neptune
Hey, you can't carry the same flag as I do at the moment. You know our country has seperated now
Well I think you're not the only one looking for perfection. My LNG is looking pretty ok at the moment, but the hull is a disaster and so I'm not considering her a succes up till now.
The hull is the largest part of a ship and therefore it is indeed very important! On a warship the superstructure is pretty large, so at least you could look further than that
Maybe I can make it to your show!
The merchant shipyard
- Dave Wooley
Hi Laurent Good project l I do like the bow and the way you have constructed the hawse pipe plus your ideas for the deck. I tend to shy away from making my own props and go for one from a manufactures that specialize in props like the the Prop Shop or George Sitek it's worth it in the end.
- Laurent
Hi Dave ,
I never made one propeller myself , but I want to give it a try ...
My problem is that props being 30 mm in diameter , 4 bladed with a M2 thread do not exist .
I know I can ask to PropShop to make one for me , but I'm a little afraid of the costs involved ...
about the hawse pipes , this is one of the reasons I always have loved plumb bows , the hawse pipes always look terrific ...
Roel ,
no , we are not separated yet , it was just a bad TV joke ...
Regards ,
Laurent
Roel ,
Regards ,
Laurent
- Laurent
Hi all ,
about the plating ...
as I already have told , the plating on my models is made out of paper or cardboard , depending on the desired thickness .
Zinnia had a "baby skin" , most of the plates being .25 inch thick ( about 6 mm ) , each member being 21 inches apart .
I had the opportunity , when I got the NMM plans offer , to buy Zinnia's shell plan .
hereby some scans of it :
an interesting view of the scantling used on the deck sides
not really useful for 1/100 or 1/96 guys like me , but there are also on the shell plan datas about the riveting :
All those datas ( strakes & butt laps ) have to be drawn on the hull .
There are two ways : beginning from the keel line up to the deck or from the deck line down to the keel
In my case , I was more sure of my keel line , my decks being not glued on the hull for the moment .
hereby some pictures of the strakes being drawn on the hull ( there were some corrections made afterward , the two sides having to be at the same level )
strakes B , C , D are to be seen here ( strake A being the keel plates ) , with the IN & OUT plating system :
Plating around the bow : IN or OUT , with some parts being IN & OUT
the stern part :
the next step will be putting & glueing the IN plating first ( strakes B , D & F ) , I'm beginning with it tomorrow
As we will see later , a shell plan , on the contrary of what most modellers do think , doesn't show the actual shape of the plating ...
this peculiar shell plan is just a kind of a diagrammatical plan of how the plates are riveted together and where the strakes are intended to be on the hull
Once the strakes are drawn on the hull , you'll see that most of the plates actually used on a steel hulled vessel were plain rectangular , there were no "banana" shapes involved...
Yes-yes , you may believe me
regards ,
Laurent
the stern part :
regards ,
Laurent
- JIM BAUMANN
..... there is a lot of work in there!!
Very good stuff--I shall be watching!
JIM B
JIM B
- Edward Pinniger
- Laurent
Hi all ,
I didn't begin already with the actual plating , I just drew all the plates on the hull , hereby some pictures :
Before the plating can be put on the hull , the main deck had to be glued on the hull , what happened today ...
to change a little my mind , I also began with the "wooden" deck ( cardboard , actually )
This is my usual manner to represent wooden decks at 1/100 scale , easy to do and it looks realistic ...
I usually coat the "wooden" decks with two layers of matt varnish , from a spray can , available in the automotive industry , and it becomes waterproof ...
any comment welcome ...???
Cheers ,
Laurent
Cheers ,
Laurent
- Laurent
Hi Admiral ,
you're right about the planks length ...
For the deck planking , I always represent it following what I read in the John Bowen's book "Scale Model warships" ( my Bible for years ) : I put a end joint at each 5th plank , like this ( the same picture appeared on page 2 of this very topic ):
this is how I understood it , in the book above mentioned , they tell "the butts are shifted so that the ends of the planks only occur in the same line every fourth plank "
Am I right here ?
Laurent
Am I right here ?
Laurent
- Laurent
Hi Guys ,
I didn't have much time to model those past three weeks ...
I just finished my "planking" for the main deck & the f'c's'le deck , that's all ...
the main superstructure coaming is there also .
I'm now in the process to build the CO's cabin , using therefore cardboard from a italian "lasagna" box
Stay tuned , I should post some further pics tomorrow ...
Regards ,
Laurent
Regards ,
Laurent
middle_watch
Unusual subject, and a fascinating use of carboard!
Re Q ships, they were only succesful in the early years of the war when the U-Boats followed the rule of surfacing and giving the crew time to abandon ship before sinking with guns. Some accounts claim that Q ships were so succesful they forced the U-Boats to assume the tactic of torpedo attacks without warning, frankly I doubt it, Q ships operated in such a way as to tempt a U-boat to save torpedoes and engage with guns instead. Either way in 1917 the balance swung and more Q ships were being lost to U-Boats than vice versa and their use was largely discontinued until the Americans revived them in WW2.
Zinnia was Azalea class and only one of those was converted to a Q ship, the Begonia, which was Q-10, known as SS Dolcis and SS Jessop, she was lost in 1917 in the Atlantic, believed to have been either torpedoed or she rammed a U-Boat, maybe both. Sadly as yet I have not traced any detail on her conversion.
Anyway, following your build with interest, nice to see this obscure class coming to life again.
- Laurent
Hi Jef & Middle_Watch ,
thanks for your comments ...
about the Q-ships , I remember I once saw a modelling plan , and the hull profile showed a lot of similarity with a WW1 "Flower" class vessel , I should check my sources ...
As already said , Zinnia is my first "man-o-war" , I wanted to start with something "manageable" , both in size and in "quantity of fittings" ...
My next naval ship should be a Destroyer , maybe the HMS Swift ( 1907 ) , or maybe a "I" class destroyer ( "Icarus" or "Ilex" , both built at Clydebank in 1937 )
I didn't do a research for plans yet , "Ilex" should be easier to find than "Swift" , as she was the only one of this design ( NMM Greenwich should be the way to go ) ...
yeah , I know , my cardboard mock-ups look odd , but this is what our pioneers in modelling used 70 or more years ago , before "plasticard" even existed ...
I still continue to think that modelling is like illusion , whatever material you use , if the results obtained look realistic , there you are , you reached your goal ...
cardboard is cheap , it can be made waterproof with modern resins , and , more important , it is lightweight , it means more ballasting in your hull , to get a stable model on the water ...
Regards ,
Laurent
Regards ,
Laurent
