Atma wrote:
1) Yes USS North Carolina class had terrible severe problems with the turbulence on the propellers, USS South Dakota had better armour than USS North Carolina and no severe turbulence problem in the propellers. Those facts dosnt change.
2) Simple put, USS South Dakota class was the epitome of battleship design for the United States Navy.
1) The South Dakota class suffered from vibration problems too, if that is what you mean by "severe turbulence problem in the propellers."
A many bladed propeller test was tried out in the following sources:
"Battleships", US BB's in WWII/Dulin & Garzke, Anna,MD.,various editions,
U.S. Battleships: An Illustrated Design History by Norman Friedman. page 287: ...."The designers cut the necessary area out of the bottom of the hull, forming a tunnel". "In its case, the chief risk was vibration due to interaction between propellers and skegs".(...)
Page 294: "All ships but Indiana (BB-58) were completed with four-bladed propellers on each shaft". (...) "Model tests showed that five-bladed props inboard would be superior"(...)"Vibration trials (Indiana) in September of 1942 showed this arrangement superior to the 4 blade outboard/3 blade inboard combination installed aboard the South Dakota (BB-57) and the 5/4 combination was installed aboard the Massachusetts (BB-59) (1944)"(...) , etc.......
Massachusetts, (Ship's Data)-Leeward publications, Anna, MD. 1979, page 22: (...) "A variety of propeller configurations was tried, in an effort to reduce vibration at high speed"(...) (...) "Alabama (BB-60) trials showed severe fore and aft vibrations due to inboard strut-supported propellers, and rather less severe athwardship vibrations due to the outboard skeg-supported ones; as a result the inboard four bladed propellers were replaced by three-bladed ones". "Five bladed propellers were also tried"(...)
As with the North Carolina class, they eventually found the right combination of propellers to reduce the vibration to an acceptable level.
2) I am curious as to why you say that the South Dakota class represented the epitome, rather than the Iowa class, given that the Iowa is for the most part a larger, faster South Dakota, with more powerful 16" guns.
