Have been working on the bridge wings today. These are quite difficult as every side is an angled cut! There are no square cuts or corners so a lot of templates and trial and error.
AT
1/72 Arleigh Burke flight iia
1/72 Hobart class AWD HMAS Brisbane viewtopic.php?f=13&t=154767
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 HMAS Perth 1942
I'm wondering who's after you... Someone with a gun wants to have this one finished tomorrow?
I admire you're quick pace at building this ship. I guess the FFG is not advancing much nowadays
So am I correct in thinking that you're actually going from the de Bazan plans rather than the proposed or actual Hobart class? Or are there already plans or pics of the Hobarts' final design available?
Hey Neptune, I'm keeping a steady pace I suppose. Only doing a bit here and there. Newcastle is sitting on the side for the time being, a little FFG'd out so a nice distraction. I will finish Newcastle though.
Using blown up f105 plans from the net and a lot of pictures from Russ French's builders models and another Task force 72 member. The hull is by Allan Pew also from APS models for the F105. So the smaller detail will be relying on photographs and again Russ French as there aren't any Australian AWD plans available yet. She might not be exactly as the Hobart will be when launched but I can 'refit' her when the time comes the final design is the same as the Spanish F105 so that parts not a problem.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
Port bridge wing now fitted. A lot of cleaning up needed but all pieces are cut from the same template I used for the starboard side so at least my AWD is symmetrical unlike my FFG
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
The angles are fun for a change, ill have to do something with the Steregushchy soon as its for my son to use and for us to build together. He's helping me with the AWD as he traces all the templates for me, every little bit helps.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
Thought I'd post these pics up of the �lvaro de Baz�n F-101 in the port of Fremantle back in 2007. Even though the hobarts use the F105 as the base design the appearance is still very much the same with the Spanish Armadas F101.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
At least you won't have to scour the internets looking for an appropriate kit for the helicopter. I'm sure Hasegawa makes a good one for you to use in 1/72 scale.
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
G'day Sean, yep they sure do. There's also a resin conversion set to turn her into an RAN version and decals available. So much much easier this time just reminds me after all the work i put into Newcastle, I really need to finish her off
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
Not much new done on Brissy over the last week, just mainly filling, sanding and cleaning up the structure to date. Planning on taking her back down to the lake tomorrow and do a waterline/ballast test. To do this I thought that she will need a mooring buoy to help me keep her in place so as most have done, made up a mooring buoy from PVC pipe and scraps.... Though I may have got a little carried away after I saw Russ's mooring buoy for his hobart - challenge excepted!
Tube with scrap styrene ends.
Cleaned up edges on buoy and stainless eyes screwed and epoxied into place. A chain will be connected to a weight on the bottom with the mooring line attached ontop.
This is when I got excited
Painted and ready to go
Last edited by Perth_shipyard on Mon Jan 13, 2014 12:04 pm, edited 1 time in total.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
A couple pics from this morning, the mooring works great and held Brissy easily - I did drop it coming out of the car so one of the rails broke off but adds some character
The black tape is where the waterline should be. The only ballast I had in her was two 12v batteries more than plenty of room for four adding an extra 5-6kg so should be enough keep her down. If anymore is needed ill just use lead sheets.
Roberts awesome Peter the Great behind Brissy. At 3.2m makes my Brissy look small!
The small selection at the lake today including Andrews cool HMS Monitor
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
Haven't done much building as such but have started to trial RC gear layout with ease of access.
I have two huge Crest motors which are popular with the TF72 guys for big ships and what Scott has used in his Sydney and rob in his arleigh burke. So it's the way I had to go. I've also fitted a shelf for the ESC'S and receiver under the rear hanger roof. My first was too short so have extended to make easier access. At the same time i decided to extend the rear opening further forward so it goes under the rear stack. If i need to later, getting to the motors will be much easier now. You should see two tubes poking up on either side of the shelf, these are extensions from the prop lube tubes. This way there much easier to fill - I hope!
Last edited by Perth_shipyard on Mon Jan 13, 2014 12:07 pm, edited 1 time in total.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
All this sparky stuff with different coloured wires was doing my head in! So decided some building was in order
Made a proper stand well a running stand for when she's at the lake. Nothing pretty but it's practical and sturdy. Lined with black felt to keep scuffing the hull to a minimum and also on the bottom so I don't scratch the bosses dining table.
Also started to build the forward superstructure and forward stack. Photos to follow...
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
