Source: David Griffith preferred "mucilage" glue for rigging
wefalck
Re: Source: David Griffith preferred "mucilage" glue for rig
Post by wefalck »
I did a bit of research on 'mucilage', not as a product name, but as a class of substances. It appears to me that it is essentially a solution of arab gum. This has been/still is used extensively to produce the sticky backs of stamps (the ones you have to lick), the sticky strips on envelopes, and as a binder for (artists) paints (e.g. in water colours). On this basis, it should be easily obtainable in every country. Check out artists' shops.
wefalck
Eberhard
Image Image Image Image
BillThePill123
Post by BillThePill123 »
Hello - you can try that, but when I first started on this "quest" I bought some gum arabic at an artists shop, hoping it would work as a substitute, but it was not very sticky, and did not work as a glue. Maybe it can be doctored with other substances; that's outside my skill set.
wefalck
Post by wefalck »
I found a recipe for a paper glue with 25 g gum arabic, 100 ml of water as solvent and 3 ml of glycerine to make the glue more elastic. Also added is a pinch of ascorbic acid as preservative.
I remember a confectioned glue like this from my childhood in Germany and that was pretty sticky. On the top of the bottle it would dry to a clear, somewhat brittle layer. I thought it had long disappeared from the market, but just discovered that it is still available:
I gather one could vary the ratio between gum arabic and water to make it suitable for different applications.
Eberhard
Pagodaphile
Post by Pagodaphile »
For those not interested in going in to glue making, I just received that box of the "Longo" Mucilage from the Canadian source.
I'm holding out a few bottles for myself and a few more for those who have already expressed an interest. I'll post the remainder on the forum trading post for what I have in to these, about $3.25 USD (money order) and your postage per bottle....if interested contact me there or by p/m. :cool_2:
edit: I noticed that this stuff is now imported by a company called "Longo" into Canada, rather than the old "LePage" branding. FWIW.
