Renwal 1/500 USS Springfield (waterlined)
Steve
Re: Renwal 1/500 USS Springfield (waterlined)
Post by Steve »
The project is almost done. The pictures represent the final "dry fit" and the only incomplete work is some minor trim painting. I am assembling a "square bridge" option using the MM 3D components. I am slightly modifying these to fit the kit as an alternate so either bridge can be used for display. I will post the two side by side when done. I chose the hull number since the model is really a "never was" and also for a reason noted later. What follows is the list of "after market" components I used with comments on assembly.
1. The 6"/47 turrets and the two after barbettes are 3D from MM (Steve Larsen). Steve developed the barbettes specifically for this scale and project.
2. The 5"/38 twin mounts are 3D from MM with barrels made available by Steve from his single 5" mounts. Alas my 78 year old eyes and the carpet monster won the battle of using the 3D barrels so I substituted 700 scale 8" barrels from the Trumpeter Astoria kit. Thus my choice of the "90" hull number. I added my "soda straw" handling rooms to simplify installation and allow rotation. No one makes brass barrels for these in 1/500 scale.
3. The Mk 37 directors are 3D from MM. Steve Larsen almost succeeded in getting Shapeways to print the dish antennas for them but it was not to be thus the model is short any radars on the directors. I choose the option of not using the kit directors since they are rather plain and really did not look good on the model.
4. The 3"/50 twins are resin from Starfighter. I added a thin wafer of plastic to stand them up a bit off the deck plus plastic rod to allow rotation.
5. The Mk 56 directors are also resin from Starfighter.
6. The decals are from Alliance Model Works.
To assist in the layout of the after 6" mounts Paul sent me some scanned shots from the USS Miami plans in a format that I could work with.
Finally Steve Larsen worked with me trading ideas and developing components that made this "almost OOB" project possible. Steve brings to the modeling community a skill and dedication that is extraordinary! In his words what I did was just monkey around and have fun.
http://imgur.com/GkM6CLh
http://imgur.com/Q2Ny2sx
http://imgur.com/4Mcbpky
http://imgur.com/1wEbP3a
http://imgur.com/DgmGsPX
ftauss
Post by ftauss »
What about the float planes?
Steve
Post by Steve »
ftauss wrote:What about the float planes?
Based on info from Rick Davis the only Cleveland Class CL with all four 6"/47 turrets and 3"/50 twin mounts was the USS Manchester. In this outfit she did not have catapults.
Post by ModelMonkey »
Thanks, Steve! Your model is beautiful.
Post by Rick E Davis »
An aerial view of USS MANCHESTER (CL-83) shortly after she was upgraded with 3-in RFG mounts. She was upgraded with twin 3-in RFG mounts in late 1952.
She was the last of the All-Gun CLEVELAND class to see active service and the only one still active at the start of the Korea War.
An overhead view of USS MANCHESTER (CL-83) on 11 June 1953 during her last tour off Korea.
Steve
Re: Renwal 1/500 USS Springfield (waterlined) aka USS Manche
Post by Steve »
Steve wrote:The project is almost done. The pictures represent the final "dry fit" and the only incomplete work is some minor trim painting. I am assembling a "square bridge" option using the MM 3D components. I am slightly modifying these to fit the kit as an alternate so either bridge can be used for display. I will post the two side by side when done. I chose the hull number since the model is really a "never was" and also for a reason noted later. What follows is the list of "after market" components I used with comments on assembly.
The USS Manchester CL 83 "Final Kit Version"
Well almost a year later and some "playing around" with assemblies I finally finished two versions of the bridge. The first is essentialy the kit version and the option is the square bridge version from Steve. The foremast is removable and the bridge assemblies are interchangeable since the both bases are from the Springfield kit. I have enough parts to do another foremast so I won't have to switch out the mast when I change the bridge.
My thanks again to everyone who helped me on this especially Steve Larsen to fill in the gaps on needed parts to make the model more representative of the 12 gun version without major surgery. I owe Rick Davis thanks for his posting of the USS Manchester photos and the background info for obvious reasons. It made this an "as was" rather than a "never was" model.
https://i.imgur.com/N7OINQF.jpg
https://i.imgur.com/mJ903ew.jpg
https://i.imgur.com/l4nsXF6.jpg
https://i.imgur.com/64ktLeB.jpg
https://i.imgur.com/eJsgNR0.jpg
https://i.imgur.com/YGTGZZQ.jpg
In the pictures the foremast is loose and may be "off" the correct angle. The 6" triple barrels can be elevated and may be "depressed"
dwkr
Post by dwkr »
Rick E Davis wrote:An aerial view of USS MANCHESTER (CL-83) shortly after she was upgraded with 3-in RFG mounts. She was upgraded with twin 3-in RFG mounts in late 1952.
Hi Rick, Thanks!!! I've been looking for photos of Manchester with 3" guns for ages! Made my day!
