Hey, man! For a dedicated vessel, an LHA is a lot of overkill just for these craft, however linking up with one temporarily would be interesting for sure! Many of the vehicles and other amphibious support could be left off with the airwing forming its own support and projection force as well. After all, with how the LHDs are occasionally being fitted more like CVs and less like amphibs, leaving he Marines behind and acting as an inbetween aircraft carrier is a possibility.HvyCgn9 wrote: What about a refitted LHA as the mothership? Its got epic flightdeck,C3, welldeck, can refuel its escorts, massive storage capability,etc....
Bruce
What-If Regional Influence Squadron - Littoral Combat Force
- navydavesof
Re: Regional Influence Squadron - Littoral Combat Force
- navydavesof
While I have heard a couple comments, what should the PC(R) form up to be? What kind of capabilities should it have?
Then, is that craft worth building in a model form?
Also, how should I build this craft? Are there any kits of 3D printed models out there I could use and run with?
- navydavesof
There has been a lot of discussion and question about what other ships should be considered for the LCS Replacement or the new FF/FFG. After a bit of research, I believe that while the FF variants of the LCS classes have potential, the National Security Cutter is actually the best US candidate to build new FF/FFGs.
This type of ship, while may not be the "best" but could be the "easiest" solution to a NSF ship mounting 155mm guns, helos, a SOF deploy and recover ability, ASuW, while rolling a very good self defense suite. While sporting a sweet paint scheme, it would likely have:
2xMk45Mod6 155/60caliber guns (one forward in place of the 57mm gun and one in place of the aft RHIB ramp)
2xSeaRAM
4x35mm Millennium Gun (2 slave option to each SeaRAM)
16xMk41 VLS forward and 16 between the stack and the hangar
2xMk32 SVTT
Sensors:
SPQ-9B
TRS-3D
Counter Measures:
SLQ-32(v)6 (SEAWIP)
NULKA
Chaff
Those balloons you see on a few DDGs
Air:
1-2xHH-60 Sea Hawk
6xShadow
6xScan Eagle
Illumination:
2xSTIR (modernized SPG-60s or Mk92 BugEyes)
Refueling abilities for the Coastal Riverine capabilities:
Mk6
RCB
RPB
The NSC hull in both FF/FFG and NGFS configuration would be great. I am really liking this ship!!!
2xSeaRAM
2xMk32 SVTT
Sensors:
SPQ-9B
TRS-3D
Counter Measures:
SLQ-32(v)6 (SEAWIP)
NULKA
Chaff
Air:
1-2xHH-60 Sea Hawk
6xShadow
6xScan Eagle
Illumination:
Mk6
RCB
RPB
- SumGui
FF4923 is not a bad combination of capabilities on the existing hull,
http://nationalinterest.org/blog/the-bu ... navy-19020
But I believe the NSC needs extra length to get 32-48 Mk 41 cells, improved main gun, layered defense against small boats (secondary medium caliber guns), and deck space for Anti-ship Missiles (Harpoon or NSM).
The published Frigate options (4921/4923) seem to surrender endurance (one of the great features of this design) and not allow enough VLS cells to deal with a wide range of threats - in addition to 8 cells dedicated to 32 ESSM, the ship may need VLASROC, new LRASM, strike missiles, etc. Cells = versatility. You can leave them empty until needed, but when you need more cells because the threat changed or the environment got hotter, it is too late to add them.
There seems to be opportunity forward and aft of the forward superstructure within the hull to add length, and that length should allow SVTT amidships (forward of the hangar) so that the Helo's and SVTT can use a single magazine.
I'd think one Millennium Gun forward and one on the hangar roof would do the trick.
The CIWS can be RAM instead, and ESSM gets carried in the VLS.
The first thought is a Mk45 127mm forward, especially with Vulcano or Excalibur N5 available.
The Helo hangar also needs to be sized for two SH-60 sized helos (NSC hangar is sized for Dauphins). Naturally, her two hangars gives you the ability to have one H-60 and UAVs, or any combination you may need.
A 9-cell rotating EASR should be considered as the primary radar (cost has to be considered, of course), keeping in mind this ship will not only take care of itself but probably escort others and be a node for the entire battle network of sensors in a given area.
http://www.raytheon.com/capabilities/products/easr/
This could be a reasonable Fire Support platform in another version, placing a second gun mount on the fantail and perhaps upgrading both guns to a 155mm version of the Mk 45, but the dollar commitment to make that happen may not be available.
All of this I would compare on a cost/capability basis with the proposed FF4923 to see if the above added flexibility gets a return across the life of the vessel.
Considering the increasing threats and myriad of roles Frigates are called on to perform for the USN, I think it may pay off as long as modification does not break the bank. (The bank being total unit price under $1B each across production)
- navydavesof
I have been talking with an HII engineer, and it is feasible to lengthen the helo hangar by "the length of 16 Mk41 VLS and buffer" to accommodate 16 VLS and extra length by consuming some of the helo landing pad.SumGui wrote:FF4923 is not a bad combination of capabilities on the existing hull...but I believe the NSC needs extra length to get 32-48 Mk 41 cells, improved main gun, layered defense against small boats (secondary medium caliber guns), and deck space for Anti-ship Missiles (Harpoon or NSM).
I agree. Thirty-two should be great. This can wash around ESSM, LRASM, and VLASROC. ESSM offers the equivalent of 4 SM-1s per cell. The rest are as they appear.SumGui wrote:You can leave them empty until needed, but when you need more cells because the threat changed or the environment got hotter, it is too late to add them.
I agree. If arranged in-line, there may be a crunch of space on the hangar to accommodate 16-cell VLS, SeaRAM, AND a Millennium Gun to the point where you might have to have 2 Millennium guns aft, one port and one starboard. Regardless, I would still slave the MG to the SeaRAM.SumGui wrote:I'd think one Millennium Gun forward and one on the hangar roof would do the trick.
The lengthening to accommodate the 16-cells would accommodate that as well. The forward most part of the hangar space would be slightly narrowed like on the DDG Flight IIAs. Easy day.SumGui wrote:The Helo hangar also needs to be sized for two SH-60 sized helos (NSC hangar is sized for Dauphins). Naturally, her two hangars gives you the ability to have one H-60 and UAVs, or any combination you may need.
I really dig the combination of the TRS-3D/TRS-4 and the SPQ-9B is an awesome combination for air and surface search with FC.SumGui wrote:A 9-cell rotating EASR should be considered as the primary radar (cost has to be considered, of course), keeping in mind this ship will not only take care of itself but probably escort others and be a node for the entire battle network of sensors in a given area.
If we were serious about the 155mm question, we could do it inside of 2 years. Look at the process of the Mk71, and that was done at a casual pace.SumGui wrote:This could be a reasonable Fire Support platform in another version, placing a second gun mount on the fantail and perhaps upgrading both guns to a 155mm version of the Mk 45, but the dollar commitment to make that happen may not be available.
I agree 100%!!! Many would try to compare this to LCS and discredit it to what they believe LCS offers for $400 million a piece. As time has passed, we know the LCS itself rolls in at well over $450 for the delivered ship, then there are all kinds of "Navy supplied equipment" that boosts the costs, and then finally the non-existent mission modules still have to be proven, installed, and effectively used. Once the ship is ready to go do a mission, the cost is pushed well over double the original cost. The NSC type FFG would be delivered ready to accomplish the missions without screwing around with the ship...just like a frigate should.SumGui wrote:Considering the increasing threats and myriad of roles Frigates are called on to perform for the USN, I think it may pay off as long as modification does not break the bank. (The bank being total unit price under $1B each across production)
- EJM
If only there was a 1/350 plastic NSC model available to whif all these changes to.
Resin is too expensive for my taste. And I'll assume those pics you posted navydave are of a Shapeways 1/700 NSC? Nice, but I'd rather stick to 1/350.
- navydavesof
Nope! It's 1/350EJM wrote: And I'll assume those pics you posted navydave are of a Shapeways 1/700 NSC? Nice, but I'd rather stick to 1/350.
- tko24
I was the one that asked Dutch Fleet Miniatures to scale up his 1/1800 NSC to 1/700 and 1/350 a couple of years ago. I bought it in 1/350 and 1/700, I finished the 1/700 as USCGC Bertholf using several 1/700 kits to fit it out, but I haven't done anything with the 1/350 yet. It came out kind of clunky as a 1/350 kit and will require some scratch building and a lot of donor parts to build, but nobody else will ever produce any Coast Guard kits other than JAG or ISW. I look forward to seeing what you do with it, maybe it'll motivate me to finally do something with mine.
carr
- navydavesof
Welcome to the fray! Indeed I have an idea but I've been reticent to share it for Navy reasons. I have to remain kind of vague about it, because it's going to be part of an official proposal.carr wrote:I've sat out this thread, so far, because it's an appealing topic that possibly lacks an operational/tactical foundation.
It's 2 fold: Peace Time and War Time. The reason why I named it "Regional Influence Squadron" was, because it would be influencing a region. That's mainly a non-combat role that carries the threat of a heavy punch if combat operations commenced. Most of the time, it would be a large number of vessels that would be an aggravating thorn in an adversary's side while providing aid, comfort, and confidence in allies' minds. For instance PC(R)s and Mk6s providing presence in and around the contested islands in the ECS and SCS. Indigenous to the group surveillance and air support in the form of H-60s or AH-1s and Shadow and Scan Eagle respectively would be available from the LSD/AFSB, FF/FFG, or LCS operating within a reasonable range. The threat there would be 76mm gun and ASCMs with the ability to chew up the island facilities and hit any ships within the respective weapons' ranges.carr wrote:1. I assume this RIS is for war. In peacetime, it doesn't matter what ships/aircraft one chooses because we've made it clear that we won't take any actions. Trump may change that but it remains to be seen. So, the RIS must be built for war.
War Time:
The threat would then be realized with the employment of those weapons. The group would then need to be reinforced by or rendezvous with AAW and ASW combatants and rearm. They would likely have to rearm some where like Yokosuka if the facility was relatively undamaged in the attack.
A mix of the PC(R)s, likely as fitted when the attack happened or refitted in Japan or Guam, could then operate in ASuW, ASW, operations or PDS AAW escort. The description of the mixes of fits (ASCM, ASW dog-house with Mk32 SVTT and a yet-identified towed array, and swapping of the Phalanx CIWS with SeaRAM is described in the other PC(R) threads.
Indeed. Most air power would come off the assigned LSD/AFSB, FF/FFG, or LCS.carr wrote:2. I assume the premise behind the RIS is that it is a lower priority force, meaning no supercarriers.
This would be true in both peace and war time. UAVs are lost quite often. The group's elements would have access to other C4I assets as long as they were in the area as well.carr wrote:3. David stated that the relevant theater is the first island chain. This, in turn, limits the degree of surveillance that can be provided by the ships, themselves, and suggests the need for a heavy UAV presence to provide the wide-ranging surveillance that a "regional" force would need. Thus, a RIS requires a UAV-carrier with a large UAV inventory because the UAV attrition will be substantial.
As a brief wrap up, again this is not meant to be a Regional Fight and Win A War By Itself (RFWABI) force. Its main function and use would be to pose a threat (ASuW, ASW, and short to medium range AAW) to aggressive power. If it came time to snap-shot an assault, a large number of ASCMs could be fired from deck mounted launchers, Mk54 torpedoes could be fired at submerged targets that were being tracked, and RAM reinforced with SeaRAM could throw a great number of RAM at an incoming ASCM threat as the force consolidates and forms up with the more expensive and more capable combatants as a larger theater-wide strategy was initiated.
- navydavesof
My training cycle is over, and I am headed out for a deployment soon. Of all these projects I have, I can focus on one. I know what I would like to work on and hopefully complete before I leave, but I would like to know what you guys think I should work on and finish before I leave.
Let me know and I will begin work this coming week!
carr
- navydavesof
Vote heard!carr wrote:PC(R)
- SumGui
The two items I'd most like to see are PC(R) and a FF version of the NSC.
PC(R) seems most germane to this thread, as the Future of Frigates is still up in the air.
Edit to add: the up-gunned LCS-1 design would also be high on my list, probably my first choice. After all, what do we do with all of those hulls we are on the hook for...?
