IJN Yamato, 1/350, 1945 - COMPLETED
Re: IJN Yamato, 1/350, 1945
Off to a great start, Joe.
Joe Simon
Thanks Martin!
- J. Soca
Nice job Joe
Hull looks most complicated and intricate to put together
supposed to be a fun kit to model not a jigsaw puzzle jeez.. Companies raise the bar but it always gets complicated.
Jose
Jose
- Strategos Augustus
You are going to make the rest of look bad again.
Looking very promising.
Joe Simon
Thank you gentleman! Yes Jose the ship is like a giant jigsaw puzzle! I am very carefully pouring over ever possible seem to make sure it is right.
Joe Simon
The hull sides are now on. Much seem filling:
IMG_3622 by Joseph Simon, on Flickr
IMG_3623 by Joseph Simon, on Flickr
IMG_3644 by Joseph Simon, on Flickr
IMG_3645 by Joseph Simon, on Flickr
IMG_3647 by Joseph Simon, on Flickr
IMG_3651 by Joseph Simon, on Flickr
IMG_3651 by Joseph Simon, on Flickr-
Joe Simon
Much work done on the flight deck. It is a combination of Pontos, Tamiya grating, and Lion Roar perforated plate. I had to Dremel tool the Pontos part to remove the solid area and install the perf board. Flight deck is not attached as of yet. Total time is 135 hours thus far.
IMG_3619 by Joseph Simon, on Flickr
IMG_3621 by Joseph Simon, on Flickr
IMG_3625 by Joseph Simon, on Flickr
IMG_3630 by Joseph Simon, on Flickr
IMG_3634 by Joseph Simon, on Flickr
IMG_3633 by Joseph Simon, on Flickr
IMG_3635 by Joseph Simon, on Flickr
IMG_3636 by Joseph Simon, on Flickr
IMG_3638 by Joseph Simon, on Flickr
IMG_3639 by Joseph Simon, on Flickr
IMG_3640 by Joseph Simon, on Flickr
IMG_3654 by Joseph Simon, on Flickr
IMG_3654 by Joseph Simon, on Flickr- Strategos Augustus
Looking absolutely brilliant so far.
Quite a bit of mutilation!
Joe Simon
Open 12.7 cm gun tubs modified with Lion Roar:
IMG_3539 by Joseph Simon, on Flickr
IMG_3542 by Joseph Simon, on Flickr
IMG_3673 by Joseph Simon, on Flickr
IMG_3669 by Joseph Simon, on Flickr
Hanger door with Lion Roar and hanger area with Pontos:
IMG_3657 by Joseph Simon, on Flickr
IMG_3660 by Joseph Simon, on Flickr
IMG_3669 by Joseph Simon, on FlickrHanger door with Lion Roar and hanger area with Pontos:
IMG_3660 by Joseph Simon, on Flickr-
Nice! Lot of work for those guntubs.
marijn van gils
Looking great so far!
What kind of glue do you use for mating those large PE decks to the plastic hull?
Marijn
Marijn
Joe Simon
Thanks Dan and Marijn! I used thin CA on the decks.
- Aop Aur
Now I see the two PE sets are so useful! This is going to be amazingly detailed!
Aop
Aop
On the way:
And our artworks!
And our artworks!
- GewoonWouter
Missed this one but I'll be definitely checking in from time to time. I'm building the same kit for about a year or two now
Koppalakki's one was inspirational to me as well.
Seems you had a great start, looking really good so far!
Joe Simon
Thanks Aop and Gewoon! Some progress on aft bridge. I added the Lion Road gun tub bottoms and put in 0.005 styrene triangle supports. I had the option of using the Pontos parts but felt they showed too much gap around the supports, and also felt the supports were too thick. I also added other styrene supports in accordance with Skulski.
IMG_3690 by Joseph Simon, on Flickr
IMG_3693 by Joseph Simon, on Flickr
IMG_3696 by Joseph Simon, on Flickr
IMG_3697 by Joseph Simon, on Flickr
IMG_3698 by Joseph Simon, on Flickr
IMG_3707 by Joseph Simon, on Flickr
IMG_3708 by Joseph Simon, on Flickr
IMG_3708 by Joseph Simon, on Flickr- Strategos Augustus
Looking good!
marijn van gils
Great work!
The scratch built support match the molded kit supports perfectly.
Marijn
Marijn
Joe Simon
Thank you Marijn and Strategos! I have finished installing the gun tubs and added the framing in styrene on the smaller ones:
IMG_3711 by Joseph Simon, on Flickr
IMG_3713 by Joseph Simon, on Flickr
IMG_3715 by Joseph Simon, on Flickr
IMG_3717 by Joseph Simon, on Flickr
IMG_3721 by Joseph Simon, on Flickr
IMG_3721 by Joseph Simon, on Flickr- MartinJQuinn
Nice! I expect to see this at MosquitoCon in April
Joe Simon
I'll bring it if you insist. It may take you some time to judge a box of parts however!
